Question about HP Scanjet 8350 Flatbed Scanner
The ADT sometimes takes in multiple pages at once. It which case sometimes it james, and sometimes it doesnt and i'll never know this happend.
How to reset master code on adt alarm system without original master code
try 1234,just for kicks and giggles. if that does not work, I need to know system type.
Dec 01, 2012 | Home Security
Adjust shutter speed
Sometimes, some digital camreas dont allow set the shutter on multi-shoot mode; I suggest check this details on X500 User Guide.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 23, 2012 | GE X500 Digital Camera
Bizhub c450 scans multiple pages to separate scans
hi im lorenzo and i have been fixing konica minolta machines for about 2 years well lets catch to the case.
If you still have problems or cant change to multiple scan.
1.you have to get in the simulation mode because machine doesnt know if the HDD installed is in.
*simulation utilty/counter =details stop 00 stop 01
2. ONCE YOUR IN LOOK FOR SYSTEM 2 AND CLICK ON HDD YOUL SEE THAT HDD IS NOT INTALLED SO CLICK INSTALLED AND THEN EXIT END AND REBOOT THE PRINTER AND TRY TO SCAN AND IT WILL WORK
THUMBS UP IF IT WORK FOR YOU
Jul 18, 2012 | Konica Minolta bizhub C250 All-In-One...
How do I keep Rollers in feed tray from pulling multiple pages?
First of all, I apologize for my poor english. Of course you'll notice it's not my natural language. Not sure whether the terms I'll use are of common use or not. Anyway, before putting the paper sheets in the feed tray, with your fingers, leaf muliple times through them, on the side which will face the printer's feed tray. Oh, in case the sheets get disaligned in the process, first arrange them in line, prior to inserting them on the feed trray.
Hope it works for you.
Anyway, please, let me know if I can assist you any further.
Regards,Carlos
Nov 08, 2011 | Office Equipment & Supplies
I have a K8V-MX motherboard. Recently, when i start the computer i will sometimes get no video, sometimes i will. When it doesn't work the monitor just goes into power save mode. Everytime everything...
that happend to me aswell, coz the asus motherboard are like that.
1st unplug all the cabels from the mother board like, harddrive ID and Cd-room ID, leave just the power supply on and try to start Your computer if it doesnt work take off the cabels of USB or anything else that is connected in the motherboard and try to switch it on, if that doesnt work.
get another graphic card and try with it maybe u have prob with ur graphic card, and if that doesnt work take of the motherboard from ur case and try to switch it on like that coz ASUS MOTHERBOARD are really silly sometimes.
hope that Helps.
Sep 20, 2011 | ASUS K8V-MX Motherboard
I have a Maytag Performa model #PAVT920AWW that fills with water but doesn't agitate
If your washer fills properly but doesnt agitate you should do the following; this will be a lot, so bear with me please.
1. After filling (with the lid open), stop the timer and move it to the spin cycle. Insert something like a screwdriver into the hole to activate the lid switch. If it starts spinning and draining, then you'll know that the belt is okay. If it doesnt do anything at this point then you'll need to pull the washer forward and drain all of the water out of the tub. Tilt the washer back to lean against the wall. You'll then be able to see if the belt is broken. stop the timer and try to rotate the agitator around manually. If it will only move an inch or so to the left and right, you'll know that the agitator isnt stripped.
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/transmission-washer-Performa.html
Here is a link that should show you how to gain access into the "guts" of the washer.
2. Next you'll need to remove the agitator. Once you pull off the fabric softener dispenser, there will be a screw you need to remove to get the agitator out. The rest just pulls up and out. After this, you will see the transmission shaft......
3. Now you need to trick the washer into thinking that it's full of water. To do this you'll need to find the clear plastic tubing that runs into the bottom of the outer tub. It fits into a plastic looking case. Turn off the water supply (and of course the tub is empty once you've started all of this), and start the cycle. You'll hear the water valve solenoids buzzing. now take a putty knife and insert it under the top panel about 4-6" from each side to release the top panel. take the clear plastic tube off the bottom portion of the tub and start blowing a steady stream of air into the tube. The agitator shaft should now start moving back and forth............. If the motor starts running, but the shaft doesnt do anything, then you have a bad transmission, and it will need to be replaced.
That's a lot to take in, and I hope it's been helpful to this point. I think the first thing in order is to just figure out "why" it's not working properly.
If you figure out the "why" and want to know how to repair it, I would love to help you if I can. Dont hesitate at all, it would be my pleasure.
Again, I hope that you have found this helpful. I have written this small troubleshooting guide while tending to a little one's nose bleed, the dog carrying out the trash from the bathroom, and a glass of milk spilled all over the kitchen floor. thank you and let me know how it turns out.
thanks,
mike
Jul 19, 2011 | Washing Machines
Sidekick LX screen goes blank/black
ok this is what you do take out the battery for ten seconds and then hold the w key and while holdinq the w key put in the battery and then let qo of the w key after the battery is putten and then turn you sidekick lx on and thennn it shoulf work aqainn :]
Aug 05, 2009 | Sharp Cell Phones
When engine is hot sometime doesnt turn on. I have a new starter and changed fuel pump and new battery. Never happend when car is cold please help.
My Did That Too. Had A Mechanic take a look at It and he Said it was the ignition switch and he changed it and my car doesnt have that problem anymore.....
Jul 07, 2009 | 1996 Nissan Maxima
K JAM
that happend to me once, i totally freaked out.... try turning it completely off, remove the sd card, then turn it back on.
once your phone has finished booting up (and all programs have finished loading), put in your SD card.
If that doesn't work you could always hard reset the phone (sometimes that fixes it)
Jun 25, 2008 | i-mate K-jam Smartphone
I don't know what to do
this also sounds mechanical. check between the keys for as much rubbish as you can, then clear it. if this doesnt solve your problem, then start to go from there. seriously, this doesnt sound like a foul up in the normal sense (software). more like simple dirt to me. check everywhere. suspect even the smallest piece of dirt.keyboards are pretty robust these days, but sometimes even the smallest of things can cause immense foul ups. if this does not work, let me know. there are somethings that can still be tried after that, but they are more difficult to do with a fouled up keyboard, believe me.
May 16, 2008 | Compaq Keyboard
HP Scanjet 8350 Flatbed Scanner Logo
24 people viewed this question
Seeker5211
Seeker5211
