Question about Acer Aspire™ T180 PC Desktop
The Acer X1700 desktop suddenly stopped booting.
The computer suddenly stopped booting. Power comes on for one second then turns itself off. No beeps are heard. It is possible to open the DVD drive during this second.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 153 Answers
I would check your power supply. take it to a local computer shop. or call acer for warranty support.
or if you are running on a backup ups, plug the computer directly into the wall and try it again
Posted on Sep 23, 2009
Testimonial: "Thank you. Will take back to shop for warranty repair as 2 months old!"
The problem was simple. The on/off switch was stuck in down position. This prevented PC from starting up after the basic one second check. Opening the case and pulling up freeded the switch and it then works perfectly. Easy eh?
Posted on Mar 12, 2012
My computer turns on by itself and does not display anything
disconnect the power adapter and battery
2) make a HARD RESET 3) press the button power and hold by 60 seconds.
3) connect the power adapt +battery and try again.
4) if the problem persist. test the power adapter for short and repair or replace.
restart pressing the f8 and go safe mode with network, and RUN the scannow.
5) Run the software coming with the computer.too
God bless you
Mar 25, 2013 | HP Pavilion a264w PC Desktop
Acer power 1000 will not turn on
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted,but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static ChargeBuildup. Remove the Power Cord, then Press and Hold the power button for30 seconds. After 30 seconds plug the power cord back in and hit thepower button to see if it boots.
Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
May 11, 2012 | AcerPower 1000 (AP1000EA380M) PC Desktop
Acer aspire x1700 black screen, makes high pitched noise, doesn't respond
You may have damaged or dislodge a component.
I suggest you remove the cover and reseat the RAM modules and all the cards in the expansion slot (unscrew them pull them out of the expansion slots and insert them back then secure them with the screws.
If it still does not boot up then you need to take the computer to a computer repair shop.
Mar 11, 2012 | Acer Computers & Internet
My tower beeps when i turn it on i have unplugged all the cords, transferred it to another power point and it continues to do this it beeps for 2 seconds and then beeps for 5 seconds and then pauses for a...
Try turning it off from the wall open the case and remove the ram (memory sticks ) from the mother board if there is one stick carefully clean the metal contacts with a new white eraser and reinstall it (if there are two sticks only replace one stick at a time ) if it boots with one stick then this was the problem if it doesnt boot and you have two memory sticks swap them and try again if it boots this time try shuting it back down and replace the second stic if it stops working again remove the faulty stick and replace it with a good one .(make sure you turn the computer of and unplug it every time you remove the memory .
I hope this helps Andrew a
Apr 07, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
Acer X1700 won't connect to monitor; monitor doesn't get signal from computer.
Is the monitor getting power? Does the power button light up? Check all your connections. Power from wall to monitor. Video cable from PC to Monitor. Do you have another computer or laptop you can try plugging into the monitor? If two machines don't work on the same monitor, it's either the monitor or the video cable itself.
Hope this helps! If so, please give a rating!
Mar 08, 2010 | Acer Computers & Internet
When I power up my acer PC I get a beep beep beep
Open your cpu cabinet cover.
Then Refix RAM memory on mother board.
Remove pci cards from mother board if any.
Make sure motherboard is not ground with cabinet.
Reattach ATX power connector to motherboard.
Pull cmos cell from motherboard for 10 minutes then refix it .
Then it work again.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 06, 2009 | Acer (AST135-U-S3100) PC Desktop
Booting problem
DEAR,
AS PER YOUR PROBLEM I THINK YOUR COMPUTER WORKING WITHOUT ELECTRIC EARTHING. PL FIRST COMPLETE EARTHING WITH ELECTRICIAN.
YOUR EARTHING IS NOT PROPERLY PL CHECK THAT:-- ELECTRIC SHOK ON PC BODY.
YOUR PROBLEM WITH POWER SUPPLY OR PROCESSOR,MOTHERBOARD.
PL FIRST CHECK POWER SUPPLY,SECOND CHECK YOUR PROCESSOR WITH ANOTHER PC MOTHERBOARD.
Feb 25, 2009 | Acer Aspire™ T180 PC Desktop
Acer Aspire L310 - Will not boot, will not beep
remove the power cord from the back and take the side panel off, take the memory and out clean the modules and the slots that they go into, if there is more than 1 put them back in 1 at a time rebooting the pc each time to see what happens
keep me informed
regards
Nov 22, 2008 | Computers & Internet
Acer Aspire™ T180 PC Desktop Logo
578 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
