Question about LG Vu CU920 Cellular Phone
How can I change the lock system to remain on?
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
1992 corvette loses spark after 20 min of running
Vapor lock can affect any kind of engine during normal operation where the outside ambient temperature remains high, or the fuel system becomes overheated because of high engine temperatures or lack of insulation. Fuels that have high volatility can also cause vapor lock. When fuel boils inside a metal line or carburetor, it vaporizes, which causes a halt of the fuel delivery. This condition can cause an engine to stall or refuse to restart, even with a perfectly running engine. Preventing vapor lock requires some observation of the existing fuel delivery system, along with some modifications.
Read more: How to Prevent a Fuel Vapor Lock ' eHow.com http://www.ehow.com/how_8182993_prevent-fuel-vapor-lock.html#ixzz2PewBlpYz
Apr 05, 2013 | Spark Plugs BR4HS Plug 10/BX #3322
My fiancee has locked her laptop DVD system to region 3 and wants to change this back to Region 2 Please
"PROCESS IN WIN XP"
To Change the DVD SYSTEM Region open MY COMPUTER-- RIGHT CLICK TO THE DVD DRIVE ICON -- CLICK ON PROPERTIES--CLICK ON HARDWARE--HERE AGAIN SELECT THE DRIVE WHICH YOU YOU WANT TO CHANGE THE REGION AND CLICK PROPERTIES--- NOW CLICK ON DVD REGION --In this page you'll find many country name so now select yours country and click ok.
CAUTION: YOU CAN CHANGE THE REGION A LIMITED NUMBER OF TIMES. AFTER CHANGES REMAINING REACHES TO ZERO, YOU CANNOT CHANGE THE REGION EVEN IF YOU REINSTALL WINDOWS OR MOVE YOUR DVD TO DIFFERENT COMPUTER. MAXIMUM CHANGES CHANCE ARE 5 TIMES.
Jul 12, 2011 | Computers & Internet
ABS issues
Take it back to the mechanic who repaired it and, this time, tell him to FIX it. I don't know which trouble codes he found in the system, but a wheel speed sensor wouldn't cause the brake pedal to lock up! -- this is much more serious --- HECU or Master Cylinder.
Sep 04, 2009 | 2002 Hyundai XG350
How do you turn off the oil change light after the oil has been changed?
GM Oil Life System This system calculates the estimated percentage of the engine oil�s remaining useful life and alerts you through the DIC when it�s time to change the oil by displaying CHANGE OIL. Please remember to always reset the oil life system after an oil change.
Reset the oil life system Press and hold the control stem for more than two seconds while OIL LIFE is displayed. When completed, the system will reset and a beep will sound.
Good Luck and Remember.
Change Your Mind, Not Your Oil.
Use the First In Synthetic Motor Oil's.
See My Bio For Information & Contact Details.
Nice, but doesn't work for my 2006 Silverado. My manual says:
1. Turn ignition key to RUN with engine off.
2. Fully press and release the accelerator pedal 3 times within 5 seconds.
If the OIL LIFE RESET message flashes for 10 seconds, the system is resetting.
3. Turn the key to LOCK.
Aug 14, 2009 | 2006 GMC Canyon
Door lock 1998 Altima
you need to change the main drivers side central locking door lock and it should fix your problem
Dec 31, 2008 | 1998 Nissan Altima
My camera on my sony ericsson w580i does not work any help please to fix it myslf
You can add flash menus, change camera driver, change acoustics, add languages with FSX
You can upload stuff to phone either with own_custpack method or via FSX
Rest all remain same. Here is a list a of directories with information. Download the stuff and upload them
ifs/settings/acoustic/ >> Acoustics file
ifs/settings/camera/ >> Camera driver
ifs/settings/display/ >> Display driver
tpa/preset/system/desktop/flash >> flash menus
tpa/system/layout/ >> layout.xml
tpa/system/system/mutlitmedia/mp/skin >> Walkman 2 skins
tpa/system/preset/multimedia/pe >> frames , clipart etc
tpa/system/preset/multimedia/av >> visualizations
tpa/user >> stock pics and themes…
pa/preset/system/settings >> startup and shutdown screens ! all are GIF but with no extension tpa/preset/system/sound >> all sound files
tpa/preset/system/menu >> the famous menu.ml
tpa/preset/system/fonts >> fonts !
/usb/audio >> locked music (can be deleted with FSX only but not with phone)
/tpa/user/audio/ locked music
/tpa/preset/default/audio/ locked music
/USB/IMAGE >> locked images.. can be deleted
/tpa/user/image/ >> locked images
/tpa/prest/default/image/ locked images
;Locked Themes -> /USB/THEME
;Locked Themes -> /TPA/USER/THEME
;Locked Themes -> /TPA/PRESET/DEFAULT/THEMECheck out the FS for more directories and locations icon_wink.gifPlease check out the customization of phone tutorial for more. You can use either own_custpack method or FAR MANAGe
thanks rate it................
Sep 11, 2008 | Ericsson Cell Phones
LG Vu CU920 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
