Question about White Sewing Sewing Machines
White Might Mender ww200 issue with bobbin thread
The White Might Mender ww200 instruction book does not describe how to correctly get the thread from the bobbin to be threaded to have the needle pick it up
SOURCE: needle picks up bobbin thread but then thread gets stuck
I had exactly the same problem on the exact same model 3205FA. I'm not an expert, but have a little experience on solving my wife and daughter's sewing machine mechanical problems. I would suggest the following: A. Page 6 of the owners manual see item # 1...to be precise it is 1 1/2 times around. B. Page 7 at the bottom, Make sure the bobbin tension spring is set so that there is tension. When holding the tread the bobbin shouldn't unroll. If jiggled about 2-3 inches the bobbin should release about 1/3 of that distance. C. Page 8 at the bottom, ill. # 2. There are two flange holders and screws that hold the bobbin case in position located at about 5 and 7 o'clock. Make sure both screws are tight. This is important. D. Make sure the thread is treaded through the upper tension adjustment properly. See page 9 # Illustration C. Terrible illustration. Keep the dial generally in the green range. E. Put in a new needle, the needles that come with the machine are just short of terrible. Wouldn't hurt to buy good top quality needles for the machine.
Posted on Mar 14, 2007
  • 5 Answers
SOURCE: needle will not pick up the bobbin thread
www.whitesewing.com try there web site
Posted on May 29, 2007
bargainbox
  • 1388 Answers
SOURCE: bobbin threading
You may have put the timing out, however, try this before you despair too much......
Ensure the presser foot is firm enough for the fabric you are using and that it will not just pull through easily by hand with the foot and feeddogs together (as the needle ascends), or things will not proceed, and you will be stitching in the same spot.
Generally a setting of 3 seems to work for general purposes, but if you are using very light or very heavy fabric, a sample is always a good idea before you start in earnest....also match the needle to the work for best results.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 10865 Answers
SOURCE: How do you thread a Mighty Mender WW200 sewing
http://www.whitesewing.com/products.asp here is the website for the company which makes your mighty mender. you will see a number there for their customer service rep. give them a call, nothing like getting the answer direct. let me know how you make out.
Posted on Jun 14, 2009
Need help with my mighty mender ww200???
Hello, Christal -
What kind of help do you need for your White Mighty Mender ww200 sewing machine? You can add details by choosing Comment and typing what kind of help you need.
In case you do not already have the instruction manual for the machine, you can download the manual (PDF version, free - Adobe Acrobat Reader software needed - free) here:
http://www.singerco.com/uploads/download/953_ww-200-x-.pdf
The instruction manual has a Toubleshooting section on Page 10 (image 11).
Best wishes.
Apr 06, 2018 | Sewing Machines
Ok how can i get my mighty minder ww200 to work
Hello, Christal -
See my answer to the second time you asked about your White Mighty Mender ww200 sewing machine:
http://www.fixya.com/answer/answerpageslideview.aspx?thid=26938238&ctg=164
Best wishes.
I need an instruction manual forthe Mighty Mender 200 Sewing Machine
Hi
You can download one free from the Singer site.
http://www.singerco.com/accessories/manuals.html
Just type in ww200 and click on search.
On the next page click on free download!
Hope this helps!
Nov 14, 2010 | White Sewing Mighty Mender WW100...
Lost my instruction booklet, don't know how to operate. ww200.
You can download a manual from the Singer site.
Hope this helps!
Nov 06, 2010 | White Sewing Mighty Mender WW100...
For the White Mighty Mender W100 sewing machine, how does the bobbin thread come up to join the needle thread?
Same as with all machines essentially.......
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Aug 30, 2009 | White Sewing Mighty Mender WW100...
How do you thread a Mighty Mender WW200 sewing machine?
Jun 13, 2009 | White Sewing Mighty Mender WW100...
Bobbin holder doesn't spin
Be really sure that the thread is threaded properly. Correct size needle for the material, and no cheaper thread. It does make a difference.
Aug 22, 2017 | White Sewing Mighty Mender WW100...
White W100 Mighty Mender Sewing Machine Instructions
I have the "mighty mender" instruction book you are looking for everyone !! Happy to help all you sewers out there!
http://www.hammerwall.com/Download_Manual/70097/
Apr 10, 2008 | Brother SE-270D Computerized Sewing...
Loading the bobbin and adjusting the tension.
Loading the bobbin for this maching is fairly simple. First thread the machine. Then after placing the bobbin in the machine pull the thread out through the first notch and back through the second. (The end of the thread should be going in the direction of the little channel on the left side of the bobbin area.) Now what I did was make a loop with the end of the thread and pushed it under the casing below the needle. Then if your machine is threaded correctly you should be able to turn the knob on the right side of the machine so the needle goes down and comes back up once. If you've done it right the bobbin thread should come up in the correct spot.
Apr 03, 2007 | White Sewing Mighty Mender WW100...
Open Questions:
Sewing Machines Logo
56 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
