Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag electric Push the start button. Dryer will start with slight burning smell. If repeat this several times a sizzle sound begins and then the dryer willn ot start at all.
  • Anonymous Dec 15, 2007
    I have a Maytag Quiet plus ii with the same problem. It is 11 years old. Sounds like a bad starter switch
  • 89 Answers
Yes, I would replace the starter switch...Also, there is a relay next to the starter switch(behind panel) that may be on the blink.. Try switch first as they are cheap.. The Repay retails for around $50.00. Goodluck!
Posted on Dec 15, 2007
Maytag dryer sounds like it is going to start but wont start
could be that the belt is cut off , of the the puleys are jam .. does it make a big noise ( squeeky noise
May 12, 2017 | Maytag PYE2300AY Electric Dryer
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Maytag electric dryer. LDE9314ACE Drum won't turn, but sometimes will. Had friend turn drum manually while I pressed start/door buttons. Drum turned fine but when I let go of buttons to shut door, dryer...
The motor capacitor is burned. You can replace it yourself. It's on the motor. Take it down to a motor shop and they will have a new one. (electric motor repair shop)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 25, 2009 | Dryers
Wont start, smells like something is burniing
if its electric burning smell,its either a overheating motor,capacitor or both or burnt connections,sounds like a motor problem,it will be very hot to touch if its failing,check capacitor though as it could be causing motor to overheat,rating of cap is on side
May 27, 2009 | Maytag Dryers
When I push the start button on my maytag neptune dryer it sounds
MORE TIMES THAN NOT, WHEN I HAVE SEEN THIS PROBLEM, IT TAKES A NEW MOTOR TO CORRECT THIS SITUATION. MAKE SURE EVERYTHING MOVES FREELY BEFORE CONDEMNING THE MOTOR THOUGH.
Jan 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
KENMORE DRYER WILL NOT START
It sounds like the motor has burned up or is burning up is why you are getting that smell. There could at the same time be a wire that has come loose or burned off that is causing it not to come on.
Jan 26, 2009 | Kenmore 73952 Gas Dryer
Maytag Legacy Series Dryer will not start
Welcome,
Your temperature is to high and running wild . So the system has shut it down for safety reasons.
You need to call service for a diagnoses
if you do get it running, do not leave it unattended or better yet do not use it as is!
Send me the model number and I can send you the schematics!
Thank You for trusting us with your questions.
Huum
Please remember to leave a solved rating before you sign off!
Dec 22, 2008 | Dryers
Maytag mde9206ayw
HI WHEN YOU PUSHED THE BUTTON TO START DID IT HUMM IF IT DID YOUR MOTOR IS THE PROBLEM ESPECIALLY THE BURNING SMELL
May 24, 2008 | Maytag PYE2300AY Electric Dryer
Wont start up.
Sounds like the motor is failing. The main cause of failure is overheating due to clooged venting. Is the dryer taking more than 60 mins to dry?? If so then the vent is clogged. Its likely too that the motor is covered with lint and not being able to properly dissipate its own heat, you could clean it and see if it helps but usually once they are shutting down overheated (the burning smell is the motors' internal windings being very hot) they need replacement.
Nov 19, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
174 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
