Question about Samsung YP-T8 Digital Media Player
MP3 PLAYER WILL NOT TURN ON
It turned on at one point,and did not use it for about 2 years, because I did not have the usb cable. I bought a new one, and connected it to the computer so that it can recharge and I could download music. But it does nothing at all. Computer does not even recognize it , I don't get the icon at all. What have i done wrong?
  • 1 more comment
  • richard39 Dec 27, 2007
    i have the exact same problem, it turned on at one point but i never used it for a couple of years and i finally got a usb wire and hooked it up but nothing happens but i dont have a charger only the usb wire, what do i do? i cant find a store that only sells the charger it self
  • Anonymous Dec 29, 2007
    wont come at all.
  • richard39 Dec 30, 2007
    no nothing at all
Try to recharge it at the charger not at the computer,and when it is full charged plug it into computer
Posted on Dec 25, 2007
How can I unlock my phone
- Unlock all Sony Xperia 2010 Year (under test, private only)
- Unlock all Sony Xperia 2011 Year( with Test Point) (under test, private only)
- Flash All Sony Xperia/ Sony Mobile Android based mobile phones
- First in the World: Read Trim Area from Running OS via ADB( Android Debug Brigde, ADB - included)
- First in the World: Write Trim Area from Running OS via ADB (Android Debug Bridge, ADB - included)*
- Trim Area Backup Read using ADB/BootLoader(for test or Security reason)*
- Trim Area Backup Write using ADB/Bootloader**
- Single Trim Area element Read/Write*
* Not all TA elements can be written or read and not all Platforms support it.
** Not all TA elements can be written or read.
!!!Software require Internet Connection for all operations!!!
download tool
http://www.mediafire.com/download.php?7gede2no6nsccvd
Usage:
!!!IMPORTANT!!! Before any operation with any new phone - Back it UP! Later
you can restore it if somethings gone wrong.
A) To read/write Trim Area
using ADB:
1. Connect your phone to PC using USB Cable.
2. Enable USB-Debugging in Settings->Development menu
3. Install drivers
4. Go to TA work tab, click ADB in the software and press Connect.
If you need to Cancel you can click cancel to stop operation
5. Wait software to check root in your phone and try to root it.
6. If your phone is not rooted you recieve a message how to root
your phone.
7. Click Backup TA. All your TA will be backed up and saved in new
folder, same as your imei number
8. If you need to restore phone - click Write TA from Backup
9. If you need to read/write single element: enter element number in
heximal (for example 7da) and press read/write
9a. Upon write operation you will be asked to open the file to
write, so please be ready for this file to open.
using BootLoader:
1. Training: Connect phone in Flash mode (Hold the back (or the
Volume down in new 2012+ phones)) key and connect the USB cable.
2. Install drivers (x64 or x86)
3. Check if driver install ok
4. Disconnect phone
5. Go to TA Work tab and click Bootloader
6. Click Connect button. If you need to cancel you can click cancel
to stop operation
7. Connect phone in Flash mode (Hold the back (or the Volume down in
8. After successfull connect Click Backup TA (for your security)
9. If you need to restore click Write TA from Backup
10. If you need to read/write single element: enter element number
in heximal (for example 7da) and press read/write
10a. Upon write operation you will be asked to open the file to
B) To flash a S1_Boot android phone
1. Go to Flasher tab
2. Follow the procedure 1 of the read/write TA using BootLoader
(Traning)
3. Click Open firmware (acceptable formats: zipped firmware bundle,
with loader.sin inside), file format - zip or 7z (7-zip)
4. Select files to flash(eg. 1 file or All files)
5. Connect phone in Flash mode (Hold the back (or the Volume down in
6. Install Drivers (x64 or x86 - according your system OS)
7. Stand by, software detect phone and send the loader.sin from the
archive
8. Click Flash when phone is connected and software hint says "You
can press the Flash button now"
8a. Keep in mind, the system.sin takes longer at 99%, this is ok,
need wait.
C) To unlock phone
without Test Point (2010 phones only):
2. Install Drivers (x64 or x86 - according your system OS)
4. Disconnect phone
5. Enter your user id and password
6. Click unlock
8. Follow the on screen instructions (some phones require one or two
reboot).
with Test Point:
4. Disconnect phone
5. Connect the Test Point.
7. Keep the Test Point connected
8. Click Unlock
9. Stand by.
9a. Longer in description faster in process about 20 seconds.
Apr 19, 2016 | Sony Ericsson XPERIA X10 Cell Phone
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
MATCHING CABLES FOR A IOMEGA LPHD-UPC
Use a USB 3 cable it will provide more usb throughput
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
Jan 24, 2013 | Iomega 500GB Prestige USB 2.0 Portable...
Will not start or make any type noise or try to turn over at all
What it sounds like is a lose connection or bad ground cable. Check both battery cable leads red or positive to the starter. If you have a meter or test light check voltage at the starter. The check black or ground cable from Battery to point of ground. If rust or poor connection clean cables. Not knowing make model year. Look once you have all connections clean for a main fuse. This could be spade or glass type. What your describing is lack of charging of batter [lose of power slowly] and not able to start bad connection.
May 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
HP DESK TOP 840C PRINTER CONNECTION
They do make adater cables for such problems. Here is just one such example: Parallel to USB Cable
Make sure you get the correct 25 pin cable. They have this type also:
Parallel to USB Cable 2
You can search the web for more companies. Google parallel to usb printer cable.
After saying all that and checking your printer info, I see that the 840c has both a parallel and a USB cable port. See page 21 of the manual: HP 840c Manual
If you go that route, you will need a standard USB cable. The shorter the better, but no longer than a 6' cable. Make sure you follow the iinstallation instructions for the USB setup in the manual.
Thanks for using Fixya.
Apr 14, 2010 | HP DeskJet 840c InkJet Printer
RCA opal 4g mp3 player - bought about 2 years ago - the power/transfer(?) cord is usb on one end and mini plug on the other end. My 2 computers do not read it anymore to charge the unit or to download...
if its mini usb then you can get that cord just about anywhere if its a custom cable then you'll have to goto the rca website and order one from them
Sep 25, 2009 | RCA M4204 MP3 Player
How do I download Pictures to MP3?
A generic procedure is :-
  1. Turn on your computer. Plug the USB cable that came with your MP3 player into an open USB port on your computer.
  2. Step 2 Turn off your MP3 player and plug the other end of the USB cable into the USB port located on top of the player. Turn on the player.
  3. Step 3 On your computer, right-click the pictures you want and select "Copy" from the menu that appears.
  4. Step 4 Double-click the "My Computer" icon on your computer. Double-click "MP3 player " or ' MP3 Device" in the "My Computer" window.
  5. Step 5 Open the "Pictures" folder. Right-click and select "Paste" from the menu that appears.
  6. Step 6 Let the files copy. Click the "Safely Remove Device" icon located on the left side of the Start toolbar at the bottom of your screen.
  7. Step 7 Click "Safely Remove USB Storage Device." Wait for a message to appear that says it is safe to remove the device, and then unplug the USB cable from your computer and your MP3 player.
Hope i helped you.
Thanks.
Aug 30, 2009 | Audio Players & Recorders
Can't re-load hp photosmart 7150 on windows xp. Gets to the point where the installshield should come up, lingers awhile, and then says check printer power and usb connection. The computer has already...
1.It could be the USB cable. Try a new cable.
2. Could be USB port, use another if available
3. You should be able to install the software without the printer connected.
4. Uninstall all hp printer software, and restart computer.
5. Delete any instances of the printer from the printer/fax located in control panel
Apr 15, 2009 | HP PhotoSmart 7150 InkJet Printer
GPX MW-3847 MP3 Player How do i disable write protection
If you have an mp3 player like the one shown in the picture, then just flick the hold switch on, then flick it again to off. This should work. It worked for me.
Jan 28, 2009 | GPX MW-3847 MP3 Player
My HP laserjet 1018 doesn't work
first of all remove the power cable and rmove the usb connection or  parallal connection from the pc. Then conneted the power and usb cable. you need to open the case to remove the printer cartise. and add the cartise. Start your pc. give print command.
Jan 23, 2009 | HP Hewlett Packard LaserJet 1018 Printer
Samsung YP-T8 Digital Media Player Logo
79 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
