Question about Denon AVR-1804 Receiver
My Denon is in Protect mode, what can I do to change this back to normal mode. I do not have the remote control either?
    President:
  • Denon Master
  • 1,114 Answers
First, disconnect all speaker wires at the receiver and turn it back on. If it stays on, your receiver is ok and you need to check each wire and each speaker by re-connecting them one by one and re powering the receiver. You will either fix the problem or find the problem by doing this. It's either a bad speaker or a wire is shorted in line or at the receiver or speaker. It's the most common problem of all. If your receiver still shuts down, it needs to be serviced. Hope this helps
Posted on Sep 23, 2009
AVR X1000 going in protect mode?
If you used it for only 3-4 hours before the problem occurred then you should have a replacement warranty on the product.
I think you have already done the factory reset procedure shown on page 175 of the user manual.
Is it possible to take it to the place you purchased it from. Alternatively check the Denon website and find out who the closest agent is in your locality. Send it back with proof of purchase using a courier service that you can track for receipt. Hope it turns out well.
http://assets.denon.com/DocumentMaster/us/Owners%20Manual%20-%20English_AVR-X1000.pdf
Denon
Aug 01, 2014 | Denon AVR-X1000 5.1-Channel Network AV...
Denon AVR589 shuts off. I removed all connections and plugged it back into the wall and powered it on. The same thing happened. I think the company told me it was going into protect mode. I have no idea...
One or more channels have a short in the audio output stage causing the protect mode to engage " saving it from further damage " this will require a professional or Denon service. I'am not aware if there are issues with this model.
May 07, 2011 | Denon AVR-3805 Receiver
How do you get a denon avr-2000 out of "protect" mode?
How diid i get a denin avr 2000 out off protect mode?
Sep 12, 2010 | Denon Audio Players & Recorders
Denon AVR-1100 receiver "PROTECT" mode
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Dec 25, 2008 | Denon AVR-1100 Receiver
Denon RC-980 subsitute remote for Denon AVR-3200
I have a remote left over from my denon ACR3200. the remote is RC-825. It is currently listed on Ebay.
Dec 24, 2008 | Audio Players & Recorders
Denon 2106 Protect Mode (Close Out)
I am glad that changing those voltage regulators in the power supply of the main board has fixed your problem. As I told you in earlier posts, when you unplug a connector it can give you erroneous voltage readings that can send you looking in the wrong places, and it can be dangerous.
I really appreciate the compliment as well, it makes this work very rewarding.
Thanks again, and feel free to contact me with any future problems you may have with any audio equipment.
Dave
Dec 12, 2008 | Audio Players & Recorders
Denon 1508
sterio wireing touching each other putting it in protect mode retrace all your wireing and redo this should clear up the protect mode if not return denon as manufacture malfunction to get replacement
May 30, 2008 | Denon AVR-2105 Receiver
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 13, 2008 | Denon AVR-1804 Receiver
Its under protect mode
Sign up with Denon and you can download you manual: Here's the link. http://usa.denon.com/ArchivedMicroSystems.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=Micro&archivedModel=D-M50S&imageField.x=16&imageField.y=11
Sep 11, 2007 | Denon D-M50S CD Shelf System
Shutdown protection? HELP please
All of the Denon recievers I have repaired (over 100) that shut down after a very short time are going into protect mode. The display lights up and after about 10 seconds the display goes out and the standby led blinks red.
I have found that they have one of 3 possible problems and they all require that the reciever be taken apart and fixed at component level. No way to tell what your problem is until it gets put on a bench and troubleshot.
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Problem 2. There is a resistor that is right next to the preamp board that opens up. It is a 10 ohm 1 watt resistor and when it opens, it causes the unit to go into protect.
Problem 3. The +12 volt regulator fails. It is in the power supply area on a smal heat sink right next to the -12 volt regulator. Generic part number is KIA7812 It also causes the unit to go into protect.
Most decent repair shops can fix these from about $120 up to about $200. Depending on which problem it is and how fast they are at finding the problem. Most charge labor by the hour.
Sep 06, 2006 | Denon AVR-1603 Receiver
Denon AVR-1804 Receiver Logo
313 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
