Question about Motorola Mobility RAZR V3
Blue backround big M, bootloader usb init txt
Pissing me off and I need help, the phone wont stay on unless its charged and that blue screen is the only thing that i can see.
Screen is blue motorola logo says bootloader usb init when try to shut off black screen says verizon tried taken battery out same problem. Thanks
Your phone is starting in flash mode..You need to have either p2k phone tools or motorola phone tools..you can get them from www.modmymoto.com. once you have the software on your PC connect your usb cable and reload your phone
May 11, 2010 | Motorola Mobility VU204 Cell Phone
I'm getting a bootloader usb init screen
Your phone is partly fried. It needs to be re-flashed. You can do it with a USB cable and the proper software....Google "bootloader USB" for some help in finding the software. One thing to try, hold down the "*" and "#" keys while powering up the phone, this could possibly help, but I doubt it.
Good Luck!!!
Apr 24, 2010 | Motorola Mobility RAZR V3c Cellular Phone
Blue screen with " bootloader usb init" message
go to service center. need to be reprogram. tnx
Jul 28, 2009 | Motorola Mobility RAZR V3
Bootloader usb init
This means that the phone firmware is corrupt - you can try to reflash it using Motorola software update, but it might not work for a phone stuck in bootloader mode:
https://rsddownload.motorola.com/download/Motorola_Software_Update.exe
Jul 01, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
BOOTLOADER USB INIT - BUT PHONE WON'T COME ON.
you need to take the phone to a mobile service center and have them reflash the phone to have it working properly
May 29, 2009 | Motorola Mobility RAZR V3
Stuck on blue bootloader usb init screen
You will have to do what is called flashing your phone.
There is a complete guide located here that will reinstall your phones software
Clicky
Jan 27, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Bootloader USB INIT
Get this Phone reflashed. Of course if you Dropped the Phone or if it went into water then Forget it about spending 35-50 Bucks on reflasing this phone. because it will go back to Boot Mode.
Sep 06, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Bootloader usb init
basicly the software is corrept.take it 2 a cell 4ne repair shop they will fix it it cost about 150.u cnt do it on ur own coz it takes a specail soft ware n only certain ppl have it
Jul 28, 2008 | Motorola Mobility RAZR V3
Blue screen Bootloader usb init I was charging my phone and when I went to use it I couldnt the screen was blue with the Motorola symble and it read Bootloader usb init I have tryed removing the battery...
take out the battery and sim card and youwill see a metal bended thing beside of the sim card insert placing not on it on the right hand top press it down or bend it and your phone will reset your memory of your phone will not be erased
Apr 12, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
13 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
