Question about Motorola Mobility RAZR V3
I have bootloader screen how do I get my phone to reboot itself?
Power button broken
Use this app: Button Savior (non-rooted version)
or if your phone is rooted: Button Savior (rooted)
It puts a customizable menu on your screen which you can have always there, or set whatever gesture or button press to bring it up. One of the button options is the power button. It also has options to use the volume buttons to "wake" the phone. Just don't let the battery die unless ur phone turns on automatically when u put the battery back in. Button Savior was working great for me on a previous phone... till I let the battery die once... couldn't turn it back on w/out a power button, lol.
Note: if u are rooted and ever need to get to the bootloader screen or custom recovery (normally done w/ some combination of holding the power button and one of the volume buttons). You can still get to them using command prompt commands on ur computer: cd /(file name your platform-tools folder is in)/platform-tools *press enter*
adb reboot bootloader (but u won't be able to select anything w/out the power button, lol) OR adb reboot recovery
Nov 30, 2013 | Android Cell Phones
My htc evo will not start up. I have a white screen with three androids on the bottom and at the top it says supersonic evt3 ship s-on hboot-2.02.0000 microp-041f touch panel-atmelc03_16ac...
this happens when you have one side button jammed, look for the jammed button and press it many time to relese it,
regards
please comment
Jan 01, 2011 | HTC EVO 4G Smartphone
I'm getting a bootloader usb init screen
Your phone is partly fried. It needs to be re-flashed. You can do it with a USB cable and the proper software....Google "bootloader USB" for some help in finding the software. One thing to try, hold down the "*" and "#" keys while powering up the phone, this could possibly help, but I doubt it.
Good Luck!!!
Apr 24, 2010 | Motorola Mobility RAZR V3c Cellular Phone
Bootloader usb init
hold the end key(power) and it should restart back to normal. If it goes back into bootloader then your phones software could be corrupt or could have a wrong value in somewhere. What provider is this?
Jul 23, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Bootloader usb init
This means that the phone firmware is corrupt - you can try to reflash it using Motorola software update, but it might not work for a phone stuck in bootloader mode:
https://rsddownload.motorola.com/download/Motorola_Software_Update.exe
Jul 01, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Bootloader usb init motorola ve465
My motorola cell phone model ve465 has the following problem that won't clear itself...
Screen has motorola logo and bootloader usb init on the screen and won't let me clear screen so phone will work
May 18, 2009 | Motorola Cell Phones
Bootloader usb init
basicly the software is corrept.take it 2 a cell 4ne repair shop they will fix it it cost about 150.u cnt do it on ur own coz it takes a specail soft ware n only certain ppl have it
Jul 28, 2008 | Motorola Mobility RAZR V3
Iphone bootloder
Hi Raj, all is not lost, the thing is i would need more info of what you were trying to do before this happened.
but a solution that may work is attempt to get into the bootloader mode of the iPhone. Hold Down power button + Home button for like 10seconds. This should then get you to a yellow triangle screen or just a blank screen.
Download a copy of iBricker. Connect the iphone to the pc, run iBricker, there should be an option of boot/reboot the phone. this should be able to get the phone in a state where you can restore the firmware.
else if you on the bootloader mode ( the Yellow triangle) you maybe able to get iTunes to recognise it and allow you to do a restore on it
Dec 03, 2007 | Apple iPhone Smartphone
Motorola Mobility RAZR V3 Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
