I have a VSX-35TX receiver. When I turn on power,the receiver turns itself right off. Yesterday, the receiver would stay on for a few minutes after I turned it on.
  • meipengelain Sep 24, 2009
    As smarthome 2 suggested, from the back of my receiver, I disconnected the wires to all my speakers, and to the subwoofer. The receiver still just clicks without turning on.
    President:
  • 1,114 Answers
Disconnect all your speaker wires at the receiver then turn it back on. If it stays on, your receiver is ok and you need to re-connect each speaker wire and test power. You will either find the fault or fix the problem. If you need further help troubleshooting, post a comment and I will help some more. Hope this helps
Posted on Sep 23, 2009
Testimonial: "Thank you very much for your useful suggestions."
  • Frank Fulton
    Frank Fulton Sep 24, 2009
    After disconnecting all your speakers and still having the receiver shut down, you will have to get it serviced. While it's being serviced, you should meter out all your wires and make sure you do not have a short, if you drop a couple hundred on the repair it's worth a couple hours of your time to double check everything so it does not happen again. Secondly, if you do not have a "Line Conditioning" Surge protector, get one! Panamax, Furman, or Monster. Can save you lots of green and frustration! Hope this helps
Pioneer vsx 405 overloading whenever it turns on I checked the speaker wires and they are all OK.
vsx405 came error dc protection chacked all power transistors c2500 ,a1948 all ok i was disconnect dc detector wire then ok after few minutes one pair burned with c945100 ohms resistors that time not fix heat sink then all replaced power on error overload with speaker and without speakers also coming error disconnect ol wire no chang pease help any expert amplifiers thanks
Oct 27, 2011 | Pioneer VSX-405 Receiver
My power went out while watching TV. Now there is no sound when I turn my receiver to TV/SAT. If I put the receiver on CD there is sound but no picture. The receiver works fine if I go to DVD; there is...
It would seem the TV/SAT source is where the problem lies. No picture with CD? Really?
How about bypassing the receiver to prove what is failing?
Apr 21, 2011 | Pioneer VSX-35TX Receiver
Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Dec 10, 2009 | Pioneer VSX-72TXV Receiver
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Pioneer VSX-45TX turning itself off
check all speakers and wire not short... you can try open each speaker testing....
Nov 12, 2009 | Pioneer VSX-45TX 7.1 Channels Receiver
Pioneer VSX-35TX , "Power Off Message" , will not stay on.
It's probably going to need output transistors and some resistors, it's a job for a technician. A rough estimate on price is $100 to $130 (that's parts and labor). Before the smoke it may have only needed repair of bad connections.
Mar 08, 2009 | Pioneer VSX-35TX Receiver
I turn on receiver Pioneer vsx d608, then few seconds later screen flashes "poweroff", then shuts off by itself
Check all speaker wiring for shorts. If nothing is found, unit obviously has circuit problems, have serviced.
Jul 31, 2008 | Pioneer VSX-D608 Receiver
Sreen says amp error
The audio Amplfier IC are damaged.
May 22, 2008 | Pioneer Audio Players & Recorders
I have a Pioneer VSX-35TX receiver when connected to the subwoofer there is no sound questions on what I am doing wrong.
Set front speakers for small and make sure sub is turned on in setup mode. If Front speakers are sent to large I believe the only time sub will work is with Dolby Digital Lfe signals. If sub is turned off of course it will never work.
Feb 10, 2008 | Audio Players & Recorders
121 people viewed this question
 Grubhead
Grubhead
