Hotpoint wd420 problems
Hi, our Hotpoint WD420 Washer Drier has developed several faults.Firstly, Water leakes from the powder drawer, secondly, the machine stops before the rinse/spin cycle and this then has to be done manually, and finally sometimes the Power LED blinks rapidly and the 'Time Saver' LED blinks slowly (I guess this could be some kind of error message)
Any help would be much appreciated :)
Thanks
Martin
  • MrBanshee Apr 10, 2008
    Same again here, when the sump is full and the drum spins clockwise, it seems to be forcing water up the intake pipe for detergent and out through the facia. I've had the top of the unit off, but it is almost impossible to get at the hose connecting the detergent drawer to the main tank.
  • WesternExile May 10, 2009
    Running program E, at the beginning of spin cycle water overflows out of the conditioner drawer. The drain hose is within specifications (less than 1200 mm from the floor). Program K has less water so it doesnt overflow
    To help solve this problem I lowered the drain hose so that the highest point is lower than the sill at teh bottom of the conditioner drawer.
    The problem persists - the pipe into the conditrioner drawer is of larger diameter than the drain hose and is nearer the drum.
    This problem did not oiccur when new - IS THERE a Non Return Valve under between conditioner drawer pipe which is stuck open (by build up of undissolved conditioer or dirt)?
We had this problem had to clean out the "self cleaning filter" this solved it for us
Posted on Jan 20, 2009
  • 4 Answers
1) Take the top off and thoroughly clean the dispenser and pipes.
2) Check and clean the filter basket at drum outlet to drain pump (in the big black pipe).
3) Timer Saver flashing on its own (but with flashing on/off) points to Triac fault Code F01. Could be intermittent connection too.
Hope that helps but disconnect from mains supply by pulling plug before checking anything.
Posted on Jul 30, 2012
Where is the filter on a Hotpoint Aquarius wd420 washer dryer?
it is located at the back of the machine...are you encountering problems with this machine? check this link i will give you, this a forum/comments which the owners encountered different problems with this machine..
http://www.unbeatable.co.uk/p_rupr/Hotpoint-Aquarius-WD420-Front-Load-All-in-One-Washer--Dryer-Reviews/22394331.html
Nov 13, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Hi. Lots of water has started pouring from the drawer during a wash cycle. I use liquid detergent.
is the tub just filling all the time if so you have a fault on the pressure system or a blocked pressure pipe
Feb 01, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My hotpoint wd420 is leaking water from out the dispensor and door on a rinse/spin cycle.
You ne to get yure rubber seals checked and changed it sounds like they have perished
Nov 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
HOTPOINT WD420 TRIPS ALL THE SOCKETS IN MY HOUSE
You have a fault on the machine which is a dead short or an earth leakage.
Neither can be sorted out without a set of testers and some knowledge
Unless you can get hold of a resistance checker and know how to use it call a in a repair person
Jun 14, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint wd420 clunking noises
Perhaps you are putting to much in it, poor machine, give it a break in its old age! All the Best -the Yeti PS leave room for the water!
May 17, 2009 | Washing Machines
Hotpoint wd420 not pumping
Hi,I have just been on a service call to the same model,the pump windings had shorted turns and after replacing the pump i have found that it has also damaged the module(pcb assembley) not good considering the module is 120 uk sterling!!
Feb 18, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Washer WD420 leaking from dispenser draw
hi firstly turn down your cold water pressure as this somtimes gives the impression that the water is coming from the drum,then check that the rinse hold button is not activated if so press in the button then the timer should continue on its own,hope this helps if so please rate thank you.
Aug 18, 2008 | Washing Machines
Washing Machines Logo
1,128 people viewed this question
Top Washing Machines Experts
