Question about Samsung NC10-14ROBL Notebook
Notebook nc10 screen keeps going white when in use.
  • 11,896 Answers
Check that hibernation mode is not on, that screen saver is not set, or that monitor is not set to power off in a short amount of time.
You can go to control panel, display, and adjust from here under screen saver settings and power options.
Posted on Sep 23, 2009
5 Suggested Answers
jennifer720
  • 830 Answers
SOURCE: Samsung NC10 notebook screen blanks out
Hello and thank you for using Fixya!
You may want to purchase an electrical conversion plug. I had a co-worker that went to China, plugged in her laptop and it surged it out. I am not sure about electrical regulations in other places but this sounds familiar to her situation.
I do believe this would be covered under the warranty without the travelling part included. They may honor the warranty as a faulty hardware.
If they do not, then more than likely it is the video graphics card or inverter on the screen that got surged.
Test:
Attach an external monitor and see if this happens. If it doesn't happen while attached to the external modem, then it is the inverter andyou will need to replace screen.
If it continues to do this while connected to external monitor, then the video graphics card is going out.
Hope this helps!
Jennifer
Posted on Dec 21, 2009
  • 1456 Answers
SOURCE: i have a samsung nc10 notebook, when charging the
Hi
The problem you are experiencing is from either the screen of your laptop,the screen board which holds the screen in place or the screen bulb which lights up your screen.
You should get an expert to diagnose which one of the three is faulty, but at least one of the three things i have listed is faulty.
Thank you for visiting fixya
Posted on Mar 03, 2010
  • 15 Answers
SOURCE: NC10 netbook screen keeps "whiting out"
If you have to wiggle it on the hinges then it sound like it is a bad ribbon cable connection, it it has somehow broken. There is a thin flat ribbon that runs from the pc to the display. Some patience and care will required. If at a ll possible, take it to an authorized service center, should still be under warranty. Best way to test if from one end to other (pin to pin) for continuity with a volt meter.
Posted on Jul 22, 2010
SOURCE: I have a NP-NC10-KA02US blue notebook, when I
There should be a problem in motherboard or in RAM.
Posted on Aug 19, 2010
I have been having white screen on my nc10
White screen usually means fried video card or graphics card on motherboard. Can you plug into a external computer monitor? If you can do that there maybe a shortcut key on your F-keys to display screen on external monitor.
Feb 17, 2011 | Samsung NP-NC10-WAS1US Notebook
The screen keeps going white
Possibly a problem with the backlight or Inverter, also reports of faulty motherboard to screen video cables
Have look here:
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=137278&modelname=NP-NC10&modelcode=&session_id=KpphnfK5hvXsn18gvx7d2Ymb2xt0pM4rMgTRnstpwGyPh9byDFpf!1920101254!17
If under warranty, I'd get this sent back
Dec 29, 2010 | Samsung NC10-14ROBL Notebook
My netbook,model nc10 ,the display becomes white suddenly and tilting the screen up and down it may ir maynot return to it's normal one.
sounds like you have a problem with your screen/pc connection at the base of the hinge/keyboard. only dismantling and repairing this type of connector would repair you pc--tricky i admit.
Sep 11, 2010 | Samsung NC10-14GW Notebook
My samsung nc10 screen goes white whilst charger plugged vin
the lcd cable that joins the screen to the motherboard is most probably faulty under AC power input. To fix it you need a new ribbon cable. Samsung will charge to sort it without warranty however the NC10 has a 12 month warranty so check your receipt date. Failing that a local computer shop is likely to be the cheapest option.
Jul 29, 2010 | Samsung NC10-14ROBL Notebook
I have a samsung nc10 notebook when i turn it on the screen is just white cant see anything/ i think it is called whiting out. i got it free from 3 but did not pay the bill but that was over a year...
No you either have a bad video card or lcd screen. Try connecting the laptop to an external screen if it is also blank. You will need to replace the screen.
Jul 27, 2010 | Samsung NC10-14GW Notebook
Jul 18, 2010 | Samsung NC10-14GW Notebook
The screen will flicker sometimes go completely white.. Is there a problem that needs to be addressed immediately?
the lcd cable that joins the screen to the motherboard is most probably faulty. To fix it you need a new ribbon cable. Samsung will charge to sort it without warranty however the NC10 has a 12 month warranty so check your receipt date. Failing that a local computer shop is likely to be the cheapest option.
Jun 22, 2010 | Samsung NC10-14GW Notebook
Why does my screen keeping going white and i have to move the screen about to get it back, battery fully charged.
HI
The flex of your laptop is what is giving you that white screen
The flex connects the screen to the motherboard of the laptop the more you open and close the laptop, the flex gets weaker
The solution is to get a repairer to change the flex for you,that will solve the white screen
Mar 09, 2010 | Samsung NC10-14GW Notebook
I have a samsung nc10 notebook, when charging the
Hi
Mar 03, 2010 | Samsung NC10-14GW Notebook
Samsung NC10-14ROBL Notebook Logo
1,061 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
