Question about GE JES1139BL / JES1139WL 1100 Watts Microwave Oven
JES1139 is not working properly. The round table is rotating but the food is not getting heated.What is the problem?
  • 6,784 Answers
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Posted on Sep 23, 2009
Why food is not heating up fan is working and turn table is also rotating?
The heating up function is not working, so get it repaired or buy a new microwave.
Aug 26, 2014 | Microwave Ovens
Sharp r350l
Sounds like an electrolytic blew, but it could be any nuber i=of things. Usually when one element fails, others are damaged and are failing as well, such as the magnetron.
If it is an inexpensive table-top microwave, it would be less expensive to replace it with a new one.
Apr 13, 2014 | Sharp Microwave Ovens
On switching Microwave oven turn table rotates and light in the chamber also lights. Heating of of food do not take place. What is possible reason?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101=--=
Aug 29, 2010 | LG LMVM1935 Convection/Microwave Oven
Whirlpool model number MH7140XFB no longer heats
you either need a new h.v. capacitor or h.v. diode in the magnetron circuitry if you cant hear it cycle when it runs as in a low pitched hummmm when its drawing current to operate the magnetron tube, each part runs about $30 to $45 each,normally its the h.v. capacitor though
Jul 28, 2010 | Whirlpool MH7140XF Microwave Oven
My KCMS185JSS-5 microwave has no heat. It seems to be running, the light and turn table all work, but it won't heat water.
hi..Your micro hood is "shot".so it is not working properly.
The food may not be heating,but the electrical and the walls
of the unit might heat.This may cause sparking and melting
of the interior of the unit.
check it out..
thank u..
kindly rate my response..
Jun 15, 2009 | KitchenAid Microwave Ovens
Ge Microwave space saver over range working but
It is a good possibility that the stirrer has failed. In the top of cabinet is a round cover,there is a small round plug in the edge of it,pry plug out and put it in safe place,rotate the cover < twist locks > gently let it down and stirrer will be either setting on cover or still attached. If you notice any damage< it is a round aluminum disc that is flat > then you need a new one. If you don't see any damage put it back in < put in hole and turn until you feel it line up with shaft and push into place,< gently >.Make note of position and put cover back on < stirrer does not lock on shaft so you have to hold it up until you get cover under it in most cases. Run a short cycle and remove cover to see if it turned at all. If not the motor is bad < turns stirrer during operation>. This is the first time that question has been asked of me and it is the only thing that I can think of if it heats glass and not food.
Apr 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have an Emerson (2 weeks old). It heats well but there is a thumping noise when the table rotates and sometimes the table will operate with a jerking motion.
It sounds like the table is'nt positioned properly on the base it sits on, most are not attached and can be easily removed for cleaning purposes, try repositioning the table on the base.
Mar 10, 2009 | Microwave Ovens
Kenmore microwave 721.80803401 rotating table pops up and stops turning.
I would bet the arm ("ring assembly") is either worn or warped from heat? and is not meshing well with the motor shaft or glass tray.
That is part number 4351W1A003A and you can get it for only $6.30 (compared to over sixteen via Sears) from Tritronics.
The motor is part # 6549W1S018C and if it's the culprit, you can get that for $24.84 from Tritronics, compared to almost thirty-two from Sears.
You should look again and see how loose the arm is on the shaft and which might be worn or warped or out of perpendicular. I think that one of these is the problem.
Dec 21, 2008 | Microwave Ovens
GE JES1139BL / JES1139WL 1100 Watts Microwave Oven Logo
156 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
