Question about Zoom H4 Handy Recorder
My Zoom H4 only works with batteries sometimes
I notice some corrosion (bought it used). Could this be the issue? I've noticed others are having similar problems.
    Sniper:
  • 92 Answers
Yes, corrosion is most likely the problem, you may also check the power cord for the correct voltage. If you are savy enough you can take it apart and clean the connections and run it from a power supply. I hope this helps, good luck..
Posted on Sep 23, 2009
    Problem Solver:
  • 12 Answers
I had the same problem. I used 99% isopropyl alcohol from a local pharmacy (do not use rubbing alcohol) and a cotton swab to remove the corrosion on the battery contacts, then put the batteries back in. Success!
Posted on Feb 20, 2010
How to perform a factory reset on zoom H4
Hello ! Actually what you do is download the latest firmware from the ZOOM page. Find HANDY H4 (you can Google that) and go to the Download tab. Follow all instructions. Be sure to have new batteries or be plugged in to AC while you reset. I've done it on my H4(I have 2) and H4n and it worked fine. Be patient, it takes a while once you start. Good luck !!
Mar 09, 2014 | Zoom H4 Handy Recorder
H1 won't connect via USB
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
Mar 25, 2017 | Zoom H4 Handy Recorder
I've bought a SDHC card 32 GB but Handy Recorder H4 do not recognize the card. I've tried to format it at the pc, but no way, the message is "no card"
Verify the device and card reader support SDHC. Try a 2g card and see if that works, typically anything 4g or larger is SDHC, older devices can not read such cards. It is quite possible that the card is bad.
Oct 14, 2011 | Zoom H4 Handy Recorder
Hi! I placed a bid on Ebay, on a used Zoom H4 and didn't read the fine print! I now notice that the seller says that the condition is good, but the battery operation doesn't work - it only works with the...
Usually the problem will be with the battery contacts. Often corrosion due to leaving batteries in too long or the spring contacts, don't. Another harder thing is the adapter connector often has a spring blade that contacts the center pin when adapter is unplugged to switch to battery. These get bent and are a chronic problem for devices that use either adapter or battery.
Apr 13, 2011 | Zoom H4 Handy Recorder
My Zoom h4 has been struggling for a couple months now. Most of the time I get either an error message concerning the card or saying the card is full. Even when the card has been reformatted both on my pc...
Make sure the batteries are good... some people try to use re-chargeable batteries and because of their lower voltage they cause problems. First thing is to try new batteries.
Feb 12, 2011 | Zoom H4 Handy Recorder
My Zoom H4 will no longer run with batteries. If I use AC adaptor it works fine but I get nothing on battery power
Probably the connector where you plug the AC adapter into has a switch contact that disconnects the battery when external adapter is used and it has gotten bent so when the adapter is not plugged in, it no longer makes contact to the battery power. This is pretty common for devices that use both battery and adapters.
Aug 23, 2009 | Zoom H4 Handy Recorder
H4 zoom battery operation
try resoldering the circuit board where the power socket is ... as there is a switch on the socket that disconnects the batterys
Jul 02, 2009 | Zoom H4 Handy Recorder
Zoom H4 recorded data disappearing
I have a H4 but not that problem. Have you tried recording when the H4 is charged? My guess is when low on battery, the H4 doesn't record.
Sep 02, 2017 | Zoom H4 Handy Recorder
Zoom H4 does not power up on battery power.
Probably two years too late, but I recently got a used H4 and it was having this same issue. Upon reading the documentation, it seemed as though it required a specific type of AA batteries. If you update the firmware (mine was 1.3) to the latest version (currently 2.4), you can toggle the battery type under the menu (most likely alkaline is what you want). It also added lots of other great features!
Jun 02, 2009 | Zoom H4 Handy Recorder
Zoom H4 Handy Recorder Logo
227 people viewed this question
Top Zoom Music Experts
Michial Gueffroy
Tom Chichester
rhodesworks
Are you a Zoom Music Expert? Answer questions, earn points and help others
