Question about Compaq iPAQ H3630 Pocket PC
IPAQ hp Pocket PC wont turn on!?!!
I have a iPAQ and i tried charging it by USB.. didnt work!! i lost my proper charger, so i used the USB it worked yesterday but i didnt fully charge it and now it wont even turn on! usually it would have a flash and start up but nothing!!!! plz help!!
Same Problem Here I In The Dark Here I've Treid All The Other Formus I Might End Up Getting A New Charger.
Posted on Oct 29, 2010
I have a h6365 that shows no sign of life,I want to know the positive and the negative terminals on the battery so that I can use a universal charger to charge the battery.
It is NOT that easy because there are 5 connectors on the Battery. If you are wanting to determine if your charger is working or not working, then I would recommend using a Multi-meter on your device to determine if they are working...
Jan 03, 2015 | HP iPAQ h6365 Pocket PC
Internal battery charger
Yes you can buy them on e-bay here is the link for one
http://www.ebay.com.au/itm/Charger-For-HP-iPAQ-hx2100-hx2400-hx2490-hx2750-364401-001-367205-001-/360527673086?pt=AU_MobilePhoneAccessories&hash=item53f11fb6fe just charge up the battery externally and away you go I bought a second battery so I can have one on charge charging while I am using the one in the IPAQ so no down time
Dec 08, 2013 | HP iPAQ HX2490 Pocket PC
Hp ipaq wont charge from usb cable. turns on for a few seconds nd loads but then turns off. it wont fully charge.
On the the IPAQ 6515 and others, there is a USB Power option that you must enable to 'slow' or 'fast' charge from USB connection.
Jan 13, 2010 | HP iPAQ HX4700 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
I have an HP Ipaq h1940 pocket PC. It won't charge!
Charge the dead battery with other good battery for a while first.
Jul 29, 2009 | HP iPAQ H1945 Pocket PC
Does not turn on
There are some known issues with the included charging equipment. Personally, I ordered a relatively inexpensive charger from Amazon.com that works wonderfully. All you really need is a device that turns a standard wall plug into a USB charger. You can then plug your base that the ipaq stands on into that and it should begin charging. The old battery is probably dead (mine was), but try to charge it anyway.
Note: The actual cord that came with my charger DID NOT WORK. It is sitting in a box somewhere, and if its the same thing I had (it probably is), then you just need the wall-to-USB converter.
This is what I bought:
http://www.amazon.com/iPAQ-rx3715-Sync-Charge-Cable/dp/B000DT8F0A/ref=sr_1_4?ie=UTF8&s=electronics&qid=1204335733&sr=8-4
It is only $10. Again, the cord didnt work for me. Maybe it will for you, but if you manage to find just that converter for less money, more power to you!
Feb 14, 2008 | HP iPAQ RX3715 Pocket PC
Hp ipaq h6315
If it is blinking red, it means that your battery is having issues. Try replacing the battery and see if it fixes the problem.
Dec 03, 2007 | HP iPAQ h6315/h6365 Pocket PC
My hp ipaq hw 6515
Try soft resetting your ipaq. If that didnt work then try hard resetting it, note that you will lose all the data in your ipaq
Oct 23, 2007 | HP iPAQ hw6515 Pocket PC
IPaq rx3115
I had a similar experience. My device would not charge via the usb charger so I connected it to my wall charger and it charged successfully.
Jul 07, 2007 | HP iPAQ RX3115 Pocket PC
Compaq iPAQ H3630 Pocket PC Logo
468 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
