Question about Dometic RM2852 Refrigerator
I HAVE A 1997 FLEETWOOD RV WITH ORIGINAL DOMETIC RM2852 REF IN IT. ALL POWER SEAMS TO WORK (LIGHTS ARE ON PLUGED IN OR OFF OF GAS BUT THE WHOLE PROBLEM IS THE REF OR FREEZER WILL NOT GET COLD
  • 332 Answers
Largest problem is with the cooling unit going bad on these unit at about your units age.
But first
check your 12 volt fuses and make sure both the fuses in the back of the refer and the fuse in the power distribution panel are good
Must have 12 volt for the gas to work
Posted on Mar 05, 2010
Dometic Americana RM2852 refrigerator does not work. Has power to it, light inside works and lights at top indicating 'AUTO' mode are illuminated, but refrig doesn't work in any mode. Gas is...
Have the same unit but experience no problems. Sounds like a freon leak has left it inert. You can of course switch from auto to gas and eliminate the auto switch over as part of the problem. You can see the gas flame in the outside access hatch, (or maybe hear it) to be sure it is getting gas. since it doesn't respond in auto, which would also work in electric mode, I think it is the freon problem.
May 11, 2011 | Dometic RM2852 Refrigerator
My dometic fridge will not turn on
Check to see if you have a switch for storage, on, off etc. usually between doors, or near top right corner of fridge compartment. It may be in wrong position.
May 14, 2010 | Dometic RM2852 Refrigerator
Ref/freezer quit working. looks like somekind of liquid in back leaked out.. fuses ok.is this repairable? motorhome Domestic RM2852
motorhome refrigerators are a different system entirely than residential style refrigerators. I would do a search for dometic, not domestic, refrigerator repair
Feb 07, 2010 | Dometic RM2852 Refrigerator
I have a rv with the Dometic RM2852 refridg. It works fine on gas, but when I switch to AC input the gas turns off like normally should but the refridg does not cool. The Auto light is on, 120VAC is OK at...
First thing to check is that the control switches are in the proper position, since some RV fridges require a particular placement for the fridge to operate on different power souces.
Check your owner's manual for troubleshooting steps for your specific fridge, beyond that, here's link to a site that provides a step-by-step troubleshooting guide complete with active links for each potential issue.
http://gasrefrigeration.net/works_on_gas_but_does_not_work_o.htm
Here's a copy of the manual for your fridge model that you can download and print for free, just in case you don't have yours handy.
http://gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Hope you found this very helpful and best regards!
Aug 08, 2009 | Dometic Refrigerators
Royale rv fridge lights on gas then goes out
clean burner assembly with compesseed air if no fix replace electrode the spark thingy as most women say to me lol 33.50 most dealers
Jun 08, 2009 | Dometic RM2852 Refrigerator
Rm2807 rv refrigerator gas works but the a/c is not working
Check the 110 volt wire for flaws. Take a volt meter and check the recep that the fridge plugs into for power, should be 110 volts or so. +/- 10%. If you have power at the recep problem is in the fridge chord or circuit board fuse or circuit board. Also check the 110 volt breaker in the coach at the service panel.
Mar 29, 2009 | Dometic RM2852 Refrigerator
Dometic RM2652 or RM2852 not working.
There is a factory recall on these refrigerators. Call Dometic 1800-544-4881 and give them your serial number and model number. Going through the same thing right now. On my Fleetwood Gearbox. Hope that helps. Robert
Sep 08, 2008 | Dometic RM2652 Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
Dometic RM2852 Refrigerator Logo
383 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
