Question about Dell 962 Photo All-In-One InkJet Printer
I want to copy front and back same paper how can I do that? please give me the step by step direction ... than'x
  • 63 Answers
You have to have a special printer to be able to do this but you can do it manually as well. You just have to figure out which way it prints. Print one test and note which direction it comes out and what side. Then put the test paper back in the tray noting which side has print on it and print again. Now you will be able to tell what side the ink prints too and you can flip it around and reinsert it in the tray to print on both sides. Its a little complicated but once you get the hang of your printer its easy- I do it all the time with my little Epsilon cause Im too cheap to pay the big bucks for a double side printer.
Posted on Sep 23, 2009
Says there is a paper jam and to open top cover but I do not see a paper jam there. I took out the toner cassette but do not see the paper jam.
When your reports paper jam for any reason, whether there is paper jam or not, most times you need to go thruogh paper jam clearing procedure to have your printer printing again. So please follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Put off the printer and unplug it from its power source.
Open all the covers/shutters on the printer (usually you will find one in the front or top and one at the back of the printer).
(If the printer is a DeskJet, otherwise ignore this step) Now pull out the cartridge carefully and place it on safe surface. (Be careful not to place it where it may slide and fall. This could damage the cartridge)
Site the paper that has jammed and pull it out in the opposite direction of its movement. Do not pull in the direction it was coming out. (Pulling the paper in the opposite direction is important for the printer's mechanism. Printer must be off). Never pull out paper from a printer when the printer is powered on.
(If the printer is a DeskJet, otherwise ignore this step) Return the cartridge gently and press it firmly inside so that you here it snap inside.
Close all covers at the top, front or back.
Power on your printer and you should be able to print again.
Good luck and God bless!
Mar 04, 2011 | Kyocera FS-2000D Laser Printer
The printert dos not respiond to any cartridge and dos blink at all /
Issue: All the lights blink In this error condition , the following blinking lights pattern displays on the control panel:
  • On/Resume light : Blinking
  • Check Paper light : Blinking
  • Check Print Cartridge light : Blinking
  • Black Start Copy light : Blinking
  • Color Start Copy light : Blinking
Figure 107: All the lights are blinking on the control panelc00864301.gif Solution one: Make sure that the front panel overlay is installed correctly If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, follow these steps to ensure correct installation of the front panel overlay. If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to reinstall the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins. NOTE: If you have already installed the front panel overlay, proceed to the next solution.
  1. Disconnect the power cord from the rear of the product.
    Please arte me Thanks Techbelkin
    TECHBELKIN ORIGINAL SOLUTION
  2. Locate the front panel overlay and peel off the paper backing to expose the adhesive as shown in the graphic below. Figure 108: Remove the paper backing from the front panel overlayc00005257.jpg
  3. Lift the scanner lid.
  4. Carefully line up and install the front panel overlay. Figure 109: Install the front panel overlayc00005258.jpg Figure 110: Correctly installed front panel overlayc00005259.jpg
  5. Reconnect the power cord to the rear of the product.
  6. Try the intended task again.
Solution two: Reset the All-in-One Follow these steps to perform a power reset. Step one: Perform a power reset
  1. Press the On/Resume button (c01602202.gif ) to turn on the product.
  2. With the product turned on , disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Plug the power cord back into the wall outlet.
  6. Reconnect the power cord to the rear of the product.
  7. If the product does not turn on automatically, press the On/Resume button (c01602202.gif ) to turn the product back on.
Step two: Print a self-test report Follow these steps to print a self-test report.
  1. Load plain, white paper into the paper tray.
  2. Press and hold the Cancel button (c02517757.gif ), and then press the Start Copy Color button. The product prints a self-test report.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution three: Service the All-in-One If you have completed all the steps and are still experiencing a problem, continue to the Service the All-in-One section at the end of this document. Service the All-in-One If you have completed all the preceding steps and are still experiencing a problem, service the product. Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
  • If your product is in warranty , contact HP.
  • If your product is out of warranty , fees might apply for contacting HP.
Jan 08, 2011 | HP PSC 1315 All-In-One InkJet Printer
Where do i find directions to change the bellows for whirlpool duet GHW9150P?
The following link explains step-by-step how to change the door bellow on a Whirlpool Duet front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope this helps you.
Apr 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Paper jam
Dear sir,
i am giving u setp to solved your problem,
Step one: Remove any loose paper.
Step two: Clear the jam from the back of the All-in-One
Step three: Clear the paper jam from the front of the All-in-One Step four: Clear the jam from the automatic document feeder Step five: Print a self-test report Thanks For Your Time,
Apr 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
States paper is jammed...no paper jammed...tried to use feed switch, reset, turning off and on nothing works
Once your printer, for any reason reports "paper jam." It expect you go through the basic motions of clearing paper jam, else it won't procede to print. So you need to patiently follow the procedure below am giving you.
i. Put off the printer and unplug it from its power source.
ii. Open all the covers/shutters on the printer (usually you will find one in the front or top and one at the back of the printer).
iii. Now pull out the cartridge carefully and place it on safe surface. (Be careful not to place it where it may slide and fall. This could damage the cartridge)
iv. (You may ignore this step)Site the paper that has jammed and pull it out in the opposite direction of its movement. Do not pull in the direction it was coming out. (Pulling the paper in the opposite direction is important for the printer’s mechanism. Printer must be off). Never pull out paper from a printer when the printer is powered on.
v. Return the cartridge gently and press it firmly inside so that you here it snap inside.
vi. Close all covers at the top, front or back.
vii. Power on your printer and you should be able to print again.
Dec 07, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My c5280 constantly tells me it is out of paper, even when I turn on/off, replace paper, try to run single sheets, etc...any ideas?
1. open hp solution center
2. in paper settings change paper type as plain paper and try it should resolve.
It should resolve your issue, if the issue still persists continue with the following steps
Solution Summary:
Step 1: Connect directly to the wall outlet
Step 2: Paper sizes
Step 3: Clean the paper feed rollers:
Step 4: Reinstall the front panel and check the functionality
Step 5: Power cycle and Semifull reset.
Iris, to isolate the issue I request you to please perform the steps given below:
Step 1:
Connect the unit directly to the wall outlet.
HP doesnot recommend connecting the printer to a surge protector. As they will not provide sufficient power to the printer. So, I request you to remove the All-in-One from the surge protector and connect the printer directly to the wall jack and switch on the printer.
Step 2:
I would like to inform you that the HP Photosmart C5280 all-in-one supports only the Paper sizes given below.
102 x 152 mm (4 x 6 inches)
127 x 178 mm (5 x 7 inches)
Please let me confirm either you are using the specified supported papers or not.
Refer the weblink given below for more information on the product specifications for HP Photosmart 2610 all-in-one.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00954910&cc=us&lc=en&dlc=en&product=3204464&dlc=en&lang=en
NOTE: Clicking the link above may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address is displayed in the Address box.
After performing the steps check the functionality of the All-in-One. If the issue persist, perform the below steps.
NOTE: After each step, check whether the issue is resolved. Once the issue is resolved, you may stop troubleshooting.
Out of paper error :
In order to resolve the issue please follow the steps provided below:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00786157&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
NOTE: Clicking the links may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address is displayed in the Address box.
Refer the weblink given below for more information on cleaning the paper feed rollers.
Rather than sending you this document in a text format, I am referring you to the Web, where this information is easier to read with graphics and the information is specified in a step by step manner.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&docname=bpu01831
Step 5:
Photo Paper Loading:
I request you to please Perform the steps provided in the article:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00994721&cc=us&lc=en&dlc=en&product=3204464&dlc=en&lang=en
Refer the article given below for more information on how to correct the envelope printing problems.
Power Cycle:
Please perform the steps provided below to power cycle your All-in-One:
We are performing this step to ensure that the All-in-One receives enough power and all the elements inside the inside the All-in-One are fully charged.
The All-In-One may not be receiving enough power if connected through a surge protector. Plug the All-In-One into power outlet without any surge protector between the All-in-One and the wall jack.
1. Verify that the unit is switched on. Unplug the All-in-One from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
6. Now check the functionality of the All-in-One.
Semifull Reset:
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Sep 11, 2009 | Office Equipment & Supplies
Front & Back copies, paper has jammed cadrej side some time only.
You need to replace not only the pickup roller but all three paper roller: Pickup, Feed, Separation.
Aug 08, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
Scanning problem
the black solid line that you were saying, is that vertical or horizontal? But anyways, i just want you to follow these steps...
Step one: Reset the printer
  1. Unplug the all-in-one USB cable from the computer.
  2. Verify the computer and the all-in-one have a three-prong power cord that connects to the power outlet.
  3. Unplug the all-in-one power cord from any power strips or surge protectors, and plug it directly into a wall outlet.
  4. Make a copy or scan, and see if the issue is resolved. If not, proceed to the next step.
Step two: Clean the glass and scanner backing
  1. Turn off the all-in-one.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the all-in-one.
  4. Raise the lid.
  5. Clean the glass with a soft dry cloth, or a sponge slightly moistened with non-abrasive glass cleaner or water.
  6. Dry the glass with a chamois, cellulose sponge or soft cotton cloth to prevent spotting.
  7. Clean the white scanner backing with a soft dry cloth or sponge slightly moistened with water, and allow it to dry.
Step three: Try a blank copy
  1. Plug the power cord back into the wall outlet.
  2. Plug the power cord into the all-in-one.
  3. Turn the power on.
  4. Close the lid; do not place any paper on the glass.
  5. Load paper in the paper tray.
  6. Do either of the following:
    • Press Start Copy Black to start a black-and-white copy job.
    • Press Start Copy Color to start a color copy job.
  7. Please let me know if the steps didnt resolve your issue.
Thank you so much...
adonscott
Jun 29, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart 2575 xi
you need to mention is the half print occurring during a print out/scan /photocopy? Follow these steps to try and resolve the issue: Step one: Reset the printer Unplug the all-in-one USB cable from the computer. Verify the computer and the all-in-one have a three-prong power cord that connects to the power outlet. Unplug the all-in-one power cord from any power strips or surge protectors, and plug it directly into a wall outlet. Make a copy or scan, and see if the issue is resolved. If not, proceed to the next step. NOTE: If the scanner bulb is not lit during a copy or scan, the product needs service. Step two: Clean the glass and scanner backing Turn off the all-in-one. Unplug the power cord from the wall outlet. Unplug the power cord from the back of the all-in-one. Raise the lid. Clean the glass with a soft dry cloth, or a sponge slightly moistened with non-abrasive glass cleaner or water. CAUTION: Do not use abrasives, acetone, benzene, or carbon tetrachloride on the glass; they can damage it. Do not place or spray liquid directly on the glass; the liquid might seep under the glass and damage the device. Dry the glass with a chamois, cellulose sponge or soft cotton cloth to prevent spotting. Clean the white scanner backing with a soft dry cloth or sponge slightly moistened with water, and allow it to dry. Step three: Try a blank copy Plug the power cord back into the wall outlet. Plug the power cord into the all-in-one. Turn the power on. Close the lid; do not place any paper on the glass. Load paper in the paper tray. Do either of the following: Press Start Copy Black to start a black-and-white copy job. Press Start Copy Color to start a color copy job. If the output is a full/half-black page, or has vertical black lines, the product needs service. Step four: Service the product If you have completed all of the steps listed above and are still experiencing a problem, service your product.
Sep 14, 2007 | HP Photosmart 2575 All-In-One InkJet...
Dell 962 Photo All-In-One InkJet Printer Logo
649 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
