Question about Hitachi 60GB 4200RPM 2.5" 60 GB Hard Drive
It makes a constant clicking noise and wont boot up windows
    Problem Solver:
  • 8 Answers
Unfortunately what you have there is a dead hard drive the clicking noise is the mechanical part of the hard drive and it should not make any noise. You will need to replace the drive and usually where you buy the new drive they may be able to hook up your bad drive to see if anything can be retrieved.
Posted on Sep 23, 2009
  • 63 Answers
That means the drive is damaged and not reading properly. Pretty much irreparable- I would suggest buying a new drive, happens all the time.
  • 3,153 Answers
If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Make sure you use ONLY the cable that came with it or a SHORTER one.
Dont connect via a USB hub
Make sure you only user the power supply that CAME WITH IT.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you
but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure and just place a new hard drive in there.
Another way to test it it to remove it from the enclosure and connect it directly to a PC with a suitable interface eg. SATA or IDE.
Makes clicking noise
If noise is coming from front wheels and it gets worse when turning, the noise could be coming from a bad constant velocity joint that needs repair. When that snaps, you do not go anywhere!
If you have a broken cv boot, chances are that is the joint that is messed up since dirt and debris gets inside and ruins the joint.
Sep 04, 2015 | Cars & Trucks
Clicking noise
take a visual look under the car if anything loose. Any lights coming on? ARE left and right signals ok- sometime they make clicking noise.
Nov 05, 2013 | 2006 Jeep Grand Cherokee
Front end has clicking or popping noise when making sharp turns right or left when vehicle is in drive or reverse. there is no noise when car is coasting in neutral and making the same tight turns. Any...
The noise is probably warn constant velocity joint in the half shafts the rubber boots are probably broken on 1 or both sides dirt enters in through the broken boot and causes wear which damages the joints they should be replaced before they break and cause serious damage
Mar 26, 2013 | Cars & Trucks
Noise in the front differential on my jeep wrangler
Check the constant velocity joints on the axle ends for rubber torn boots and no grease in the joint. That will cause the click
Jun 25, 2012 | Jeep Wrangler Cars & Trucks
Started up my dell inspiration 4100 laptop and it says no primary boot up devices and makes a click noise ,i went into the bios setup and it says down the list harddrive none constantly please help as just...
You must remove the battery for 12 min, and start your computer with the power cable.
Try opening the bios setup and change the boot order making harddrive no.1 in the boot order.
If all that not working, just press F12 and setup a new windows copy, may be the windows copy is damaged.
Jan 30, 2010 | Dell Inspiron 6400 Notebook
I think my front universal joint is making a noise
Your vehicle may be covered under the 100,000 mile warranty. The axles are part of the powertrain and I would see my dealer before I tried to fix anything. Good Luck
Jul 08, 2009 | 2008 Pontiac G6 Sedan
FAILURE to boot
is the constant noise a clicking noise? does it say operating system not found?
Jun 04, 2009 | HP Pavilion dv6000z Notebook
My printer is making a clicking noise
I woudl try uninstalling and reinstalling the printer. It may have gotten confused.
Dec 21, 2008 | Office Equipment & Supplies
HDD making clicking noise/will not boot into windows
the clicking noise will be the platelettes or the head trying to park inside the hardrive. there isn't a lot you can do ;if you can no longer boot into windows, the hard drive will need replacing and you may not be able to see anything from it unless you have a usb to ide cable adapter to view any files. You may be able to retrieve your important documents from it by fitting the drive as a slave drive after you have installed the new one as a master.
May 30, 2007 | Sony VAIO VGC-V517G PC Desktop
Hitachi 60GB 4200RPM 2.5" 60 GB Hard Drive Logo
124 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
