Question about Epson ACULASER CX11NF All-In-One Printer
Error code: Paper Set MP LGL - Epson ACULASER CX11NF All-In-One Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark T630 error message: Change MP Feeder
use the right arrow go to paper menu scroll to the right to paper source select if it is set to mp tray reset it to tray one. if its set to tray 1. check the side of the paper drawer to make sure the paper size snap in plate is in place. if these things are good replace the paper size selection pcb located in behind the logic pack
Sep 15, 2009 | Lexmark T630 Laser Printer
Showing change paper size when select LGL size paper in canon ir2016
If you are selecting legal on the screen to copy, then be sure that you have legal paper in the tray for printing and that any tray guides are properly set to reflect this.
Jul 22, 2009 | Canon Office Equipment & Supplies
Jamming halfway thru fuser
WHAT IS THE JAM / ERROR CODE
ARE THE PAPER TRAYS REGISTERING THE CORRECT PAPER SZ. LTR OR LTR R LGL LEDGER ECT...
Jan 27, 2009 | Minolta CF2001 Copier
IR 5000-6000 LGL TO A4 PROBLEM
What country are you from ???? here in the US we do not use A4.
Only Legal Letter, check the size of the paper you are using and check the trays to make sure it is set correctly.
Oct 11, 2008 | Office Equipment & Supplies
Paper sizing error
Solution #2 WORKS! Just when you use the #clear option.. select "ALL" it will reset everything but all you have to do is simply re set the paper size to letter as it seems to default to A4 size once it re-initializes. What a nightmare this was..
Jun 29, 2007 | Canon imageCLASS MF5750 All-In-One Laser...
Sending and receiving faxes on legal size paper.
There should not be a problem with TX on LGL paper. If you want to configure the machine to recieve LGL on a regular basis: Press "MENU" 1-3. Then use the up/down arrows to select LGL. "MENU", "EXIT". That should do it. Good luck!
Apr 20, 2007 | Brother IntelliFax-2820 Laser Fax
Epson ACULASER CX11NF All-In-One Printer Logo
41 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
