Question about Freezers
I need to know which circuit to install for my freezer The description I have is imperial commercial manaual defrost freezer 20.7 Cu Ft.
  • Dennis Boxerman May 11, 2010
    are you asking for what the amperage should be? Not real sure of your question.
    President:
  • Freezers Master
  • 1,922 Answers
Put it on a dedicated circuit(meaning only item on this breaker) with a minimum of 20 amps @ 120 volts
Posted on Oct 05, 2009
Our old Imperial heavy duty commercial model uf20x needs seal. Where to find it?
Commercial refrigerator parts supplier can make it same day. Check google for your nearest supplier.
Feb 01, 2014 | True 72 cu. ft. / 2039 liter Commercial...
Fan didnot work bat the fan its good
Uses a fan delay switch. Temperature of coil has to be around 20*F. before fan can come on.
This usually happens when defrost problems occur.
Oct 24, 2010 | True 52 cu. ft. / 1472 liter Commercial...
20 cu. ft. / 566 liter Commercial Freezer J1GF-20S: We are trying to use this product to keep ice crea...
if it freezes you and get a new defrost timer with a wire on it and it will have diff times on it
May 06, 2010 | Coldtech 20 cu. ft. / 566 liter Commercial...
Defrost times and adjust
http://www.turboairinc.com/TB-Service/Service%20Manual%20%20-%20April%202008/TSF-49SD.pdf
go to this site and check out the service manual. I guessed at the unit you had as you did not include the model number.
You can also go to turboairinc.com and search for more info if you need to.
Hope this gets you your answer.
Apr 15, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
I have lost my turnkey for an Imperial Upright heavy duty Commercial Freezer. It is locked and I have no way of getting inside... Where can I get one?
you can visit the website of the company and make a request for the key or get the door forced it to get open and get a new locker key for it.
Feb 16, 2010 | Amana 19.7 cu. ft. / 558 liter Upright...
Unit will not go into defrost.
There is a good chance, if the defrost timer is mechanical, that you can rotate (nudge) the timer to see if it get's going.
Most commercial refrigeration does not use a defrost thermostat, and a lot of it does not use a heater (they use a hot gas bypass valve and pump hot gas through the evaporator, rather than through the condensor.).
Let me know if you need further help.
Feb 04, 2009 | Turbo Air 49 cu. ft. / 1388 liter...
Defrost mode
typical defrost set up 8 times a day (24hrs)
duration about 20mins for the size you have described.
defrost stop temp should be 20 C
recovery time about 10 mins
so pls consult manuals and rest parameters.
Feb 23, 2008 | Hoshizaki 18.8 cu. ft. Commercial Freezer...
Freezers Logo
121 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
