Question about GE (PSS26MSRSS) Side by Side Refrigerator
Refrig 4 yrs old ,freezer fine but cool section even when cranked up all the way isn't very cold
  • osburnwilly Sep 23, 2009
    where would I find this flap
  • 11,896 Answers
You may need to check the flap that controls the air flow between the fridge and freezer. Sometimes it can get stuck in one direction. Also the mechanism that controls the flap can go faulty. You can check power to the module with an ohm or volt meter.
A bad thermostat or temp timer can cause unit not to cool.
Posted on Sep 23, 2009
  • Nate Stansfield
    Nate Stansfield Sep 23, 2009
    In the vent between freezer and fridge
I have model number PDE18LZRBB. Freezer works fine; refrigerator section will not cool properly.
Your problem is usually caused by poor air circulation. The only way the refrig section gets cold is from the fan in the freezer blowing cold air into the refrig section. The fan should be behind the back wall of the freezer and should be running at the same time the complete refrigerator is running. No fan run---no cold in the fresh food section.
Apr 01, 2015 | GE Refrigerators
GLRT216TAW2 Model Number. Water under vegetable drawers, No other water leaking. Back is dry, Do i need a repair man or new refrig which is only 10 yrs old.
Its the defrost problem.In your unit the defrost cycle is not running on time.This is the procedure of the unit.--- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to fridge passes from the section, in that section the damper is located.In your case the freezer gets cold, after that defrost cycle has to start, but in your case the defrost cycle is not starting on time so over ice gets internally build and when defrost cycle starts, this ice melts and this gets leaks in the vegetable and under vegetable drawer.-------- Get the defrost timer, and defrost assembly parts checked and repaired by the technician.Repairing will solve the problem.You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 04, 2011 | Frigidaire GLRT216TA Top Freezer...
Refrig. is 4 yrs old. Refigerator side just quit cooling. Freezer side seems to be working fine. Help!!! Samsung Model #RS267LBBP
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
I have a frigidaire side by side #FSC23LR5JM2 that is not keeping cool enough. Age is aprox 1.5 yrs. Noticed the problem over a couple of days. Turned the temp cooler by 2 numbers in the frig and freezer,...
if the freezers staying cold but not the refrige section,then its the damper vent door between the freezer and refrige section thats either frozen shut or the damper door motor is bad or without power,if nothings cold as in freezer and refrigerator sections,then its the ptc overload & relay on the compressor thats bad,unplug the ptc overload & relay off the side of the compressor and obtain an exact replacement and plug in the new replacement and it will again cool
Mar 23, 2011 | Frigidaire FRS3R5EMB Side by Side...
The freezer works fine, refrigerator section not cooling it is 6 yrs. old, should it need a refrigerant(freon) charge ?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 09, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Refrig. Won't keep food cold but the freezer works fine. Milk spoils after 3 days in the refrigerator. What's wrong? The thermastat was supposely changed?
If the thermostat has been replaced, then I would take a look at the dampers between the refrigerator and the freezer. Here is why....
All the cooling takes place in the freezer section of the unit, there are passageways with dampers that connect the freezer section to the refrigerator section. If these dampers get stuck in a certain position you will either have not enough cooling or to much cooling. This sounds like it is your issue. Hope this helps.
May 07, 2010 | Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchenaid built-in refrig 15 yrs old cold freezer, warm fridge
it.s the frezer that makes the refer cold.the evap fan in the frezer moves that chilled air to the refer.if that fan is slow or any blockage inthe air ways it slows that process.Also the frezer should be close to 0 degrees if theres a defrost prob that would make fresh food warmer
Dec 31, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
20 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
