Where do I buy a spare power adapter pa-225
Where do I buy a spare power adapter Opti pa-225. This is the power adapter used on the Antec MX-1 hard drive enclosure.
For those who run across this situation, don't add to the land fill if you can fix it. The majority of the problems with the PA-225 and 226's, is the DC plug connector that connects to the MX-1. That plug's connections are 4 pins and one thru-hole terminal that's meant for the center wire, ground line connected to the plugs metal jacket, which is the ground for both 5 and 12 volt lines. The problem is that during assembly, they miss getting the wire through the eyelet of the ground terminal and solder it anyway, which usually creates an intermittent or permanent disconnection later. Although this can happen for the pins, the main culprit is this ground connection. When this becomes disconnected, the LED will Blink indicating a problem. Normally the LED is a solid orange. The plug's molding can be cut (spit in half) and slid back to expose the plugs ground terminal. The inside molding can be cut/chipped away in if need be to expose the ground line. You might need a really good mag lens to show the fault. I took some pictures and created a pdf on what I found but haven't posted any where. If all else fails, you can order one from Antec. However, beware that the connector used on the replacements will most likely not be the same as the originals. So, if your supply is really DEAD, keep it for the 4 pin male connector, and check out this Antec Online Store for their replacement. Also be aware that I've discovered that the original supplies, two of the pins are used as one 12v supply, and the other two pins are the 5 volt supply with the plugs metal jacket as the ground for both. The original supply's labeling is incorrectly pictures as each pin pair being both positive and negative, with the metal jacket not connected. Make sure that this your next supply does not ground to any of these pins, only to the jacket. The motherboard inside the MX1 connects each pin pair together for a positive terminal only, therefore, if you get a supply incorrectly matching, you can toast a new supply. If you look at the male connector from the original supply with the plastic key "top". The left pin pair is 12VDC, and the right pair is 5VDC with the metal jacket as ground for both. Good luck.
http://store.antec.com/Product/accessory-spare_parts/mx-1-power-adapter/0-76
1345-30290-6.aspx
Posted on Feb 03, 2011
Toshiba laptop adapter not working.should i go for a new original or is compatible duplicate safe
I will not recommend you to repair it, it's a sealed box, not worth it. Just buy another one. Always a 3rd party adapter will be more cost effective. Toshiba PA3215U-1ACA
Dec 09, 2011 | Toshiba AC Adapter/Power Supply Cord...
Tip
My dell pa 12 won?t start ?
When i start my dell pa 12up and it takes 10 mins to load to windows XP, , when the windowsloading screen comes up the FANS go crazy. I then wait till i’m at thedesktop at which point i immediately shut down the pa 12(which takes afurther 7 mins) while the FANs are going crazy.
answer :
Now if i start the pa 12 again it works normally.
I had to do this procedure everyday, untill today when i switched the pa 12 on, waited till the desktop appaered and i removed the battery while the pa 12 was on..
Now when i switch the pa 12 on it powers up but i’m not getting anything on the screen
First try a different AC adapter (such as :pa 10 ac adapter)
If no change then the issue is the motherboard. Often the AC adapter will fail then the battery discharges and you get the symptoms youdescribe.
SO AC adapter then MB
It shows no power on your laptop but it shows you the dvd player led comes on then off.
I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter (hp dv6000 ac adapter)tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If laptop AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
on Feb 09, 2010 | Computers & Internet
PA 21 adapter shows no sign of life. LED does not light up. No output voltage
Try another mains power cord. If this does not work then the PA-21adapter is faulty and needs to be replaced.
Jun 13, 2011 | Dell PA-21 Family AC Adapter For Dell...
Can I use the Antec MX-25 to transfer files from my PC (desktop)
The answer is yes and no. The Antec MX25 is just an enclosure for a hard drive, you will need to purchase a separate hard drive to put into the enclosure. Think of it like an empty box to hold the hard drive. Once you have it fitted out with a hard drive, you can then transfer files from your PC to the drive and then take them wherever you need.
The hard drive you will need will be a 2.5" SATA hard drive, up to a maximum 500GB in size.
Hope this helps.
Apr 13, 2011 | Antec MX25 25Inch SATA Hard Drive...
In an antec basiq BP 500u PSU does the molex connectors have the same voltage in each wire as the sata connectors
If you are looking to find out if you can power a SATA drive with an older power supply. The answer is yes. You can buy the adapter from sites like newegg.com and tigerdirect.com etc. They are about 5-10 dollars.
Hope this helps.
Zeppelinx12
Feb 27, 2011 | Antec Basiq BP500U (ASKU51402) 500-Watt...
I have a pc with an IDE hard drive which i want to change. the motherboard is M8V-MX Can i install a sata hard drive with this motherboard?
You will need a SATA PCI card to use a SATA drive. You can get one inexpensively on Amazon or E-bay.
An alternative is an IDE to SATA adapter which plugs into the primary IDE port on your motherboard. You can get these on E-Bay using "Buy it Now" for as little as $1.99 with free shipping if you are patient enough to wait for up to 2 weeks.
One are of caution (it happened to me with my first SATA drive) - not all drives are shipped with a power adapter for using a SATA drive with a non-SATA motherboard (they come with the data cable, but not all have the power adapter!), and they are difficult to find in a store. This is an adapter that converts from the standard drive power connector with red/yellow/black wires to a SATA power connector. Make sure your drive or adapter card comes with it, or order one on e-bay.
Feb 24, 2011 | ASUS K8V-MX Motherboard
Where do I find a driver antec mx-100 for vista
You dont need a driver for this encosure.
However if you have installed a fresh drive in there then the drive needs to be formmatted before use
Also dont connect to older usb 1.0 ports as most of these enclosures dont work well on the older speed USB ports.
You should be able to see and initalise the drive by going to CONTROL PANEL then ADMINISTRATIVE TOOLS then COMPUTER MANAGEMENT then DRIVE MANAGEMENT
Identify the drive and initalise it from there
Feb 23, 2011 | Antec MX100 Aluminum Hard Drive Enc ...
My dgx-220 ypg-225 yamaha keyboard is dead.
If you know how to use a multimeter then I suggest you measure the voltage from your wall adapter plug that you plug into the keyboard. If that has approx. 9Vdc, then take a look at d151 on the power supply board. See if it is passing voltage. Voltage should pass only 1 way. If you have voltage on one side but not the other then the diode it is open and needs replaced. You can find the diode designator on the board next to the diode.
Nov 11, 2008 | Yamaha Full-Size Keyboard
Computers & Internet Logo
3,349 people viewed this question
David Payne
David Payne
