Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
I have SimpleTech drive that I used Storage Sync to back up C drive. Took drive to work and since all the files are 'bpa' cannot open them. I compare this to a simulation of what I bought the drive for - in case my pc crashed - so I totally don't why these files can't be either converted/opened from another pc when the drive is in. Help!
  • 696 Answers
The BPA files are the backed up copies of your data. The simpletech utility backs up your files to compresse file ending in BPA. Any computer running the simpletech restore program can extract the data from these files.
You will simply need to install this software on a spare computer in order to test the backups. Frankly though I would just use windows backup to copy the files/folders you want to the drive raw as this can be read anywhere.
Hope this helps FixYa,
Chris
Posted on Sep 24, 2009
  • Kslerner3 Jul 15, 2011
    I too have this problem I installed storagesync 1.4 and tried to restore the files, but they will NOT restore. When trying to cancel the restore function the program says it will corrupt my files. GREAT! Any suggestion on how to get my files restored>>>
I have a Simpletech pininfarina 120gb external hard drive that I used to back up my computer.
did you purchase the storage sync program youmight not be able to download that version again unless you pay for it
if you can or want another free backup utility
save this to a document then click on it to open and download second back up free edition
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-2242_4-10405044&ontId=2242_4&lop=linktitle&ltype=dl_elite_gen&pid=10999341&mfgId=6272401&merId=6272401&ttag=lst-4&destUrl=http%3A%2F%2Fdownload.cnet.com%2FSecond-Backup-Free-Edition%2F3000-2242_4-10405044.html
hope this helps
Nov 12, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
My simpletech 500g hdd wont work and i took it to staples and they couldnt retrieve my files . please help
Does the hard drive get recognized by the computer? Your best bet and probably only bet would be to remove the hard drive inside from the external casing and plug it directly into a computer and see if you can retrieve any thing that way. One good program I know of is file scavenger. But the drive has to be working enough to actually work on a computer. Beyond that you would have to send it to a professional that deals with data recovery. I ALWAYS recommend that any important files be backed up. This means the files are saved in two different spots. So if one is lost or stops working you have the back up to use. Hence the name back up. If you need any further assistance let me know.
Thanks,
Lee
Feb 25, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
My simpletech, which is the 360GB model. It is plugged in to my laptop, but when I go looking for the drive it is not showing in my drectory. I going throught the process as if my computer is seach for the...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 12, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
I have mac book pro lap top it came with a simpletech 250 external drive. when i git the computer i back it up the the drive then couple of months later when i tried backing up my computer a again,...
* the USB cable
* the power-adapter
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 11, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
I have a SimpleTech Simple Drive Model 96300-40001-001 that was working fine but now there is flashing blue light and I can not access this drive
* the USB cable
* the power-adapter
Nov 10, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
I have an ibook g4 mac and a 160 gb simpletech hard drive. there are two lights showing in the hard drive- red and blue. how do i get the hard drive to register with my computer, and how do i save my music...
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 04, 2010 | SimpleTech 160GB USB 2.0 / FireWire...
I have a 250 gb simpletech external hard drive. no. 96200-41001-077. I have used it as the time machine backup on my MacBook. It stopped backing up time machine recently. I got the message. Backup failed...
> icon does not show up on the desktop or finder
A major "clue" that one component of the external storage device has failed, namely:
* USB cable (try a different one)
* optionally, the external power-supply that connects to the enclosure
Use a multi-meter to verify the voltage/amperage output of that power-supply.
(Not all external storage devices need such a power-supply.)
> can it be saved?
Partially. Disassemble the enclosure, and remove the disk-drive.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage-device. (Compare it to a heart-transplant -- same body, new heart.)
Nov 03, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Can not open the bpa files on my external simpletech drive
did you use special software or windows backup?? try to use the same software to restore your files. In windows you need to restore your files to special folder, you give it a name. then you open the folder and there you have your files.
Make sure you log on as the same user who backed up the files, of course one who has the right to restore the files.
Mar 22, 2009 | Dell Computers & Internet
Have the SimpleTech SimpleDrive External 400GB hard drive. When I click on StorageSync I get the message "Program is already running. Can't create process". Don't know what to do? Any help?
Go to task Manager > processes tab and find the StorageSync program and end process. Unplug the drive, shut down the PC, replug and start up the Pc and try again.
Oct 29, 2008 | Computers & Internet
PLEASE HELP
It is just like any other disc drive. You can set up folders to store your music. You can store music, files, videos, whatever you'd like.
It should be assigned a drive letter like d: e: or f: You can simply copy your music files to it.
Be more specific as to to how you are trying to use the Simpletech drive to store music.
Dec 07, 2007 | SimpleTech SimpleDrive 250GB, 7200RPM,...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
719 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
