Question about Harman Kardon AVR 320 Receiver
Harman Kardon AVR 320 Stereo Receive Problem
This receive keeps kicking off, like it's overheating. After it work a few minutes, a while--no consistent time pattern.
Also, we'd like to request to be sent another manual for this receiver--can that be done???
  • mikeg003 Nov 29, 2008
    my harman kardon avr 320 is not new but just starter useing it last week. It worked fine till the other night. i was watching tv late and it just shut off. i tryed it the next day and it turns on the off in about 3sec. read the trouble shooting part about reseting tryed it but still the same. does it need to go to the shop? mike
  • Anonymous Apr 30, 2009
    just goes off after few secs, and then can turn it right back on and same thing off a few secs later, what gives>?
Check for a couple issues..... #1 - The STDBY battery or capacitor is functioning properly. #2 - The "Service Switch" located under the top cover is not dead shorting to ground. You should measure approximately 3.6 VDC off the battery and a similar level off the capacitor if it's so equipped. The Service Switch, should measure approximately 3.3VDC between the pins when in stand-by. 0.0VDC when depressed. This switch shorts the power to the DSP to ground causing a reset condition and also eliminating any stored settings within the unit. The switch can effectively be removed from the circuit by cutting the vertical jumper. This may help with your intermittent shutdown issue.
Posted on Sep 26, 2012
I need to buy the manual repair the receiver harman kardon avr320, could you tell me how
Posted on Oct 20, 2010
Ours overhears too. Have to keep it well ventilated. It's annoying.
Posted on Feb 06, 2010
They just overheat, ours does, have plenty of circulation and a fan behind it if its warm.
Posted on Dec 18, 2007
My receiver turn on and shuts off
Are there any error messages on the display ?
Any blinking lights?
Harman Kardon US
Dec 12, 2013 | Harman Kardon AVR 320 Receiver
Will not retain presets
Many times a capacitor is used in place of an actual battery. On Harman Kardon receivers this component is on the front side circuit board behind the receivers external display. Harman Kardons website provides the actual location and part number if you dig around for the service manual PDF.
Jan 12, 2012 | Harman Kardon AVR 320 Receiver
Can you hoop up an external equalizer to the Harman Kardon AVR 30?
Any traditional old-school analog stereo processor can be used only with analog stereo sources.
If this receiver had any digital sources, you would eventually discover that activation of a Tape Loop disables digital sources. Just the same you CAN still use DSP on processed 2-channel audio.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Harman-Kardon-AVR-30-Receivers-review-manual/id/386bh140/t/1-2/
It's should clearly marked on the back of the EQ where everything goes.
The Line IN and Line Out would go to any available Tape Loop on the receiver. Something that has Out's and In's. Obviously, Out's on one device go to In's on the next.
Apr 29, 2011 | Harman Kardon AVR 30 Receiver
Fiber Optic input
No gots. The 3485 is pre-digital stereo-only.
From the manual, page 19
"You may have observed that the HK 3485 is not equipped with digital audio inputs or surround sound decoding. If you prefer the complete home theater experience, you may wish to consider purchasing a fullfeatured Harman Kardon AVR Series audio/video receiver. However, we hope you will find that using a DVD player with the HK 3485 in smaller settings, such as a bedroom or den, surpasses the audio performance of most televisions, including those with onboard stereo speakers."
Apr 13, 2010 | Harman Kardon AVR 240 Receiver
My Harman/Kardon AVR 140 is stuck on stand by mode
I have the same problem on my AVR 1550 - its been bugging me for ages then it works again, then it doesn't ...
Aug 28, 2009 | Harman Kardon AVR 140 Receiver
Harman Kardon AVR 120 turns off by itself after normal work for about 1 min
Do you get an indication on the display where the point of failure might be? It would show up on the LCD speaker diagrams just before shutting off.
Dec 05, 2007 | Harman Kardon AVR 120 Receiver
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
Harman Kardon AVR 320 Receiver Logo
598 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
