Question about Nextar MA933A MP3 Player
When I plug my MP3 player into a USB port, it locks computer
When I plug my MP3 player into a USB port, it locks up the computer. Trying to play anything it shows disk empty. Also, when I tried to record voice, it said 'initializing . . .(then) disk error'
    President:
  • 803 Answers
Try resetting the device it?s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds OR Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturers website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Posted on Nov 03, 2009
How do you charge my player Player will not play. Do you charge by plugging into any USB port?
yes, plugging it into a usb port (either through a wall charger or a computer) will start to charge the mp3 player. an indicator that it is charging should show up on the screen.
Jan 24, 2011 | RCA M4204 MP3 Player
Im trying to download music on my mp3 player i just got for christmas an i cant figure out how to ? it said to look up more info on www.gpx.com but i cant find anything
MP3 players can only play music files in mp3 file format.
Google search for free mp3 music files and download them to your computer. Then connect the USB cable that came with your player, connect it to your player and then plug it into the USB port on your computer. The computer will see the player as an external storage device, then copy the mp3 music files to your player.
You can convert your CDs for free and copy them to your MP3 player. Please click on this link and follow my instructions :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Dec 26, 2010 | GPX ML759 Digital Media Player
Where do you plug in the mp3 player to transfer music?
You MP3 player will be supplied with USB cable. Attach the cable to the MP3 player and plug the other end of the cable into a computer's USB port.
The computer will see this as an removable device, you can then open this device and copy mp3 music files from your computer and paste these files into your MP3 player.
Nov 07, 2010 | Compaq Presario 5000 PC Desktop
Low Battery Mp3 player How do you charge it? Thought it was thru the USSB port on computer with computer on?
Hi dave holte,
It should be through the USB port, I don't think any players nowadays have separate ports for charging. Nevertheless, check if there is any port other than the headphone and the USB, because it never hurts to check. Does the computer recognize the device when you plug the mp3 player into the USB? It might be loose connection as well. Or maybe it is not set to be recognized as an MTP or Plug-and-Play device. Once you have it plugged in, go to My Computer (I'm assuming you are on PC) --> Device Manager and then scan for new hardware changes. Probably then you have to manually install the device and its drivers. But do check for the loose connections. Ask back if it doesn't work.
Mar 25, 2010 | RCA TH1611 MP3 Player
My son's mp3 stopped playing yesterday. We plugged it into the computer. There's no response from the player and no indication from the computer. the usb ports on the computer work.
Are you plugging it infront or at the back USB port of the computer? Try turning it off first and then plug at the back usb port. Once plugged in, that would be the time you turn the MP3 player on. If the computer still does not detect the mp3 player as new usb device, then i guess the mp3 player must have been fried due to not being "safely removed" from the usb port. Make sure you are safely removing ALL usb devices when disconnecting them from the computer.
Mar 01, 2010 | Audio Players & Recorders
My Sansa MP3 player does not play on the i symphony dock. How can I solve this problem? The i symphony says it is reading when I plug the Mp3 player into the USB port but then it says no USB. Can I play my...
The only solution for that is that if you are using a usb cable to plug it in to it. If you are you should try a new cable. If that does not work you might want to connect your player to your computer and see if your computer read your player. because iSymphony does suport Sansa
Sep 27, 2009 | Audio Players & Recorders
USB Port and Creative MP3 player - wont play
Dragonclu your fix is very good if this was a computer unfortunately you did not read the problem correctly this is about a standalone stereo system NOT a computer or a computer program. Your problem maybe that your Creative MP3 player is registering as a portable media player which the stereo system does not support chech if theres an option in your MP3 Player to use USB Mass Storage which the stereo system will read and playback
Hope This Helps
Apr 07, 2009 | Electronics - Others
Files will not load
Try reformatting the drive to factory defaults. I would also try this unit on other PCs to verify that the USB port will not work correctly. Does the USB port on your Sony Walkman MP3 player have any damage or broken pins/connectors on the USB port?
Mar 31, 2008 | Sony Network Walkman NW-E005 MP3 Player
Computer doesnt register device as being plugged-in
This can be a problem with your USB capabilities in your computer.
If you are using your front USB ports, it is possible they are underpowered. Try switching to the rear USB ports.
You can also try a self-powered USB Hub to improve performance or purchase a USB 2.0 card for your system.
It could be something as simple as a bad USB cable. That would be the cheapest place to start...next to trying the rear USB ports.
Mar 05, 2008 | Insignia NS-DA1G MP3 Player
Its not plug and playing Sandisk 240m 1g
Hi blackmajik, I just got a Sandisk m250. Windows wouldn't recognize it either until I updated my Windows Media Player to version 11. Now XP sees it just fine and the MP3 player syncs with WMP and accepts and plays music!
Jun 07, 2007 | SanDisk Sansa m240 MP3 Player
Nextar MA933A MP3 Player Logo
109 people viewed this question
Top Nextar Audio Players & Recorders Experts
ray gallant
Paul Chapman
Paul Chapman
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
