Question about Refrigerators
Ice maker trap door does not close tightly, ice cubes become one big cube and water drips from the ice cube trap door. need some adjustment to this door so cubes do not melt and water run out of storage and keep cubes loose in the ice bin.
  • Mike Smith
    Mike Smith May 11, 2010
    Due to the many different models and brands of refrigerators , access and operation of the dispensor controls , differ many times over . If you could return with the brand and model number , either myself or another fixyx expert , would be glad to help .
  • 4,059 Answers
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
There is a solenoid that operates the door that could be sticking.
The hinge on the door could be broken or the bracket it goes in could be broken.The spring could also be off or broke. You'll have to look to see what's wrong.
Posted on Sep 23, 2009
  • 27 Answers
SOURCE: Water leaks into storage bin
open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
Posted on Jun 24, 2008
jumptrout51
  • 3361 Answers
SOURCE: Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
Posted on Mar 03, 2009
  • 531 Answers
SOURCE: ice maker not making ice- water leaking or cubes melting
icemaker have problem
Posted on Apr 06, 2009
Sea Breeze
  • 4654 Answers
SOURCE: cubes won't dump into the storage bin
In photo below you can see the heating element that comes on moments before the ice maker drops the ice. If not working then the icemaker will struggle to unload. You need to unplug the refrigerator and then unpluge the ice maker and remove it to test these parts. Test with a multi meter or ohm meter. Test the 2 connections next to the number #26. Hope this helps, Sea Breeze
Posted on May 21, 2009
SOURCE: Symptoms: Ice cubes melt, drip then refreeze causing
are you having any cooling problems? take a look at your ice cream, if you have any. does it look like it has melted and refrozen? if so, you have a cooling problem, and that is causing ice to melt, then refreeze. if you have no cooling problems, then you may have a faulty water valve solenoid, or even a faulty icemaker.
Posted on Feb 15, 2010
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Hi have LG fridge, ice maker making ice but freezes into one solid block instead of staying in individual ice cubes making it impossible to dispense do you have any ideas a sto why this is happening and...
Sounds like this is a water level problem. Too much water is being released into ice tray, which raises the water level above the depth of each cube form, causing one big cube. You can adjust the water level.
Check this out:
How to Adjust the Water Level on an Ice Maker eHow
Jul 19, 2014 | LG LSC26905TT Side by Side Refrigerator
WATER DOESNT SHUT OFF AFTER ICE CUBES ARE MADE- THEN THE CUBES BECOME ONE SOLID BLOCK FROM THE DRIPPING WATER. SERVICE GUY SAID NEED TO REPLACE THE ICE CUBE MAKER: STRANGE THE ICE CUBES ARE PERFECT -...
Replace the water inlet valve to the unit. The valve is not closing completely after the water is called for. By replacing the valve should solve this issue.
I hope this helps.
Sep 12, 2013 | Sub-Zero Refrigerators
I have a Kenmore Elite side-by-sr ide refrigerator Model 106. The ice making system is putting too much water in the ice tray, making the cubes too big. These large cubes are clogging up the dispenser. ...
With out the full model number it is hard to say. Most 106 model referigators have a modular ice maker. If you take the cover off of the front of the ice maker and look on the right hand side of the motor module you will notice a small plastic adjustment screw. If you turn this screw you can adjust your water fill time to the ice maker.
Sep 01, 2011 | Kenmore Refrigerators
The Ice maker does not make cubes.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Feb 06, 2010 | Refrigerators
Ge monogram fridge over freezer model has stopped making ice
water valve dripping like a faucet and making a big old ice cube in the fill tube? Ice cube hung in the ice maker? bad water filter? A wittle bit of all of the above?
MONOGRAM MANUAL
IM6 notes
Bonus
Jan 12, 2010 | GE Refrigerators
FROST BUILDS UP IN ICE CHUTE FROM STORAGE BIN, AND BUILD-UP BLOCKS RELEASE OF CUBES....ALSO WATER LEAKAGE OUTSIDE LIKE WARM AIR IS COMING UP FROM OUTSIDE...
As a suggestion:
Check the trap door that opens and closes each time you obtain ice cubes. The water leakage may indicate a damaged seal allowing air from outside to enter. This will cause increased frosting and blockage.
The trap door may not be closing all the way or the magnetic seal around the freezer door may be damaged or not sealing completely.
You may also need to check the thermostat.
Temperature may be set too low. If you make an adjustment allow the unit to stabilize for 12 hours before attempting another change.
Oct 04, 2009 | GE Refrigerators
Ice maker makes ice cubes, but the doesn't dispense ice cubes.
If you could observe exactly where the water is dripping from it would help but...If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Aug 19, 2009 | Refrigerators
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My jenn air freezer is not making cubes. the
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 13, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Refrigerators Logo
174 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
