Question about Samsung Eternity Cell Phone
When I turn my enternity on it says phone lock how do i get that
When powered on it goes to the screen that says phone lock
I screenlocked myself out of my LG optimus dynamic ii phone how do I getin to it
http://img-tf.deviceanywhere.com/tracfone/pub/252610/docs/L39C%20English%20UG.pdf
Locking and unlocking the screen If you do not use the phone for a while, the screen will be automatically turned off and locked. This helps to prevent accidental taps and saves battery power. When you are not using your phone, press the Power/Lock Key to lock your phone. If there are any programs running when you lock your screen, they may be still running in Lock mode. It is recommended that you exit all programs before entering Lock mode to avoid unnecessary charges (e.g. phone calls, web access and data communications). To wake up your phone, press the Power/Lock Key . The Lock screen will appear. Touch and slide the Lock screen in any direction to unlock the screen. The last screen you viewed will open.
Mar 01, 2015 | Tracfone Wireless LG Optimus Dynamic II -...
My lg306g phone's back light goes off after 15 seconds, even though I have it set for 60 seconds.
full factor restore your phone after backing up your phone numbers....this should work......if still problem persists then get your phone flashed.....i.e. get software reloaded
Nov 29, 2014 | Cell Phones
Iphone 5s is locked and disabled and stuck on connect to itunes
Dear Sorta,
Please follow below instruction:
Turn it off by holding home+ power button untill the screen goes black ( as soon as it goes black, release the buttons).. This might take some practice , so dont worry if on the first try your phone reboots and goes to itunes screen again.
Now, with your phone powered off, enter DFU mode:
Method 1)
  • Attach the phone to the pc
  • Turn the phone off
  • Hold power and home together for *exactly* 10 seconds
  • Release power but keep holding home until the pc beeps as a USB device is recognized.
Whilist in dfu mode, itunes will recognize the device and it will ask you if you wish to restore it. Simply click restore, and the restoring proces will begin.
This will hopefully fix your iphone.
Cheers
Jul 25, 2014 | Apple iPhone 5
Why wont my main screen show
I will need to know what model phone that you are currently using before I am able to provide any furth assistance.
Until you provide your phones model, I will give you two basic reboot processes for most non-smartphones and smartphones.
1. You may attempt to reboot the phone simply by pressing and holding the lock screen/power button.
2. You may attempt to reboot the phone by removing the battery (if easily accessible) and counting down from 10 and re-inserting the battery.
3. For iPhones, you may attempt the reboot process by pressing , and holding the lock screen/power button, and the home button until the screen becomes black and the device goes Into the reboot process.
4. Lastly, for some smart phones you may power the device off by pressing and holding both the volume UP and the lock screen until the screen becomes black and the device enters the reboot process.
If none of these work, please leave specify the model of your cellphone device and I will provide further assistance and advice. Thank you
-Seth
May 17, 2014 | Cell Phones
How to work my touch screen on my jelly bean 4.1 10in
Android 4.1 (Jelly Bean) your device now has several different lock options available.
To access your lock options, touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> > > Security & Screen Lock.
Screen Lock Options
  • Slide - provides no protection, but lets you get to the Home screen quickly, or open Camera and start taking pictures immediately.
  • Face Unlock - lets you unlock your phone by looking at it. This is the least secure lock option.
  • Pattern - lets you draw a simple pattern with your finger to unlock the phone. This is slightly more secure than Face Unlock.
  • PIN - requires four or more numbers. Longer PINs tend to be more secure.
  • Password - requires four or more letters or numbers. This is the most secure option, as long as you create a strong password.
The Lock Screen on Android 4.1 (Jelly Bean) uses two timers. The first timer is the "Sleep" timer which turns off the device display to extend battery life. You can turn the display on and swipe to unlock. The second timer called the "Automatic lock" timer turns on security features like pin, pattern, password or face unlock and protects the device from unknown users. This"Automatic lock" timer begins after the "Sleep" timer expires and you will be asked to enter personally recognizable data like pin, pattern, password or the face unlock when the display is powered on.
Note: The Automatic lock option will only show after a screen lock option (other than Slide) has been set.
To adjust the "Automatically lock" timer go to Settings > Security & Screen Lock > Automatically lock > Select desired time frame.
To adjust the "Sleep" setting go to Settings > Display > Sleep > Select desired time frame
If you are using facial recognition and do not want the "slide to unlock" to appear, set the "Automatic lock" timer to "5 seconds".
Power button instantly locks
There is an option in Android 4.1 (Jelly Bean) which will automatically lock the device when the display is on and the power button is pressed. As soon as the power button is pressed your device will lock.
Note: The Power button instantly locks option will only show after a screen lock option (other than Slide) has been set.
To activate the "Power button instantly locks" setting, go to Settings > Security & Screen Lock > check the Power button instantly locks checkbox.
It is important to note your phone may contain security policies set by your IT administrator which may override any settings you attempt to set under screen security. For example, if you set your phone to automatically lock for 30 minutes and phone locks after 10 minutes, it may be due to security policies set by your IT Administrator. Please contact your IT Admin for more information.
For more information on using your new lock features select one of the quick links below:
Lock and unlock basics
Set screen lock
Respond to incoming calls
Face unlock is grayed out
To unlock the screen, press the Power key, then touch [img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics06.png">and flick to .
[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics01.png">
To add a message to the lock screen:
1. From the home screen, touch Menu [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/JB/razr-menu.png" width="34" height="23">>
2. Touch Security & Screen Lock > Owner info and type your message.
Set screen lock
Depending how you use your phone, you may want to set some form of automatic screen lock to prevent unauthorized access. If a screen lock has been set, the screen locks when your phone's display goes to sleep. It is important to note your phone may contain security policies set by your IT administrator which may override any setting you attempt to set under screen security
Before setting a screen lock it is important to note that you will need your Gmail / Google Account credentials to reset any security lock, so please do not set a security lock on your device without first setting up a valid Gmail/Google Account you can remember and access.
To adjust your phone's lock settings:
1. From the Home screen touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> >
2. Touch Security & Screen Lock > Screen lock.
3. Touch the type of lock you want and follow the onscreen instructions.
If you have previously set a lock, you must enter the pattern, PIN, or password to unlock the lock settings.
4. You can choose among these lock options, listed in approximate order of strength: Slide, Face Unlock, Pattern, Pin, and Password
After you set a lock here, a lock screen displays whenever your screen wakes up, requesting the pattern, PIN, or other specified key
Respond to incoming Calls
While the screen is locked, you can respond to incoming calls in three ways.
  1. To answer a call, touch[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/icsphoneicon.png">and flick to .
  2. and flick to .
  3. and flick to . Select a message to immediately send it.
    Tip: To silence an incoming call alert, press the Power key or the volume keys.
Face unlock may be grayed out due to security policies set by your IT administrator which may override any setting you attempt to set under screen security. Contact your IT admin for more information.
Was this answer helpful?
YesNo
Sep 13, 2013 | Computers & Internet
How can i delete My enternal Ext- no
try youtube ive done it its easy hold menu button and power button while plugged to computer in itunes it will reset it
Jun 12, 2013 | Panasonic KX-T7730 Corded Phone
Screen do not wakeup
factory reset should fix it
May 20, 2013 | HTC Desire A8183 Cell Phone
Htc one x plus is stuck on the white htc quitely briliant screen
hold the power button down all the way until the screen goes black. then reboot it it should solve the promblem
Mar 16, 2013 | Cell Phones
Zte z990 at&t pre-pay phone wont power up
1.Power off the phone.
2.Press and hold "Vol+", "Menu", and "Power" key until the phone goes to recovery mode.
3.Use "Vol+" and "Vol-" to move the cursor up and down.
4.Move cursor to "wipe data/factory reset", press "Back" key to select it.
5.Now move cursor down to "Yes - delete all user data" and press "Back" to select it.
6.The data will be erased.
7.The cursor will be on "reboot system now" at the end, so just press "Back" key to reboot the phone normally.
WARNING: All user data will be completely cleared; the phone will be in a factory reset status.
Dec 26, 2012 | ZTE Z990 Avail At&t Black Android Touch...
I put a new password lock on my phone ( HTC desire ) when drunk and have now forgotten it
If you have forgotten the screen unlock pattern, you have up to five attempts to try and unlock your phone. If this fails, you can unlock your phone by entering your Google Account user name and password.
  1. On the unlock screen, attempt to enter your unlock pattern five times.
  2. When prompted to wait for 30 seconds, tap OK.
  3. If the display goes off, press the POWER button to turn the display back on, and then press the bar on the lock screen and slide your finger down to unlock the screen.
  4. Tap the Forgot Pattern button in the lower right corner when it appears.
  5. Enter your Google Account name and password, and then tap Sign in.
Jun 17, 2011 | HTC Desire Cell Phone
Samsung Eternity  Cell Phone Logo
29 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
