Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
Power supply problem used a replacement.it would light up for a second and pop. can i replace something drive s/b fine just need powering up. currently on 220v 50cy.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
The drive inside is a standard hard drive, you may be able to plug it into a computer to get the data off it. i would contact maxtor for a replacement unit.
Posted on Sep 23, 2009
My TV screen went out while watching, but the sound remained. At first, turning it in and back on would help. Now the screen won't come on at all except for a brief second when the LG screen pops up.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 23, 2015 | LG Electronics 50LN5700 50 Inch LED LCD
Vizio 50" Plasma Does not power up
there are two items in there..power supply board and system control board..I recommend replacing them both.
there's a group, called WACA that handles this, that might be able to sell you those parts..let me get their information.
Mar 27, 2008 | Televison & Video
Samsung ft-p5084 plaza tv went blank. No power at all.
If that fuse is blown chances are its because the Power supply has developed a short. The power supply will need replacement. You can easially install a power supply yourself just a few screws and couple of wire sockets and the old board pops right out. You can get the power boards from www.tvcircuitboards.com
Feb 09, 2013 | Samsung FPT5084 50 in. Plasma HDTV
I heard a loud pop while comp was on -it shut down. Now blue power light wont come on --something with the power supply. If it is fried is it easy to replace? I have HP p6774y
The pop was probably a capacitor exploding and yes they are easy to replace. All of the power connectors are keyed so they only fit one way.
Here is a good guide with pictures on the whole process. Your computer won't deviate much from this. http://www.hardwaresecrets.com/article/362
Any power supply should be fine, you can pick one of from a best buy. 300Watts+ should be more than adequate.
Or pick one up cheaper online I prefer newegg.com
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007657%204093&IsNodeId=1&name=%2410%20-%20%2425
Here you can pick one up for as little as $12
Aug 04, 2011 | Computers & Internet
Pc wont boot up, instead a red light flickers.
Flickering LED means power supply is overloaded with something. It might be inside of the supply, but sometimes it is something else. Try that:
1. Disconnect everything from the motherboard except power supply and power button;
2. Disconnect all power connectors from all drives;
2. Remove any cards from the motherboard so all you have is power supply and motherboard with CPU and RAM, nothing else. You can keep connected the monitor and keyboard;
3. Press Power button. Will motherboard turn on normally?
If no - check electrolytic capacitors especially around the CPU, if some of them are "popped" replace them.
If yes - connect drives and cards one per time to localize the problem.
Sep 14, 2009 | Compaq Evo D500 PC Desktop
Gateway 200arc motherboard problem
If there are two wires running from the power button on your case to the motherboard, take them off and try jumpering those two terminals with a jumper or something that will make contact for just a second and them take back off. Your power button may have fried along with the power supply.
May 18, 2009 | Gateway Refurbished $30 P1 TO USA - BOARD...
Dell Inspiron 5150 Will not turn on......
had same problem, thought changing power jack would solve problem, but, it turns out the power supply is the problem,, works great with another dell ps
Jan 03, 2009 | Dell Inspiron 5150 Notebook
Hard drive will not power ON
I have had my own experience with Western Digital and their policy is to not sell or provide parts in order to replace damaged parts in an otherwise functional device.
Your options would be to send it in to WD for a repair and strictly a repair. They may replace the power supply.
The other option is to buy a used/off-market case or power supply which matches your drive's supply.
I had a harddrive burn a hole through one of the interface chips on the bottom of the HD and was told there was no way I could get it repaired or recover the data as it was. However, I found an exact match for model and type of the drive and a near enough year to the one I had and exchanged the interface boards on the drive, and I'm using the drive today as my main boot disk.
All you need to do is replace the power supply. Try Ebay for your external drive model number, there may be cases with no drives which you could buy that have functioning power supplies, or power supplies alone.
If all else fails, you can do what I did - buy another, matching product, exchange the broken part from the new one you get with the old one, recover data, and swap the power supply back again, then send the old drive to WD for replacement. You can attempt to resell the RMA'd (returned to WD drive) on amazon/ebay and use the new one, or keep the new power supply in the old device and use it, and sell the drive out of the case, or keep the drive and use it. I expect the drive inside the external case should work as a normal drive.
Dec 16, 2008 | Western Digital 500GB My Book Pro-External...
Technic 1200 mk2 turntable wont spin
need to know if it powers up. Does it try to spin, do you hear it trying to spin? More than likely the on/off switch went bad. No, I am not referring to the ON/OFF knob. THere is a switch this engages when turned. The part is S601. You might also want to replace the Start/Stop switch as well. If neither work, then the issue is on the main PC board, and probably IC101, or IC201 with the problem. At this stage, you will have to have a service tech look at your unit.
Oct 19, 2007 | Technics SL-1200MK2 Turntable
Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
114 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
