Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
How do i fix the pullstart, including attaching to inner coil
  • 11,896 Answers
You can remove the cover and you will then be able to view the pulley and crank as well. You can pry up tabs on pullstart, rewind and replace.
Posted on Sep 23, 2009
I am looking for pullstart for Tivoli 60 hedge trimmer
Fixya does not sell replacement pullstarts.
Oct 27, 2016 | Garden
How do you fix a pull start
-Take the handle off the rope. You want to only have one knot in one end of the rope. (Of course, if the rope's already broken, you can skip this step ....)
-Get the reel and lay it facedown.
-Get the coil, and begin carefully winding it up so that it fits inside the grooved edge on the reel. BE PATIENT - this will take time.
-On the inside of the coil, there should be a little hook on the end of the coil. That hook matches one inside the pullstart cover when you put the two pieces together. The trick is to get the hook on the reel to catch the hook on the pullstart cover. CAREFULLY put the reel and coil inside the cover, and ***** the bolt in for a moment to hold it in place.
-Turn the pullstart reel clockwise until you feel the hooks catch each other. Feel some resistance? Good, that's what you want.
-Take the bolt back out, and reassemble the starter pawl assembly inside the pullstart, then put the bolt back in and tighten it.
You should now have a complete assembly, minus the pull rope. -Now, looking down into the pullstart, notice there is a hole in the reel off to one side. This is where your rope threads through. Grab the reel, and crank it around about .... four or five times, and try to get the hole in the reel lined up as close as possible with the outer hole in the pullstart cover. -Take your rope (you DID take the handle off first, right? Oh yeah, it broke off ...), and thread it through the reel, then through the outer hole in the cover. This will be a little tricky, as you need to be holding the reel so it doesn't unwind ...
-SLOWLY let the reel start to retract, but don't let it go all the way. Does it look like it's drawing the rope all the way back in? If so, great! If not, pull the rope back out, crank the reel around another turn, and try again.
-Once you have the reel set to where it will retract the rope all the way, thread on your handle and tie it off. You're done!
Apr 16, 2016 | Motorcycles
Rear window defroster has an attached coiled cord that attaches to inner back ceiling with a electrical component that's attached.
the end of the black coil will probably have a metal tab in it that was once attached to the back window.
Apr 05, 2016 | Cars & Trucks
2000 Sportsman 500. How do I reinstall spring on rewind start cord?
An easy way to fix a pull start recoil spring . - YouTube
? 8:48
https://www.youtube.com/watch?v=d4r8wbejHXY
Feb 19, 2013 - Uploaded by chaseme81871
Thank you so much! I was able to find the pull cord at a local home depot store and when when my husband ...
How to rewind a pullstart spring - YouTube
? 5:05
https://www.youtube.com/watch?v=qTcL3_3leTk
Mar 13, 2010 - Uploaded by lenniepincher
If you ever need to rewind a un coiled pullstart spring. ... ( NEW VERSION ) How to Rewind and Replace Recoil Starter Spring - Duration: 3:53.
Nov 24, 2015 | Polaris ATV
Its a pullstart engine starts no problem cold but when the engine is warm it will not start?
What type of engine, what type of machine, is the choke sticking on.
Sep 18, 2015 | Cars & Trucks
Ryobi chainsaw rcs4640n pullstart slips frequently
sounds like the gears on the pullstart mechanism is starting to get stripped there generally not expensive a small engine parts store can get it for you
Jul 28, 2014 | Ryobi Garden
Victor spitfire motor type lawnmowers pullstart. The pullstart is not working, its not the pullcord/spring return system that is the problem, it is not engaging anymore to the plywell well that it needs...
Either the pull string has un coupled or the little fingers that are part of the start assembly are not engaging the motor. If latter, you need new start assembly. Ouch.
Aug 29, 2017 | Garden
How do I replace the starter pull rope on TB70SS?
You must first remove the shaft assembly by removing the Torx/Flathead screws that hold on the trigger. Then you remove 3 screws that hold the engine to the shaft. Next you can remove the shaft assembly and you will see 4 or so screws holding the black surround around the clutch. You need to remove this to get to the pullstarter. Once you get to the pullstarter make sure not to release the coiled spring or you'll have a hell of a time putting it back in. Typically that are behind the pullstarter assembly.
Aug 15, 2010 | Troy Bilt Tb70ss Gas Trimmer
Pullstart jamed removed putstart rope no problem
If after removing the starter the starter pulls easily but you can not turn the flywheel the engine is probably seized. Could be a piston failure or a bearing failure. check to be sure nothing is caught under the flywheel binding it up.
Jan 14, 2010 | Echo Garden
My recoil inside the pullstart
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Jun 08, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
87 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
