Question about Lexmark X1150 All-In-One InkJet Printer
What plugs do i need for the printer, i recently moved and have no attachments now
    Scholar:
  • 150 Answers
I've got a 1180 & it looks as if you need a standard mains mains supply cable with a 2 pin socket - similar to those which fit stereo units and a computer to printer cable - one end usb and the other a device end socket to fit the printer at the back. Not all generic device cables will fit, you need one which fits the printer
Posted on Sep 23, 2009
KM-5050 Finisher not attaching, Why?
Make sure the connector cable from the finisher is plugged into the copier. Unplug the copier power cord first if you have to reconnect it.
Jul 13, 2014 | Kyocera Mita KM-3035 All-In-One Laser...
Ink cartridges will not move in place error # 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 - Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont...
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn't move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Jan 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
Kyocera KM-2530 printer displays "Attach Finisher." It was working until we moved it recently. Checked all cords and rebooted several times to no avail. Couldn't see any push rods or buttons that need...
on the copier metal bracket that finisher attaches far end or front ull see a metal pin that sticks out.
That pin goes in to the finisher white plastic hole.Inside that hole there is a switch that tells the copier the finisher is attached.
Oct 07, 2010 | Kyocera RI-3530 Black and White Copier
I recently moved and I lost my Lexmark Printers Plug that go's from the printer to the wall. It's the Lexmark x5495. I need to purchase another plug. Where can I get one????
It may be available in some electronic shops around your area. But I suggest you contact Lexmark Technical Support, for your convenience, to request for that. They can send you one for free. Just give them your contact info and the serial number of the printer. Hope this helps.
Jun 14, 2010 | Lexmark X5495 Printer
It wont print and everytime i try to print it says error #1200
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable2_bing.gif to reveal the gold screw beneath
7. Remove the ink cartridges2_bing.gif out of their carriage.
Figure 6 - Displays ink cartridge2_bing.gif carriage with ink cartridges removed.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
9. Lift the front cover open (if not already open) and plug in2_bing.gif the X4270. Cartridges should move to center as if preparing for replacement.
Click Here for the Documents
May 03, 2010 | Lexmark X4270 All-In-One InkJet Printer
Re-install my printer
gives this a shot unplug the usd or whatever plug you have to the computer and thn unplug the power to the printer
then restart computer . then plug everything back in but plug in power plug furst. i hope this works
Feb 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Plugging in my lexmark z708 printer
Z 705?
Can't find you model number. Download a manual from the Lexmark website below.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Jan 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Mini USB disconnected inside HP all-in-one 2210v psc
You will have to take the printer apart and re-solder the usb connector to the board.
it was jerked out likely by moving the printer while it was attached to the cored or was tripped on.
it may not be an easy job to fix as you have to have several tools
and soldering skills,
you need a electronics nerd to help.
Feb 02, 2008 | Office Equipment & Supplies
Lexmark X1150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
