Question about Fellowes Powershred 220CC Shredder
The machine will not always shred when you put a piece of paper in it. It works sometimes but doesn't work always.
  • tracy_y_reav Sep 24, 2009
    No, actually I think I fixed the problem. I cleaned the little sensor window on the machine and it now receives and shreds paper. Before, it would not receive the paper.
    Thanks
  • A Miller May 11, 2010
    does the paper pass though unshredded on occasion, is this correct? If this is the case, it is time for a new shredder, IMHO. Tell me more ...
  • 557 Answers
You most likely have bits of paper scrap jaming the switch. Remove the power cord and look for any small pieces and pick them out. A small dental pick works well for this task.
Posted on Sep 24, 2009
Keeps stopping with overload light on. How can this be fixed
The most likely cause is that the shredded paper, has tightly wrapped itself in the blades. One possible cause is by shredding labels (like Avery Labels) or any paper which has adhesive on it. (Causes it to attach the cut pieces to between the cutters.) It reaches a point where there is so much bound up on the blades that even a single sheet of paper will cause an overload. The fix is simple to describe, but difficult to accomplish. You must go in and manually remove all of the paper bound up in the blades. It's not easy, I found that using a needle nose pliers worked best. Lot of digging and tugging (paper will pack between the blades very tightly). Sometimes a small, slotted screwdriver will aid in being able to pry out bits and pieces (it's not going to come out in anything but small chunks; at best). Don't forget to unplug your shredder before you start; those blades are sharp. This happened several times with my last shredder *Royal), but not once with my current shredder (Fellows). I tend to believe that the better quality shredders are worth the extra money. But any shredder will become a problem if you shred labels (like Avery) or paper products that has adhesive on it. (Another common mistake is shredding junk mail that has any kind of adhesive associated with it. Best to open and check first.) One other thing, ALL shredders need to be oiled on a regular basis. They make special oil for this, you can usually find small bottles of it at Wally World or the like. Best practice is to squirt some shredder oil in a serpentine pattern. over a piece of paper to be shredded and run it through. Do this whenever you empty the shredder bin. (Important for the life of your shredder.)
Aug 29, 2014 | Royal 150MX Cross-Cut Shredder
Staples titanium shredder
Sometimes the sensor gets blocked by pieces of shredded paper. Unplug the unit and remove it from the paper bin. Turn it upside down and see if there are any "stray" pieces of shredded paper hanging on the unit. Remove the stray and replace the unit onto the bin making sure it is properly seated. If that is not the problem, try "tamping" the shredded paper into the bin and by doing so, giving the machine more room for the shredded paper. If neither of these help, refer to your owner's manual to see what recourse you may have.
Jan 08, 2014 | Office Equipment & Supplies
My shredder runs non stop, when I insert paper to shred , it stops... I push reverse, it works , pull paper out and runs non stop.......
Sounds like a bad or stuck sensor, acting as if it is always seeing a peice of paper in it. Check if you can find it and maybe it is just stuck to the on position..
Nov 07, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
Shredder will go into reverse but not forward
If this is like my elecrtical paper shredder the solution is to unplug so it cannot shred you and then take any squashed up pieces of paper out of the cutters on the inside of the machine. I have to unblock my machine after every 50 or so pieces of paper I shred.
Feb 07, 2011 | Vacuums
Shrededer motor remains on after shredding is complete
Blow out the sensors with some compressed air.(Computer Duster) they are likely covered in paper dust and the machine believes paper is present.
Please be sure to unplug the machine before attempting any sort of repairs
Hope this is of some help
Ed
Apr 20, 2009 | Fellowes SB-99Ci Shredder
How do I lubricate a Aurora AS702MX shredder?
two ways, first take a light oil (3 in 1) and scribble a pattern on a piece of paper and pass it through the cutting heads do this a couple of times, this can be done as you shred just put a little oil on papers you are about to shred from time to time.
second, if it is a light duty machine, with plastic parts, then pass some waxed paper through the shredder to clean and lube the heads, this also works for your 3 hole punches.
Apr 12, 2009 | Aurora Global AS702MX Shredder
Red overload light is on
Try pouring some shredder oil into the throat where you normally insert the paper and run the machine in reverse.Put machine back into ready condition.
Put a piece of paper in the throat just enough so the machine should run but not all the way in so that the cutting mechanism catches the paper...all you want to do is make the machine run forwards but not actually be feeding in any paper.
If it wont even run in the forward direction you may have a pcb prob...give Royal a call at 1-800-524-0799 for parts assistance.
Jan 08, 2009 | Royal VF1012mx Shredder
Shredding paper partially
Your cutters have spread apart this could be caused by overloading machine to many times or something may have cracked internally that held them in place.
Jan 02, 2008 | Shredder Secure Shred Shredder
My techko SH 3112Fa won't turn off
I had the same problem with my Shredded. In the centre of the paper feed slot is a little sensor that detects when you put paper in, it breaks some sort of light beam that is connected to the motor circuit.
Over time paper dust gathers on this sensor, covering it completely and fooling the machine to think that there is ALWAYS a piece of paper being fed into the shredder, the result being that the motor just runs continuously.
Clear the dust from this sensor and you'll fix this particular problem - a toothbrush worked great for me - don't use it to clean your teeth afterwards :-)
FIXYA!!!
Oct 11, 2007 | Office Equipment & Supplies
Fellowes Powershred 220CC Shredder Logo
160 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
