Question about HP 48gx Calculator
The calcutor doesn't turn on from the first time. It takes too long to turn on and at random. Also the soft keyd don't work. I try to set the modes but when I press shoose nothing happens.
  • HP Master
  • 8,016 Answers
The following testing procedure valid for the HP 48G should work for the HP48GX. If any the tests fails the calculator requires service.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
Posted on Nov 07, 2009
  • k24674 Nov 08, 2009
    If calculator requires repairs,
    There is an HP customer self repair (CSR) which you can
    contact. On the site it is said that the service is available for
    products under warranty or on contract. but you have nothing to lose by
    contacting them. Here is the link to the web site.
    - You can also try this site. They do repairs on most models, except the newer ones.
Keeps going into soft safety mode
Take your Smart to a competent mechanic and have it diagnosed. Otherwise, you will be just replacing parts at random without solving the true problem.
Jan 10, 2014 | Cars & Trucks
For a long time the monitor wouldn't come on right away when the computer was in sleep mode, or hibernate. I'd move the mouse around and nothing would happen for 2 to 3 minutes - sometimes. Other...
Probably not a setting
If you are on windows : Can you change the power setting in the interim , to stop it going into hibernation - sleep mode
settings > control panel > power options>high performance should be clicked and then click change plan, PUT THE COMPUTER TOP SLEEP > NEVER
Does not solve the intial issues, but tis impossible to diagnose in this forum
Hope it helps
Apr 21, 2017 | ViewSonic VP2030b 20.1" LCD Monitor
My HP w2007 has started clicking to Monitor Going to Sleep and then going blank. I have never known how to wake it up so I have to turn the whole computer off and restart. HELP
Hey there, Normally simply pressing a random key on your keyboard or moving your mouse should wake it up, if it doesn't though I think the easiest way to solve this is to simply turn off the sleep mode after x amount of time.
If you have windows 7, press the start button and type in "power options", go ahead and open power options and there you will be able to set the time it takes before your PC shuts down, and you can also set it to never.
If you still wish to use this feature but just want to be able to it's a bit tricky and it won't even work for all PCs but if the keyboard waking isn't working, then it's probably because your pc does have this feature. When your PC is off, boot it up again and enter the bios by pressing F10 i believe it is for HP. And somewhere you should be able to set which devices are allowed to wake up your computer, all devices are probably disabled now, so go ahead and enable the keyboard to wake up your computer. Now save and exit, and the next time your PC goes to sleep mode you should be able to wake it up by pressing a key on your keyboard.
I hope I was able to assist. If I was, please don't forget to rate this solution.
Jul 28, 2011 | HP Pavilion F1523 15" LCD Monitor
Samsung S8000 Camera is not working. I don't know why.
Try to go to the camera settings of your phone and try some adjustments or try to update the soft your phones camera, but if it doesn't work maybe your cellphone camera has a hardware problem.
Jul 01, 2011 | Samsung Jet S8000 Cell Phone
Magnavox older tv; suddenly shows a "tutorial" which begins "Here's why this should be your next tv". then reviews tv's features ex: close captioning, sleep timer, language,...
Your TV appears to be in what is known as DEMO MODE, which is used when the TV is set up in the store on display.
In order to disable that mode and return it to normal operation, try the following procedure:
Turn on your TV.
Hold down the VOLUME UP and the VOLUME DOWN buttons at the same time for 10 seconds.
Be sure to use the buttons on the front of the TV and not the ones on the remote control.
Some models may turn off at this point while others may not. Either way, the set should now be ready for use in NORMAL MODE.
If that does not cure the problem, then check in your OWNER'S MNAUAL for the exact procedure on how to disable the demo mode feature.
I hope that was helpful to you, good luck and take care.
Joe.
Jun 20, 2011 | Televison & Video
The television stays in closed caption mode regardless of the settings. Is there a way to reset it to factory default
try turning off the caption through the remote of the menu. to reset it to factory settings, go to menu, then settings, then there should be an option to reset the tv. If this doesn't work look through your manual. Sometimes you have to hold the power button for some length of time or the menu button on the tv. if these methods don't work, tell me the model and make of the tv.
May 28, 2011 | Televison & Video
My camera takes pics without any movement infront of it. I set it up in my closet and it still took pics at random over the 30 minutes in there it took 17 pics. Longest time in between pics was 9...
Scroll thru setup menu and make sure you don't have it in time lapse mode...if it is, it will automatically take a pic every whatever time time lapse is set for.If it is, set to default and reprogram.
Oct 10, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My rev counter, speedo, fuel gauge and temp gauge
try to check yor meter conection at the rear of your meter.there is a loose connection due to vibration
Mar 30, 2009 | 2006 Gilera Nexus 250
Random "mode flipping"
Mode dial has connection problem in built-in switch. try to use W-40 lubricant 1 drop.
Jun 05, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Rebooting
Random rebooting, without know the history of your PC all I can do is give you a list of things to try and look for. The first thing I would do is check the basics, if that turns up nothing then the only option left is to removing variables one at a time. Obvious things to look for: - Physically remove and clean the processor heat sink. Make sure the area directly underneath the CPU fan is clean of dust; you have to remove it usually to make sure. When you reattach the heatsink take the opportunity to clean off the old and reapply new thermal grease. Use sparingly to ensure excess material doesn?t get on the CPU pins or the motherboard. - If you have a video card with its own heatsink and/or fan make sure it is free of dust. Make sure the fan runs freely and forcefully. It usually takes a can of compressed air to clean the dust underneath the fan, in some cases it requires disassembly. - Make sure all connectors are snugly plugged into their sockets. - Make sure all cooling fans, especially the power supply are running smoothly and forcefully. - Vacuum out case air vents and blow out dust from all secondary heatsinks and around the memory modules. - If your computer is plugged into a power strip or UPS try plugging it directly into a tested wall socket. - With the computer running try wiggling where the power cord plugs into the PC and the wall socket. If nothing turns up the next step is to make this computer as basic as possible. Disconnect any secondary drives, all USB devices, hubs, ports, printers anything you can remove and still have the PC boot. Don?t assume something couldn?t possibly cause this, making assumptions works against you. Run the machine in the basic mode and see if the problem persists. If it doesn?t don?t assume its one of the things you removed, replace the items one by one remembering it could be a power problem that only manifests itself when lots of stuff is plugged in. If the problem persists try these one at a time: - Typically your system BIOS will have a safe or factory reset mode, set it to that making note of the setting you had originally. - Try removing the hard drive and boot via a CD (Windows install or a diagnostic disk will do). - If you have a plug in video card try using the motherboards built-in video or another know good video card. - Test or preferably replace your power supply with a known good supply. - Try new memory. - At this point we?re probably left with just the processor and motherboard which means unless you have spares around you?ll need to start considering if its time to upgrade to a new motherboard and/or processor. Also if you haven?t done so already you should immediately backup (and test) your important files stored on your computer. The random shut downs are dramatically increasing the chance your hard drive will suffer damage or data corruption. I hope this helps but let us know if you have any other questions and please don?t forget to rate this post.
Mar 31, 2007 | VIA C3, 1 GHz (5na00m11q-bwt6a) Processor
HP 48gx Calculator Logo
104 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
