Question about HP Office Equipment & Supplies
Right edge is smearing - HP 3030 laser
Right edge is smearing. possible fuser bar?
    Scholar:
  • HP Expert
  • 199 Answers
Yes.teflon sleeve
Posted on Sep 25, 2009
Print smears on right edge of paper only
It is possible that the fuser film is damaged. The fuser film covers the heating element. Open the back panel, and examine the area where the paper exits. The grey film should cover the same area as the lower black roller. If not, you will either need to replace the fuser or obtain a replacement fuser film and install it. Is the printer noisier than it used to be? The fuser bushings on these printers are notorious for wearing out and causing the film to fail. If the bushings are worn then likely a replacement fuser will be the solution for you.
May 22, 2014 | HP LaserJet P3005n Printer
HP 9050 with smeared or Ghosted print on the leading edge
Your printer might have dust on the hexagonal mirror and other optical components inside the LSU (Laser System Unit). If the printer it's dirty inside, all that dust flows and lay down on components. In course of time, it reaches the optical components and generates a "gradient wiped out" image from left to right as you are looking at the printed page. This problem is common on laser printers. On colour printers, you may find that only one or more colors have this gradient wiped out. Because they have separate Laser System Units.
May 08, 2014 | HP LaserJet 9050 Printer
Hp laser jet P2035N has a crease down the center of the page as the paper exits it is actually slightly raised so the print is smearing
Check to make certain that the fuser unit is not damaged. Often a crease or dimple is caused by foreign material on the fuser roller or the fuser is damaged. If the fuser is damaged, look into replacing the device, it may be cheaper than repairing the fuser.
Jan 31, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
HP laserjet 5000gn when i print, output smears ink on 2 sides. not a toner issue cause changed toners already. someone says printer is telling me something and might be a warning of
If by smearing you mean the print is also rubbing off? Then you definately have a fuser unit issue. The fusing unit is the assembly that heats up and "fuses" the toner onto the page. When these start to go bad, usually on one edge or the other the print will smear/double image/wipe off of the effected area. One test you can do to verify a fuser problem is to print a page and then when the page is about half way thru the prcess, shut the printer off. Open the top and remove the toner cartridge, pull out the page and see if the lower part is not smeared. Basically what your checking is to see if the print is ok BEFORE it goes thru the fuser. Based on your description I would suspect your fuser is going bad.
Good Luck and Thank You for using Fixya.
Sep 09, 2010 | HP LaserJet 5000gn Printer
Replaced the black Cartridge, however, printing is smearing
The fuser must be dirty. Change the fuser. It is also possible that the rollers along the paper path is dirty, so clean or replace the rollers.
Apr 03, 2009 | Konica Minolta magicolor 2400 Laser...
Printer HP laserjet 3030
It sounds like a faulty toner cartridge.Try changing the cartridges and see if this solves the problem
Dec 29, 2008 | HP LaserJet 3030 All-In-One Printer
Failure to Allign
This could be the Fuser Assembly. The Fuser is the unit that heats up and makes the toner ahere to the paper. The fact that it is smearing, means that the Fuser is not heating correctly. I would call for service on it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 02, 2008 | HP Photosmart C7280 Laser Printer
HP LaserJet 3030 Fuser Rollers
fuser roller is part of fuser assimble so you need to do is removed first fuser assy set aside and replaced the roller..tnx
Mar 24, 2008 | HP LaserJet 3030 All-In-One Printer
SMEARED PRINTING ON RIGHT-SIDE MARGIN
Ist I take it you have replace the toner/drum. If not do so. If you have then check the paper path to make sure there is nothing in the way, like a torn piece of paper or a label stuck in there? If you are 100% positive the paper path is clear there maybe something stuck in the fusing unit.
Feb 11, 2008 | HP LaserJet 3030 All-In-One Printer
70 people viewed this question
Seeker5211
Seeker5211
