Dell Inspiron E1505 Notebook Logo
Anonymous Posted on Sep 23, 2009
On opening dell inspiron 1300 screen stays blue mess
Open screen on laptop no proper display. fiddle about and screen appears
Anonymous
Level 3:
  • Master 3,940 Answers
  • Posted on Sep 23, 2009
Anonymous
Master
Level 3:
Answers
3940
Questions
0
Helped
1405213
Points
12062
2 things, reseat the video cable (Under keyboard), and tighten all screws in and around the hinge assembly (LCD Grounds through the hinges)
Testimonial: "i have yet to try this remedy.i need to know how to expose the cable at the keyboard.i have checked the cable at the screen end. thank you for your ad"
What is the process for resetting factory setting?
Press and Hold CTRL + F11 when you see the blue bar at the top of the screen that has www.dell.com (this will be soon after powering on the machine). It will then display "Dell Recovery by Symantec Ghost" or something similar. Choose the restore option and then follow through the prompts.
RE: DELL Inspiron 1300 Hello, Would a 14" screen
NO! it will fit in the opening but it will not have anything holding it in. So while yes it technically will "fit" it wont work as the screen will fall out every time you close it!
Blue screen
if its a blue screen without error message or any text, operating system cannot load properly. do a repair on operating system.
Dell Inspiron 1300 blank monitoe
the problem might be from the screen or from the screen inverter.
Connect your laptop to an external monitor and try again.
If there is a display, then its obvious that the problem is from screen or screen inverter of your laptop.
Good luck.
MY DELL 1525 TURNS ON AND THE NORMAL BLUE SCREEN APPEARS. THEN ALL OF THE SUDDEN IT GOES BRIGHT GREEN, THEN BRIGHT YELLOW, AND STAYS BRIGHT YELLOW
Please connect your laptop to an external monitor and see if the output is the same. If it displays fine on the monitor, then we are looking at either a screen cable problem or a screen problem. If the display is the same as on the laptop, then it is a problem with the display adapter on the mother board.
All the best.
1helpful
Dell inspiron 1300 display
Does this happen regardless of operating system state? (e.g. if you interrupt normal booting to windows)? You could try booting from e.g. linux live cd to see whether the issue is operating system-specific or if it's caused by a hardware problem.
I've seen very similar symptoms on several Thinkpad T41s where ATI graphics chips were failing, I hope it's not the case with your dell.
Good luck,
Raf
2helpful
Dell Inspiron 1300 - When I re-open the lid,Screen stays Black !
Your laptop either goes to hibernate or sleep mode when you close the lid. Then, when you open the lid up, the screen is still off because your pc already hanged/froze and could not wake up at all (usual problem in vista). Off course, hard shutdown would fix it. But actual fix is under power options on your control panel. Check your current scheme and edit it. There are options there that you can select to "do nothing when closing the lid"
Hope this helps
Vista is not letting things go away
It's sounds like it may be an issue with the screen refresh rate. From your desktop right click and select properties. Then select the display tab. From there, choose the option to reset to default settings.
3helpful
My Dell Inspiron 1300 wont start
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
6helpful
2answers
Dell inspiron 1300 back light problem
All laptops have a backlight and an inverter to power it, and the problem you have is very common. Usually replacing the inverter board in the display fixes the trouble. There are a number of vendors online offering replacement parts. Here is one that just popped up after a Google search. You can also find videos on youtube showing the procedure for opening up the display to install the new part. It's a simple process that most people can handle with a little patience and some small tools.
It's also possible the light itself has gone bad, but the inverter failure is more common. The backlight on some displays is not replaceable separately. So try the less expensive inverter replacement first.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
