Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
Wireless light is on solid and no wireless connection. Internet connectivity is still possible through wired LAN cable.
  • 11,896 Answers
These due tend to build up a static discharge and you will need to unplug it for 10 and plug back in to reset it.
Posted on Sep 23, 2009
Cannot connect to 192.168.1.1 to set up wireless in my router
If you fail after ping your IP address then it may be problem in your physical connection,so you should check connection like:
check cable modem status light. If it is solid green, it indicates that your cable modem has a good connection. If the light is off, check modem's physical connection.
Verify that the Internet light on your wireless router is solid or blinking green. It indicates a good connection and correct wiring. If the light is off, check the Ethernet wire's connection between your modem and router.
May be it can be cause of Incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
***If you need any kind of technical assistance you can contact support cell at here
Feb 01, 2013 | Actiontec GT704WG Wireless Router...
Solid yellow Internet light on D-Link DIR-825
Try a new working LAN cable between your internet modem and the router. Is your internet modem connected and working? You should be able to directly connect using a LAN cable to check the modem connection. Reboot your modem and router.
Nov 16, 2011 | D-Link DIR-615 Wireless Router
Before connecting to the internet wired or wireless, a blue screen occur... I unistalled wireless drivers and re-istalled again, I replaced the wireless unit with a new one using the original configuration...
Try getting the driver from the manufacture on the internet. The driver maybe corrupt causing a blue screen. Another solution is to use a live linux cd, example puppy linux and see if works that way.
http://puppylinux.org
Apr 04, 2011 | Computers & Internet
The CD is not available for installation is it necessary? I have all of the cable if the Yellow cable connects to the cable router what does the white cable on the wireless router connect to. Thank...
If the cables supplied have RJ45 connectors then they are used for connecting and configuring the wireless settings in Netgear router and to connect the Netgear to the DSL modem foe Internet access.
Most likely the color of the cables is not important.
To configure the wireless settings, connect a cable from one of the LAN ports (not the WAN/Internet port) to the LAN port on your computer. You may remove this cable after configuring the wireless settings if you want to connect to the Netgear by wireless only. You need to connect other computers to the Netgear's LAN port with a cable if they do not have wireless cards installed in these computers.
The other LAN cable is used to connect the Netgear WAN/Internet port to the DSL modem so you computers can connect to the Internet via the Netgear router.
Follow these instructions to configure the Netgear router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 23, 2011 | NetGear WGT624 Wireless Router
I have a d link d1 514 router. I'm unable to open 192.168.0.1. if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
carry out the resetting of the dlink router
then use lan cable to gain access to dlink router,
set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
Try turning off the router for 30 secs, then power it up again.
Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
If you can connect to the Internet then -
With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
Also install the latest wireless card driver.
Then test the wireless and Internet connection. If this doesn't work -
Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Will not connect to the internet wired or wireless
Unplug your power from the modem first and after that unplug your power to your router, disconnect all your cat5 cables and wait for at least 20 secs. After 20 secs or so go ahead and plug your power back to your modem and wait until all the flashing green lights are solid and that the link light starts blinking. After that plug in your Routers power (You can also reboot your PC while this is going on) . Wait until all blinking lights becomes steady then re-connect your cat5 from the modem to your routers uplink and last the cat5 cable from the router to your PC. If you'd rather not test the direct connection then go ahead and switch your wireless on.
Your wireless connection properties on your PC under "Internet Protocol TCP/IP" should be set to "Obtain IP address automatically" and that "Obtain DNS server address automatically" should also be set. Your routers should, if not already, be set to automatic DHCP. Make sure that on your Device Manager > Network Adapters that your wireless network adapter is not disabled and that it has the correct driver (yellow exclamation on it indicates it needs correct driver). You should disable your integrated ethernet LAN card if you have enabled your wireless Network Adapter to avoid conflict.
On your Wireless Network Connection properties under "Wireless Network" tab go to "Preferred networks" and highlight your wireless network name (SSID) . After highlighting click on the "Advanced" button and select "Access Point (infrastructure only) networks only"
Jan 23, 2009 | Toshiba Satellite L25-S119 Notebook
Cant connect wireless router to laptop
With cable attached type http://10.0.0.2 and enter the username admin and the password zoomadsl then go to basic setup and make sure your ISP username and password are listed under PPP then click start next to 'configure my network' save changes and write to flash. Make sure the DSL light is on solid (otherwise its an issue with your phone line/isp account).
Jun 24, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Having difficulty logging on to internet.
Re Router;
Is it properly configured with your DSL modem? Are patch cables porperly wired EA568A or 568B? Is your power to the router good? make sure all connections are solid. Check the cables with lan tester if possible.
Nov 11, 2007 | NetGear MR814 Wireless Router
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
131 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Elise Lacoursiere
Elise Lacoursiere
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
