Question about Plumbing
What is the maintenance for a zoeller extractor pump?Should it be serviced so there won't be a problem?
  • 523 Answers
There really is no maintenance for a Zoeller submersible pump. When these fail it is typically the switch or the motor itself. If it is a smaller unit 1/2HP to 10HP I consider the pump trash if it is the motor that does fail. Yes they may be rebuilt but when compared to the cost of a replacement it can be hard to justify, especially when a new unit will give you a warranty.
I hope this may have helped,
Tom
Posted on Sep 23, 2009
Have a Zoeller 710 backup sump pump and keeps blowing fuse, whats the problem?
Make sure the impeller is as clean and clear as possible, anything clogging it and restricting its rotation will cause it to blow a fuse. If tis not turning easily and feely most likely the bearing is starting ti seize up.
Aug 13, 2014 | Zoeller Powered Emergency Backup Sump Pump...
Zoeller m267-f pump has power going to the motor but will nut run
Does it have a float switch? Does the motor run when you lift the float switch? If not... then the motor's gone.
Jul 23, 2014 | Zoeller Sump Pump with 25 foot cord 2" 1/2...
How much wattage is needed to run z57 zoeller pump
It probably draws about 6 amps so the power is 720 watts. Put it on a separate 15 Amp fused line so it doesn't put electrical noise into other items such a TV or radio for best results.
Apr 28, 2014 | Zoeller M53 Mighty Mate Iron Body, Poly...
Zoeller Pump M57
The only "easy fix" may be a stuck float switch. First make sure the outlet where the pump is plugged in works. Plug something into the outlet such as a work light to confirm the outlet is live. The float switch may be stuck in the OFF position. Giggle the float arm up and down several times to see if the pump comes on.> You can spry wd40 into the switch where the arm enters. If this does not work, the pump probably needs servicing.
Apr 07, 2014 | Zoeller Sump Pump, 3/10 HP - M57
My Zoeller M57 pump has stopped working. It won't even turn on...is there a reset switch or some other easy fix for this?
These Zoeller pumps are very good quality> I suspect that the float switch is not working, which is why the pump is not turning on.You may try giggling the float arm that is attached to the switch. You can also try spraying some WD 40 into the switch where the arm enters. Zoeller does have replacement parts for their pumps. Review their website for your pump parts.
50 Series Zoeller Pump Company
Fixed! Zoeller M53 won't turn on. Will turn on with a slight tap.
I had the same problem of pump not turning on unless I tapped the pipe to create a vibration. I took the float off and cleaned the grime / buildup. The buildup changed the buoyancy of the float (made it heavier) such that it did not float high enough to trigger the switch. Once cleaned, the float floats much higher above the water line and triggers the switch.
Apr 04, 2012 | Zoeller M53 Mighty Mate Iron Body, Poly...
Where can i buy a replace float road for a m98-b zoeller water pump
zoeller is a pump normally found only at plumbing and heating supply houses. they should carry or can order thge part for you
Jan 04, 2010 | Zoeller M53 Mighty Mate Iron Body, Poly...
Zoeller M53, pump keeps pumping half the power
try backflushing with high pressure water(carwash) if that doesnt work you have to remove the bottom plate to expose the impeller and remove debri,gasket will probably have to be replaced(silicone) will do
Oct 31, 2009 | Zoeller M53 Mighty Mate Iron Body, Poly...
I HAVE A 8 1/2 DIAMETER SUMP.MY OLD PUMP FAILED. CANNOT FIND A PUMP SMALL ENOUGH TO FIT.HELP!
get a submersible zoeller sump pump the flaot is attached to the pump not a teather and it wilol keep less water in the pit,, this is the best pump on the market
Jun 12, 2009 | Zoeller M211 Automatic Aqua-Mate...
Plumbing Logo
104 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
