Question about Janome Memory Craft 9500 Computerized Sewing Machine
Needle threader out of line where to get replacement part? memory craft 9500 janome sewingmachine
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
Touch screen for MC9000
This Replacement LCD Touchscreen is suitable for your Janome Memory Craft MC9000
Janome Memory Craft MC9000 Replacement LCD Touchscreen
Mar 15, 2012 | Janome Memory Craft 9000 Computerized...
After I broke a needle the threader won't thread the new needle. Does it only work with Janome needles or is something out of alignment?
Threaders only work with certain combinations of needle and threads. Too small an eye or too big a thread and its a no go. The book should give an idea of the combos you can do. Make sure the needle is inserted completerly up inside that needle clamp.
Jan 17, 2011 | Janome Memory Craft 9000 Computerized...
I am having difficulty using the needle threader with my new Janome 3160. There does not seem to be anything to push the thread through. Help!
It had the same problem with my new Singer and I called them, they sent me a new threader, no charge. Just call Janome, I am sure that they will send you one.
Aug 15, 2010 | Janome Memory Craft 3000
Needle threader for the Janome won't drop down.
It seems light your needle thread motor is not working. It will be hard to help you online unfortunately
Jan 19, 2010 | Janome Memory Craft 10000
My Janome Memory Craft 4800 is skipping stitches. I've cleaned the bobbin race, replaced the needle and re-threaded both top and bobbin. Any suggestions? it also feels as if the thread is getting caught on...
Here are some things to check.
* Thread tension is too tight.
* Needle is bent or blunt.
* Needle is wrong size.
* Needle and thread does not match.
* Light pressure on presser foot.
* Incorrect setting of needle.
I hope this helps you.
Sep 18, 2009 | Janome Memory Craft 4800QC
Janome MC 10001 auto. needle threader stuck in up position.
You are threading the top of the machine incorrectly.
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem, please respond.
Feb 12, 2009 | Janome Memory Craft 9000 Computerized...
Janome Memory Craft 9500 Troubleshooting
Have you tried a new needle?
If re-threading, changing the brand of thread, etc. does not work, then it's likely your machine is out of time. Search for sewing machine timing or take it for service.
May 24, 2017 | Janome Memory Craft 9500 Computerized...
Needle Threader is not lined up
This is called the Needle Threader Plate.
If this is too small for you to read, or you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Dec 08, 2007 | Janome Memory Craft 4000 Sewing Machine
Janome Memory Craft 9500 Computerized Sewing Machine Logo
176 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
