Question about Sony VAIO PCV-V210P PC Desktop
I just bought and installed memory for my computer which is on my d drive. How can i save files to it instead of my c drive which i'm running out of space?
    President:
  • 2,678 Answers
Instead of just clicking save click file/save as and you can choose the destination
Posted on Sep 23, 2009
Sorry i have posted my 1st comment wrong. hi, I have recently bought my Sony PSP 2000 (piano black). It do not play the copy game CD's of UMD. When I bought that copy CD and put in my PSP it gives...
Here try this method.
  1. Open your Psp and Press Select to show the menu.
  2. Now Change the USB Device from Memory Stick change it to UMD Disc.
  3. And Exit the menu.
  4. Make Sure that you UMD GAME in inserted in the drive.
  5. Now insert your usb cable into your computer.
  6. On your PSP , GO to settings and USB CONNECTION
  7. Now on your computer go to MY COMPUTER and Double Click your PSP DRIVE.
  8. Now on your PSP Folder, Copy the game ISO and paste it in your Desktop
  9. Now Download and Install this software DOWNLOAD LINK
  10. Once install, Run this software.
  11. Choose compress ISO to CSO.
  12. on INPUT FILE, Browse for the game ISO, ( We save it in desktop )
  13. on OUTPUT FILE, Select the destination where you want to save the COMPRESSED FILE.
  14. Now choose your compression level ( I Suggest you choose 9 - Best Compression )
  15. Click Compress and wait for the process to finish.
  16. Now lets go back to your PSP, Press Select Again to show the menu.
  17. Now Change the USB DEVICE back to MEMORY STICK
  18. Go to your Settings and USB CONNECTION.
  19. Now on your computer, Open Your PSP Drive.
  20. Go to ISO Folder, (DO NOT CLOSE)
  21. Go to the Folder where you save the compressed file.
  22. Copy the compressed file and paste it in your ISO Folder.
  23. Now go to your PSP and Play the game.
  24. Enjoy.
Goodluck in doing this method. Hope i Helped. Please give me Feedback regarding my solution thanks.
Jul 05, 2011 | Sony PSP (Piano Black)
My cd rom is not working cant use installion disc to configure lgt300 as modem . Is there a file i could download here and save it to usb to configure instead?
On a different computer, copy all the files from the CD-ROM to the USB memory-stick.
Move the memory-stick to your computer, and install the software, by accessing the memory-stick.
May 14, 2011 | Computers & Internet
Our business has been using Printmaster 15 for a few years now. We recently bought a new computer with windows 7. Printmaster 15 is obviously not compatible with Windows 7. I bought printmaster 2011...
You can try version 15 in compatibility mode:
Troubleshoot Compatibility
This can help with some (but not all) programs/drivers:
1) Uninstall the program if it's already installed. Then when you install/reinstall it instead of double clicking on the install file right click it and select "Troubleshoot Compatibility"
2) Then click "Try Recommended Settings" and in the next window click "Start the Program" to install it.
3) After it installs see if it works correctly. Please note - some programs may not be able to run in Windows 7.
More details about how to make older programs run in this version of Windows:
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Jul 19, 2017 | Broderbund PrintMaster Platinum 16
I have a game called juiced and When i double click to play it it says ,,Juiced requires virtual memory to be enabled".Can somebody please help me to fix this error and play my game please?I have...
Manually manage computer memory loadTOCNode(3, 'moreinformation'); When your computer's physically installed random-access memory (RAM) is running low, Windows adds available memory by using a paging file, generally known as virtual memory, on the hard disk to simulate physical RAM. By default, the virtual memory paging file that is created during installation is 1.5 times the physical RAM on your computer. Therefore, a computer that has 1GB of installed RAM will have 1.5GB of virtual memory.
You can manually change the size of the paging file to make it larger or smaller. You can also optimize virtual memory use by dividing the file space between multiple drives and by removing allocated space from slow or heavily accessed drives. To optimize your virtual memory space, divide it among as many physical hard drives as possible. When you select drives, follow these guidelines:
  • Try to avoid having a paging file on the same drive as the system files, usually drive C.
  • Avoid putting a paging file on a fault-tolerant drive such as a mirrored volume or a RAID-5 volume. Paging files do not require fault tolerance, and some fault-tolerant computers experience slow data writes because they write data to multiple locations.
  • Do not put multiple paging files on different partitions on the same physical disk drive.
How to manually change the size of the virtual memory paging file loadTOCNode(4, 'moreinformation'); You must be logged on as an administrator or as a member of the administrator's group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
To manually change the size of virtual memory, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then press ENTER.
  2. Click the Advanced tab, and then under Performance click Settings.
  3. Click the Advanced tab, and then under Virtual memory click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
  5. Under Paging file size for selected drive, click Custom size, type a new paging file size in megabytes (MB) in the Initial size (MB) or Maximum size (MB) box, and then click Set.
  6. Click OK to close the dialog box and apply changes.
Note After you change the size of the paging file, you may be prompted to restart Windows. If you are prompted to restart, the changes will not take effect until Windows is restarted.
Notes
  • To have Windows select the best paging file size, click System managed size. The recommended minimum size is the same as 1.5 times the RAM on your computer, and 3 times that figure for the maximum size. For example, if you have 256 MB of RAM, the minimum size is 384 MB, and the maximum size is 1152 MB.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is the same as 1.5 times the RAM on your computer. It is good practice to leave the paging file at its recommended size as performance can decrease if a paging file is too large. However, you may increase its size if you frequently use programs that use lots of memory, such as graphics programs or games.
  • We strongly recommend that you do not disable or delete the paging file because this can lessen the computer's performance. However, if you decide to delete a paging file, set both the initial size and the maximum size to zero, or click No paging file.
How to manually optimize the memory usage loadTOCNode(4, 'moreinformation'); You can optimize your computer's memory usage to reflect your specific needs. If your computer is used as a workstation instead of as a server, you can increase performance by devoting more memory to your programs. Your programs will work faster and the system cache size will remain the default size that was included with Windows XP. Or, you can set aside more computer memory for a larger system cache if your computer is used primarily as a server, or if you use programs that require a large system cache.
  3. Click the Advanced tab, and then under Memory usage use one of the following methods:
    • Click Programs if you use your computer primarily as a workstation instead of as a server. This option allocates more memory to your programs.
    • Click System cache if your computer is used primarily as a server or if you use programs that use a large system cache.
  4. Click OK to save preferences and close the dialog box.
You may refer to this link http://support.microsoft.com/kb/308417
Apr 18, 2011 | Intel Core 2 Quad Q8200 Computer System...
Hi , i was wondering was there a way to download oovoo to your flashdrive and how do i do that.
Hi..
ooVoo is an audio and video instant messenger for windows enabling Skipe like features, but with more features like desktop sharing, Sidebar views, Social Network Implementations.. etc.
yes. there is a portable version available so that you can save it in your USB Pen Drive and use it with out any installation.
Trick is that it saves all configurations in separate file in installation directory instead of default %APPS% directory.
Some of portable versions of ooVoo is found on this site.
you may take precautions to avoid virus attacks.
thank you
Mar 13, 2011 | Computers & Internet
Is ram and memory the same?
Yes it is Ram stands for random access memory .........cheers
Jan 27, 2011 | Toshiba Satellite L25-S119 Notebook
How to recover deleted text messages from Nokia e63 memory
you can recover lost info from phone with mobile phone recovery software, recommended asoftech data recovery as it helped me beforehttp://www.asoftech.com/adr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Dec 28, 2010 | Nokia E63 Cell Phone
I cant save my messages to my memory card
In nokia 3230 you cannot save the messages to memory card.You dont have option in this mobile itself.
Dont worry, please download MSV driveE software in your mobile phone so that messages can been directly saved in MMC.
Download the MSV software from below website
http://www.ziddu.com/download/8277766/MsvDriveE.jpg.html
After you downloaded it, you’ll find that you save file named MsvDriveE.jpg. Don’t worry! You just downloaded the right file. Rename the extention *.jpg, and change it to *.sis. Then you’ll get MsvDriveE.sis then install it to your phones.
But in this feature it just saves the incoming messages to the memory card instead of saving it to phone memory to keep the phone memory unused.But you cannot read your messages.
To read your saved messages in PC please install a software called as FE explorer.
You can download FE explorer from below website
http://gallery.mobile9.com/f/1210278/
Using this FE explorer you can copy the messages in your inbox and you can paste in any of the folder in memory card.Then you can open the messages in your computer using Note Pad and read the messages.
To copy please follow the below steps,
1.Select inbox from the main page in FE explorer.
It shows the messages in Your inbox,sent item,saved messages also.
2.Copy it and Paste where ever you want to copy in E:/ drive(Memory card)
3.Then you can put your memory card in your PC and can open up the messages in Note Padfd6f18b.jpg Thank you
Aug 08, 2010 | Nokia 3230 Cellular Phone
I have purchased a memory stick[8GB] and I need to know how to use it
Hello !
If you are familiar with floppy disks (were placed in the "A" drive) from years ago, the memory stick works in the same way. Instead of saving to the "A" drive, you would save to a drive letter.
If you have a computer that is less than 8 years old, you probably have a USB port. The USB port is rectangular in shape.
Place the memory stick in your USB port (any USB port). The stick only goes one way. So if it does not fit, flip it over and try again. Do not force it.
You should see a message displaying a drive letter (probably "E", "F" or "G") that has been created. Note that drive letter.
Now, the memory stick will allow you to save your files to the "E", "F" or "G" drive. Your computer's hard drive is "C". When you save files (in a document, for example), you are saving to your "C" drive. To save to the memory stick, select "Save As" with in your software program, such as Word, and select the memory stick's drive letter. Your document will be saved to your memory stick. Note that the light will go on the memory stick as it saves your document.
When you are finished with the memory stick, look for a symbol on your Toolbar (near the date/time). Right-click the item and select "Eject" and you'll get a message that it is safe to remove your hardware.
Please note to never remove your memory stick when your are saving a document or other file.
That's it !!
Hope this helps.
Oct 09, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My acer aspire 5600 warned that I am running out of memory. My "D" drive says there is 30g of free space. How do I use it?
I think the computer actually said you were running low on Virtual Memory ... memory is the physical ram installed in your machine ... virtual memory is an area of hard drive the computer uses to store data when in runs out of "real" memory .....hard drive space is nothing to do with memory.
Ok, that got that cleared up :-) .... now the quickest way to get over low virtual memory problems is to install more RAM. For XP you should really have a minimum of 512mb .... 1gb is probably optimum. For Vista you should really have a minimum of 2gb.
So if your laptop has less than 512mb(xp) or 2gb(vista), the first thing to do would be to upgrade the memory.
Virtual memory problems should only ever crop up when you are running multiple applications .... so just try and keep the amount of programs you have running to a minimum. Instead of just minimizing programs, try to close them down to save memory.
Jan 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Sony VAIO PCV-V210P PC Desktop Logo
50 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
