Question about Microsoft Xbox 360 Console
3 red rings blinking
How can i stop it?
The three red lights blinking. How do you fix it without giving your console to the factory for however long they keep it? Has anyone been successful in getting the console back in one piece and fixed. I'm quite concerned about giving purolator my console and taking it to Texas free of charge to fix it and then they courier it back to me. Has anyone gone through this process?
Posted on Dec 15, 2007
The red light is blinking and when i turn it on it goes to green for a few seconds and then beeps and blinks red again.
You have "The red ring of death" If 1 corner is blinking: Turn it of and wait a few days for it to cool off. If 2 corners are blinking: Do the same, but check after 3-5 days to see if it works. If 3 corners are blinking: You HAVE to see a xbox repairer, because you can't wait after 3 rings. Saddly, a complete ring of red: You can't do anything about it, it can't be repaired, but check the power wire and reattach it, there's a little glitch where if you loosen the wire, it does that. Good luck!
Sep 04, 2011 | Sony Playstation 3 (PS3) Console
Blinking red light.Checked all cables. I replaced Hard drive...still problem exists. Wondering if power supply could be problem
When one light from the four lights ring itself changes from green to red, it means that a general hardware failure has occurred or is imminent. Blinking of one red light with an error message like E66, E67, E68, E71, E74 or E77 means a repairable problem while the one red light blinking without error message means some critical or irrepairable problem. The problem can be avoided by restarting the Xbox 360 console but if you have not received any error message with one blinking red light then the problem is irrepairable. The console will behave the same way and you should understand that one or more of the hardware components in your console have stopped functioning due to hardware failure. If you receive an error message with one red light blinking then the problem is reparable and the system will definitely start working. It means that there is some hardware problem with the Xbox 360 console connection occurring due to the misplacing of cables in the ports. Turn off your Xbox 360 and disconnect all cables, now reconnect the cables and switch on the Xbox hope this helps.
Dec 01, 2010 | Sony Playstation 3 (PS3) Console
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
3 blinking red lights
u my friend hav the 3 red rings it just means that u need 2 let ur xbox rest 4ahale ur lucky its not tha ring of death
Dec 20, 2009 | Microsoft Xbox 360 Console
I have three flashing red lights
You have the dreaded red rings of death the only way to fix it is to send it back to micsoft it will be free if you havent had it for less than 3yrs if not you will have to pay 120dollars.
Oct 27, 2009 | Microsoft Xbox 360 Console
Power button is blinking red
if 3 of 4 lights are blinking red, you have a red ring of death and need to contact microsoft. this is distubingly common on some of the older 360 models.
Jul 11, 2009 | Microsoft Xbox 360 Console
Night button and incoming calls
The programs involved with you ringing are 81 ( no light or Day Mode ), 84 ( blinking red light or Day 2 Mode ), and 87 ( solid red light or Night Mode ). To change the ringing assignments you need to know the port numbers of the phones you want to ring or not ring. You can do this by pressing DN/ICM dialing # 4 0 2 at each phone, the diaplay will show the physical and logical port numbers. These numbers will be used to turn on or off the aaociated lamps within the above programs. Do you have anyone on staff that understands the system programming ? Let me know ...Mike
Jul 17, 2008 | Toshiba DKT-2020 Corded Phone
Won't load game keeps blinkng red light
If the XBOX 360 is blinking the color RED in three of the four quarter of the ring around the power button, you will have to contact Microsoft for a replacement. This is what is known as "Red Ring of Death." You can find plenty of information on it if you Google it.
Click HERE for a video of the Red Ring of Death.
Click HERE for Microsoft's support system for the XBOX 360 and get in touch with Microsoft to get your replacement started.
It's the ONLY way.
Good luck.
Cyryl
Dec 10, 2007 | Microsoft Xbox 360 Console
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Blinking red ring
send it back to microsoft they will send you a new one
Oct 30, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
20 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
