Question about Philips 50P8341 50" Rear Projection Television
PHILIPS 50P8341A COLOR PROBLEM
IT HAS TO MUCH BLUE AND RED.CAN ADJUST RED WITH THE CROSSES.THE BLUE WILL NOT MOVE AT ALL.COULD THIS BE A CONVERGENCE PROBLEM AND IF SO PLEASE GIVE ME THE STEPS TO FIX THE PROBLEM.
THANKS
JENNIFER
  • 8 more comments
  • DR J Repair Jan 02, 2008
    Cannot get picture adjusted
  • johnnydo Feb 26, 2008
    to much red or blue
  • wildcat1 Mar 13, 2008
    i cant get the color adjusted by using controls to much red and yellow images i have tried setting everything but nothing seems to work
  • Ryan Ford Jun 28, 2008
    picture is blurry, too much red and blue, cannot change blue convergence
  • Anonymous Dec 01, 2008
    color problem
  • mpersley143 Dec 11, 2008
    There's to much color in the tv, I've tried to adjust the color and tried to adjust tint as well as the other features but the tv will not do anything. It's almost like blurry but not quite like that, you can see the tv it's just annoying to watch. It also cuts off on it's own but it always comes back on.
  • jbarajas39 Dec 22, 2008
    There is to much blue and cannot see the face that will..
  • Anonymous Jan 25, 2009
    I have the same problem I can't get the red , blue, and white fixed
  • Anonymous Apr 15, 2009
    The color of my tv is totally messed up. I dont know how to make the color back to normal. Is there a way to set the brightness, color, tint, and sharpness back to default??
  • RodneyValerie Teston
    RodneyValerie Teston Nov 25, 2013
    how to adjust the convergence
    President:
  • 4,402 Answers
Http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 15, 2007
I repaired many of those tv's, you probably need to relplace the picture tube coolant. The coolant is kinda tricky to replace, you should remove the whole picture tube out before trying to remove the bad cooland or you might dump the coolant onto the circuit board, there are three picture tubes. Ususally the red one doesn't need to be replaced, good luck.
Posted on Jan 19, 2010
I have a PHILIPS 50P8341A & the color is so dark. I tried adjusting the color but still no change .Please tell me if this can be corrected?
Posted on Jun 05, 2009
I have a Sony KDP-57WS550 TV that has a convergence problem. Based on the symptoms, I'm not sure whether to indict the convergence ICs. In the convergence mode, I can move the red (and blue) crosses,...
With your TV in setup Use a small magnet to "move" the non converged Red, Blue, or, Green color lines "crosses" (each CRT will need to be adjusted in turn) by moving the magnet close to the offending Red, Blue or,Green color CRT yoke or, tube while observing the movement of the CRT color line "cross" in a mirror ( try several places near the tube and, several strengths of magnets:) a refrigerator sheet magnet works well (you can cut these with a scissors to make a better fit or, apply less magnetic "pull." by making them smaller (you may need more than one magnet per tube to fix each CRT's convergence) When you have each CRT tube's convergence right, apply some clear silicone adhesive to the magnet and, permanently affix the magnet to the now "fixed" CRT tube exactly where you placed the magnet to obtain the best convergence on the CRT.
(Do not adjust the "Green" CRT unless you must, as it is used as the color line to adjust other lines to)
Jun 30, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
Philips 50p8341a - the red converges, the blue does no move. the screen is all reddish with orange lines in it. the sound is ok. took the back off and the red and blue big lights are on, but the other big...
Hi, convergence IC`s have failed, set is usually a good one, call your local tv shops and get a price to replace the "convergence IC`s ", good luck, video-tek
Jul 01, 2009 | Philips 50P8341 50" Rear Projection...
I have green outlines in the pictures
go into your menu there should be something called convergence in the menu a red and a blue convergence. when you select one you will get a cross in the center of your screen use the selection keys to move this so the two crosses are on top of each other. once you align both the red and blue ( the green is the base) then go to the multi point convergence if all crosses are lined up you are good if not then you will need to replace the convergence I.C. for that color or both. let me know how this turns out.
Mar 04, 2009 | Philips 43P8341 43" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Converge colors?
If the colors look 3D or if you can't adjust the blue or red convergence the convergence chips and resistors should be replaced. You can get a repair kit and photo instuction guide for this exact model from www.TvRepairKits.com. Hope this helps
Nov 15, 2008 | Philips 9P5034C 50" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
2,050 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
