Question about Motorola Mobility L6 Cellular Phone
I can;t acess my initial setup from my phone under settings
My motorola c350 language has been changed. Now I cant read the language for what its getting difficult to change it to English. Please help
Download the user-manual from this site. http://www.motorola.com/mdirect/manuals/C350_gsm_User_Manual_E.pdf
Observe the menu map. From your main menu, you have to open more (It has box open icon). Under More, you have to open Settings(Two mechanical bolts icon).
Under settings, you have to go to Other Settings which is the 5th option.
Call Forward
Phone Status
In-Call Setup
Security
Other Settings *
Under Other settings, you have the following options:
Personalize
Initial Setup
Network
Car Settings
Headset
You have to select the 2nd setting, that is Initial Setup.
Under Initial Setup, you have the following options:
Time and Date
1-Touch Dial
Backlight
Zoom
TTY Setup
Scroll
Animation
Language
Battery Save
Contrast
DTMF
Master Reset
Master Clear
You have to select the 8the option, which is language(langua/idioma/langue).
Now from the options select English to set english as the changed language.
Jul 20, 2011 | Motorola Mobility C350 Cellular Phone
Mobile habg
Try this under Settings Menu:
Initial Setup
• SpeakerPhone
• Auto Redial
• Display Timeout
• Backlight
• TTY Setup
• Scroll
• Language
• Battery Save
• Brightness
• DTMF
• Hyphenation
Master Reset
Master Clear
And as far as the Reset Code try (666666) it worked on an older MOTO. phone. Hope this helps
May 08, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Reset time on phone
go to initial setup > time and date. enable auto-update for the time. and change it to your correct time zone if u have to under this same menu.
(your first option "initial" may be phone setup, or setup depending on the current flex version on your phone so don't be afraid to surf around a little in the settings tell u find the "date and time" option.
Nov 01, 2009 | Motorola Mobility Clutch i465 Cell Phone
Changing the time on my Motorola Razr V3 phone
you must first disable Autoupdate (turn it off) - go to settings>scroll to Initial Setup, (select this)>Time & Date (select this)>Autoupdate (set to OFF)>after you do this option will appear to change time to 12/24 hour....
May 11, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Motorola MOTORAZR² V9m
Go to Menu/settings/initial setup/master reset enter 6 zero ok.
Similar Menu/setting/initial setup/master clear enter 6 zero ok.
Before to do that function,copy all phone book to simcard.
Dec 26, 2008 | Verizon Communications Motorola MOTORAZR2...
Go to settings
--> Initial Setup
--> Time and date
--> Auto update off
Then you will find the time and date.
go to date use right soft key and change the date and similarly for the time.
Jul 28, 2008 | Motorola Mobility RAZR V3
W220 motorola
  1. menu simplified traditional
  2. Settings 置 or 設置
  3. initial setup 最初的设定 最初的設定
  4. language 言 語言
If you know the sim codes
and unlock codes (1234 0r last 4 digits of phone #)
do a master re-set
  1. menu
  2. settings
  3. initial setup
  4. master reset
Feb 26, 2008 | Motorola Mobility W220 Cellular Phone
I do not know how to set my clock on my razr after the time change last nite
Settings
Initial Setup
Time and date
  • Turn AutoUpdate Off
select and make the change
Nov 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
12 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
