Question about Avid Juicy Ultimate Hydraulic Disc Brake , 160mm, Front
Brakes have lost all power after changing the pads
    Sergeant:
  • 246 Answers
Pads and rotors wear together. if you dont replace the rotor along with the pads, the pads wont have complete contact the rotor and will not have the stopping power they should.
Posted on Feb 17, 2010
I just changed out a bad coupler, and now have squeaking and smoke coming from my Kenmore 90 series washer
It sounds like something is hanging up on the transmission. That may be what caused the coupler to go bad. Look at the brake assembly to see if it is tied up. If you see any black dust or particles, I would replace the brake pads and the clutch assembly. Here are the brake pads to order.
Here is the clutch assembly to order.
Regards,
Richard Roth
http://appliancecafe.com
Nov 12, 2012 | Kenmore Washing Machines
I keep getting the "Brake Fault" error, but the
have you checked your brake pads? lost of vw, not all of them, have a sensor on the brake pads that let you know that its time to change them. hope this helps
Jun 11, 2011 | 2000 Volkswagen Passat 4Motion
Brake trouble Grinding sound
sounds like it is time to replace the brake pads. i would do it quickly before you ruin the rotors.
Apr 06, 2011 | 2005 Mitsubishi Lancer
Just changed front brake pads and still feels like brakes go to the floor. What is wrong?
check that fluid level is ok, by changing pad and opening calipers you may have lost fluid our of resovoir.
if your discs where not changed or skimmed at the same time you will have ridges, that do not match to the smooth pads, when you drive for a few miles eventually the pads will wear down and form the shape of the discs.
if they continue to be soft, bleed the fluid to make sure there is no air in it, if the brakes are still soft after this you should replace the brake fluid completely if it has not been done for a while as brake fluids absorbes moisture and that makes the brakes feel spongy or soft.
i hope this was useful.
Jan 23, 2011 | 1998 Toyota Corolla
No brakes I think the booster was going out because my peddle got soft but would still stop me then i changed my brake pads shortly after the brakes completly went out and can now only stop with the...
The problem is not the booster, the job of the booster is to make braking easier. If the booster went out the brakes would be hard to press.
Your soft pedal is likely due to air in the brake lines. Bleed the brakes and go from there.
Dec 13, 2010 | 1992 Buick Park Avenue
My 2003 ml350 petrol needs the brake pads replaced but ever since the brake inication light has started coming on it has had trouble starting I was wondering if somehow theses could be related
IF YOU OPEN BRAKE LINE ON BRAKE CALIPER WHILE CHANGING BRAKE PADS IT WILL CAUSE BRAKE FLUID LOST CAUSING AIR IN BRAKE SYSTEM IN WHICH BRAKE LIGHT WILL COME ON.YOU NEED TO BLEED BRAKES.
Nov 08, 2010 | Mercedes-Benz ML350 Cars & Trucks
2006 grand vitara brake lights comes on when accelerating from stop
check under your steering column brake switch has to be loose and when you push the gas pedal something in that area is touching the brake switch causing lights to come on.
Jan 17, 2010 | 2006 Suzuki Grand Vitara
How to change rear brake pads for a honda 2007 ridgeline
The 2007 Honda Accord is equipped with four wheel disk brakes. Disk brakes wear down and require regular maintenance. Worn brake pads can cause squeeling and grinding noises, as well as reduced braking power. Improperly maintained brake pads can cause damage to the brake rotors as well as brake failure. Save on labor costs by replacing your own brake pads.www.lightdeal.co.uk
Jan 07, 2010 | 2007 Honda Ridgeline
Hi just caanged my brake pads all round and ive
try pumping teh brake pedal and pulling the handbrake at the same tim to work the auto adjusters
Nov 25, 2009 | 2000 Jaguar S-Type
94 geo prizm
1- Verify the procedure of bleeding.
2- Probably you have to run the car even than the faces of the rotor and the pads mold.
Jul 21, 2008 | 1994 Geo Metro
Avid Juicy Ultimate Hydraulic Disc Brake , 160mm, Front Logo
298 people viewed this question
Top Avid Cycling Experts
Michial Gueffroy
John Egan
John Egan
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you an Avid Cycling Expert? Answer questions, earn points and help others
