Question about Panasonic TH-42PZ700U 42 in. Plasma Television
While watching the TV, the picture goes black and can stay that way for long periods of time with no warning or pattern. This is not a power issue, as the TV is still powered on I still have volume the whole time. The red light does not blink, it stays on. Everything works fine except for the picture blackout. I've had the TV almost two years now and had to deal with this problem for over 6 months off and on. It doesn't always happen but it does happen roughly 90% of the time while watching TV. Any ideas?
  • wrightm328 Sep 27, 2009
    Thank you for providing a response. Are changing the boards as easy as swapping them out or should it be tested after installation? Do you recommend getting this done professionally? I will definatly check out all hdmi and a/v cords first just in case that would be an easy and cheap fix.
  • Panasonic Master
  • 19,396 Answers
To start check all cables attached to TV , and test TV with no device or a minimal set of devices connected. A faulty connected device or a defective cable can cause the problem.
If plasma TV loose picture erratically, but tv keeps working, then the most common fault is concerning Sustain boards.
Sustain boards (Ysus Zsus) function is sustaining voltage on the plasma screen. If one of them is faulty, among other problems you can suddenly get darker picture or no picture.
You can replace Sus boards buying one of the kits , however part should be tested by a technician before repair. Less commonly but still possibly, the problem can also be caused by a faulty digital controller board or faulty buffer board inside the TV.
Here the parts:
YSUS SC BOARD TNPA4250 PANASONIC TH-42PZ700U
XSUS SS BOARD TNPA4251 PANASONIC TH-42PZ700U
Posted on Sep 26, 2009
  • Ginko
    Ginko Sep 27, 2009
    Changing the board is not a difficult repair. The job is done unplugging power cord, removing back panel , and removing and refitting the two sustain boards that are connected at the sides of the plasma panel.
    While doing the job parts can be damaged by touching the circuits or contact, and big capacitors can release dangerous discharge even when the TV is not connected to main.
    The issues are the following:
    For safety reason any repair job of this kind should be do by a technician. By law I cannot really suggest DIY to a non trained person.
    To test in full the Sus boards you need to work with volts on. This must definitively be avoided unless you have a strong experience repairing electronic and a H&S training.
    By replacing the part without testing you take the risk. The Ysus Xsus (Zsus on other TVs) is the most common cause for no screen, and TV working and not going on protect.
    Part for this set is quite expensive, and the problem can be caused by a fault on digital board or a bad connector.
    On other models the Ysus Xsus kit can be purchased for a lower price. In this case I think it will be better calling a technician. Call Mitsu first. You find the number on the manual (or tell me your location). Ask them a charge on repair or if there is possibility to get a new TV discounted. Ask also if you can extend your service plan to cover the repair.
    Many users fix their TV
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
Sony KDL-40Z4100 standby light solid red, orange blinks every 4 sec, What part may have gone bad?
The red stand by indicates the set is in PC stand by the blinking orange timer is indicating the timer has been set or has an issue
Mar 13, 2012 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
When TV is first turned on, color looks like a reverse negative in a photo, picture is mostly black, white, and purply pink. TV picture then shuts off, power light indicator stays green, sound stays on....
we had a SONY Rear projection and we had that problem turned out to be a bad fan and caused the main control board to fail thus the same problem contact the company and see what the warranty covers
Jan 02, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
Samsung HP-4252 screen goes black
I have the same problem, and it will get worse. I have read and seen video on youtube, stating that it is capacitors on the power board, that need to be replaced. I watched the tutorial video it seems pretty easy, I am going to try it this weekend. Will update.
Jun 02, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Screen periodically going black
try dvd if that doesnt go in and out try a new cable box or ddish receiver
Jun 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Plasma tv screen goes black once you turn it on. Only sound
I have a panasonic TH-42PX60U plasma TV. When I watch TV programing I have no problems, or with the DVD input. But if I switch to another input, be it video game (PS2) or vcr the screen sometimes goes black and the red power lcd light next to the power switch flashes. Holding the power button in for a few seconds will shut down the tv. Then I can turn it back on and it may operate normally again for a undetermined period of time, before the screen goes black again. This never happened when new. The tv is about 1 year old. Any ideas on this problem? Thanks Ernie
Aug 13, 2008 | Televison & Video
Red light blinking rapidly...no picture
Gentlemen, I have seen people with this problem and it requires the replacement of the light engine, search AVS Forum, for more information. Understand it is not cheap, hope you have ext warn.
Sep 25, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Panasonic TH-42PZ700U 42 in. Plasma Television Logo
382 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
