Climatronic does not work in my 96 golf vr6 can
I have had the full control panel out of the car and checked the connections and it still doesn't work, thought it might be a fuse but can't seem to find it, it says in the manual that there are fuse above the relays in the fuse board but I can't see them, can you help please. Richard
  • 11,896 Answers
The relays are above the fuse box. You can test them with an ohmmeter. and check power in the wiring with a test light. If fuses are good, the control itself may be bad. You can test pressure in the vacuum hose with a vacuum pressure tester.
Posted on Sep 23, 2009
Ac on 2001 vw golf tdi 1.9 blows hot air was working but stopped blowing cold air has freon and compressor clutch is good
Your motor for the temp door may not be working. It is all the way under the dash, toward the back, may be able to reach it and put your hand on it from under the driver-side foot well- but with the windows up so you can hear, listen to hear if the motor runs when operating the temp from cold to hot. If you have Climatronic, take a deep look at Climatronic blend door motor. The Climatronic is a fully controlled system. You absolutely need to use a scan tool to access the diagnostics and code memory. You may just need to clear the DTCs for compressor operation. Also, these are known for temp sensor problems causing no compressor operation. You pressure readings to indicate the clutch is not engaging. If you do need to replace your ac compressor this site looks like it has cheap prices, free shipping and great reviews http://www.buyautoparts.com/autoparts/Volkswagen/Golf/A-C_Compressor.html
Jun 19, 2013 | Cars & Trucks
1998 golf gti vr6 power sunroof doesn't close when i turn key at the door
Check your wires and fuses, I am having a similar problem myself as the windows open, but not the sunroof and this is a feature that VW had on most of these models with power locks, even my 96 Gti did it. I will repost with what fixed it ASAP.
Mar 24, 2012 | Volkswagen Cars & Trucks
Colors of wires of MAF sensor in 2001 VW golf gti vr6
2001 VW Golf GTi VR6
On the MAF sensor connecting plug you will see 5 pin numbers. Each pin number correspond to a wire color:
Pin no.# 1 = violet/green, is comming from pin no.# 26 of ECM. ECM = Engine Control Module.
Pin no.# 2 = blue/yellow, is comming from fuse no.# 43 = 10 Amp. (battery plus is comming through a blue wire from pin no.# 23 of fuel pump relay).
Pin no.# 3 = green, is comming from pin no.# 27 of ECM.
Pin no.# 4 = red/violet, is comming from pin no.# 53 of ECM.
Pin no.# 5 = black, is comming from pin no.# 29 of ECM.
Wiring diagram:
Feb 10, 2012 | Cars & Trucks
Hello, I have 2 problems with my son's '01 GTI VR6
You have to sensors one on the motor and one on radiator they could be faulty the other is a faulty relay check to find out where they are located in fuse box with the ignition on but car NOT started take out the relay then put it back in a noticeable click will be heard this is the relay activating and is ok The relays may be located under the dash or in engine compartment
Apr 01, 2017 | 2001 Volkswagen GTI
93 Golf VR6, headlight high and low beams are very
Did you check battery charge.Must be 13.8 v-14.4v.Or your battery is gone.
May 12, 2010 | Cars & Trucks
I need a wiring diagram for a 96 vw golf gti vr6 ignition switch
http://www.the12volt.com/installbay/alarmdetail/2180.html
Apr 06, 2010 | 1996 Volkswagen GTI
Vr6 does not want to idle
Turn down idler controller
Apr 06, 2009 | 1996 Volkswagen Golf
MK3 GOLR VR6
Your cable from the battery needs to be in great shape. If this happens mostly when the weather is very hot, it is quite likely the cause.
Jul 21, 2008 | 1994 Volkswagen Golf
2003 Volkswagen Golf Problem
it should be number 42
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).
Jul 09, 2008 | 2003 Volkswagen Golf
Heating & Cooling Logo
314 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
