Question about IBM ThinkPad 600E 2645 Notebook
IBM Thinkpad 600e (2645),error 189 and could not installing win98
I have IBM Thinkpad 600e laptop. It is showing error 189 at the POST. I could not instal win98 due to the above error. pls give me a solution
  • 63 Answers
Usually this means a hardware failure. I would suggest reseating the CMOS battery overnight to reset the system. Also you might want to replace it as well. It could also be more serious such as a motherboard component failure.
Also IBM error code # 189 according to Scott Mueller's Upgrading and Repairing PC's (8th edition) - "Excessive incorrect password attempts." Is there a password on your CMOS ?
Also try hitting ESC key on boot to bypass. Good luck!
Posted on Sep 23, 2009
My laptop IBM ThinkPad 600E 2645 by turning on shows the notice Error 129 in system board. The laptop cannot be put into service.
The ThinkPad error code 129 is a motherboard problem. This is a component failure on the motherboard and cannot be fixed easily.
The 600E is a very, very old laptop. I suggest you don't spend money on it, put your money towards a new or later model laptop.
Aug 18, 2010 | IBM (30L2872) for ThinkPad 600E 2645-55x...
I have ibm 600e 2645...error 161 and 163....Replaced my bois battery and still get the same error. I reset the clock and I still get back to the OFF and ON site which leaves me nowhere
after the error you need put the right date and hourly push ok later hold the button to off - turn on if the problem continued is a motherboard problem
Mar 18, 2010 | IBM ThinkPad 600E 2645 Notebook
IBM Thinkpap 600E 8611 error
http://www.repairspot.com/thinkpad_8611_error__disabling.htm
pls rate this solution if it works
thanks to choosing FixYa.
May 29, 2009 | IBM ThinkPad 600E 2645 Notebook
Formatting IBM Thinkpad 600E
I know you can't boot from the Windows 98 CD, and probably not from Windows 2000 either. It is possible to turn the the Windows 98 bootable floppy into a bootable CD, but I think you would be much better of trying to install Linux.
Mar 16, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
UPGRADING
That unit it about 10 years old.
Unfortunately, you cannot upgrade the CPU (processor)
The RAM is a standard 100MHz non-parity SDRAM SODIMM. The 2645 can use 128MB DIMMS for 160MB maximum. It has 32MB internal and two slots.
The hard drive size is limited by the BIOS. Any standard 2.5" hard drive should work, but may show as limited size, maybe 20GB.
Get a PCMCIA modem.
If you found a docking station for this unit, you'd be in better shape. Like I said, it's 10 years old. It won't be easy.
Jul 22, 2008 | IBM ThinkPad 600E 2645 Notebook
08611 Error
I'm not sure about the 600E or that error number but the same F1 or ESC key sequence might apply(from your other post)! Good Luck! regards, Babb
Apr 28, 2007 | IBM ThinkPad 600E 2645 Notebook
My ibm s showing a certain error no. on startup
Without seeing the error, you may be best just typing the number into Google.
Feb 20, 2007 | IBM ThinkPad 600E 2645 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
502 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
