Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Hello! Hoover WindTunnel broken! aRGGHHH
Hello! Ive a Hoover WindTunnel Bagless Canister Cleaner with Powered Nozzle! I bought it a few months ago, and it just broke! The plastic underneath the "telescopic wand connector end" broke into 2 pieces argghhh!! just where i have to plug that thing (the telescopic stuff) in, so my question is should i have to replace the whole windtunnel (cos thats the part that holds this piece of plastic), or would it work if i repair it with an epoxy glue???... Thank you!
    Top Expert:
  • Hoover Master
  • 12,962 Answers
I would definitely check out the epoxy route.
Posted on Jun 14, 2017
SOURCE: Hoover Bagless Windtunnel - Self Propel feature not working
I have the same problem with ours. If you lift the vacuum by the handle it breaks the lever on the transmission. You can find a replacement cable and lever on line for about $16.00 it is somewhat involved to repair but can be done by someone with mechanical ability. You can try and find a repair shop but be careful, they sometimes tell you the part is not available and try to sell you something else. I think they should be able to do the job for aprox. $80.00, but they may want more. I did it myself plus the height adj. knob for $24.00
Posted on Nov 25, 2007
  • 126 Answers
SOURCE: hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Posted on Jan 20, 2008
yalmer
  • 552 Answers
SOURCE: U5780-900 Windtunnel maintance / cleaning
http://www.hoover.com/pdfs/manuals/U5780900.pdf
Here is a link to a pdf file at hoover website.
It explains alot.
Posted on Feb 22, 2008
nwj2468
  • 76 Answers
SOURCE: hoover windtunnel bagless shuts off when warm
it is a heat thermostat in the motor.
contact hoover or a local dealer
Posted on Jul 28, 2009
Vac Belts
  • 701 Answers
SOURCE: Describe how to replace belt on hoover windtunnel
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Posted on Oct 15, 2009
The electric motor in the Power Nozzle does not work when the turned on.
There could be several issues with this. First determine if the problem is in the nozzle, hose or wand. This can be done by turning the unit on and wiggling the connections. One known issue with canisters is the cord that sticks out the back of the power nozzle goes bad, due to movement and normal use. There are also 2 electronic control boards inside the canister that give some problems. If you are unsure about looking at it, take it to a qualified repair shop.
Apr 13, 2010 | Hoover S3765-040 WindTunnel Bagless...
Hoover bagless cannister 3765 - belt on power head slips off spindle. bought new belts - same problem. is this a design problem or can it be fixed? I don't want to take it to a repair shop 100 miles...
I would not recommend a smaller belt. You will only wear the motor. This model series power nozzle needs to have a metal clip installed near the belt on the brush roller housing. I know that most of them left the factory without it. Remove the cover to see if one is ther. if not have your dealer send you a clip or a housing with one on it.
Apr 03, 2010 | Hoover S3765-040 WindTunnel Bagless...
Vax hoover bagless, there is a burning smell coming from it
Most common burning smell is the belt in the power nozzle. check & replace.
Oct 11, 2009 | Hoover S3639 WindTunnel Bagged Canister...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Can not figure out how I have to attach the Powered hand Tool
Just got connected it to the main hose and press the switch on
Mar 28, 2009 | Hoover S3765-040 WindTunnel Bagless...
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a hoover windtunnel upright vacuum bought it a few months ago and now the brush spinning stopped working.
You probably have a broken belt, or the belt came off. The Self Propel Windtunnel has an issue with the pulley that tightens the V-belt in place getting stuck and needs to be taken apart and released, but most likely its just the belt. They should be replaced every 6 months or so, and the part number is usually on the serial tag of the machine.
Nov 22, 2008 | Hoover Vacuums
Red light for HIPPA filter won't go off
Red light is sign of reduced suction due to a blokage of some sort. If you are sure the filter is thoroughly cleaned, check the hose, wand, and the nozzle connector for obstructions of any kind.
Oct 25, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Hoover s3755 bagless windtunnel canister
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
79 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
