Question about GE (GTS16BBS) Top Freezer Refrigerator
I am having a problem with water in the bottom of my 11 year old whirlpool refrigerator, under crisper drawers. I understand this could be a blocked defrost drainage line. How do I access the drain line? The freezer is on top.
  • 98 Answers
There should be four screws. Two in front on each side.
The two in the back or at the fan cover. in center. take teem out. slide the fan cover up and out. now you can take out the bottom. The drain is in the middle at the back. HOPES THIS HELPS
Ken
Posted on Sep 24, 2009
I have ice bottom of freezer
There could be blocked condensate drain and water from the freezer is dripping in the refrigerator and freezing under the crispers.
Sep 23, 2014 | Refrigerators
Water in left bottom crisper drawer
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Jun 11, 2017 | Whirlpool Refrigerators
Water in bottom left crisper drawer and under drawer
I'm sorry to say that it sound as though your door gasket may no longer be sealing correctly.
For me, it's simply a task of getting a replacement gasket for that make and model.
To remove the old one you would, simply, peel the inside of the gasket toward the outside of the edge of the door revealing the mounting screws. Remove these screws all the way around and replace with the new one in the same fashion...
The reason that I recommend this is that humid air outside of the refrigerator can seep past a worn gasket and condense on the inside surfaces making its way to the bottom and into those drawers.
Feb 16, 2014 | Whirlpool Refrigerators
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
A 2 to 21/2 year old Samsung bottom mount freezer RB217ABPN purchased from Costco. Water is starting to collect under the crisper drawers in the fridge section. This is the third time in a couple of months...
You have a leaking water tank behind the crisper drawer. You will need to get back there to determine if the tank is leaking or the water connection is leaking. This will only leak if you close the door and dispense water from the dispenser.
Jun 22, 2011 | Refrigerators
Frigidare 1812 frig-water under crisper drawers
clogged drain line somewhere in fridge plumbing
Feb 21, 2010 | Refrigerators
Whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Dec 29, 2009 | Refrigerators
Water collecting under crisper drawers.
When the refrigerator goes into defrost mode there is a drain tube that allows water melted off the evaporator coil to go into the drain pan that you found empty. That drain tube is clogged.
May 02, 2017 | Whirlpool ET1MHKXM Top Freezer...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Frozen Veggies in Crisper Drawers and Water under Drawers
water under the crisper doors is pretty common, all you have to do is raise the front legs of the refrigerator, Refrigerators have a heater in them that keep everything from freezing, if it wasnt for the heater then it would just be a freezer, now alot of these samsungs have 2 evaps, so if you get a warm fridge, its prob. because a sensor is out or the heater is out and there is ice buildup inside the unit preventing either the fan from turning, or just blocking air flow, but for the water, just raise the front legs and there is a drain in the back that it will go into from now on
Jul 29, 2008 | Refrigerators
Open Questions:
See all GE (GTS16BBS) Top Freezer Refrigerator Questions
GE (GTS16BBS) Top Freezer Refrigerator Logo
75 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
