Question about Dell Dimension 4550 PC Desktop
Looking for replacemnt harddrive for my 4550 with
Looking for reccomendations for a replacement harddrive for my 4550 with 2.53GHz pentium 4 processor
  • 333 Answers
You can use any ide hard drive that you want. Choosing a new hard drive depends highly on your requirements of use. If you're using it as a raid drive, then you need a drive with a high rpm rate. It all depends on what you're using the computer for.
But if you just want a new hard drive for general use, then any ide hard drive you want. A great website that sells affordable hard drive is www.directron.com
Posted on Sep 23, 2009
  • 3,940 Answers
Largest drive it shipped with was a 120 GB drive, but this 160 should work> http://www.newegg.com/Product/Product.aspx?Item=N82E16822136112
Use Windows XP SP2 or higher
Mx6955 processor support
Compatible Processors Pentium 4, Celeron D, Pentium Extreme Edition, Pentium D 64-bit Processors Compatibility Yes Processor Socket LGA775 Socket
Aug 11, 2013 | ASUS Computers & Internet
Can i up grade my single core cpu pen4 550 3,4GHz to a Quad core or dual core either one would help
Depends on the socket type.. Socket 423 and 478 do not support core duo or quad core processor types. However, if you have LGA 775 (aka socket T) your motherboard will support the following:
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition (3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition (3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
Mar 22, 2011 | HP Pavilion a775c (A775CB) PC Desktop
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
Can i put a amd processors in a dell dimension
Short answer: NO.
Long answer: AMD processors have a different pin-arrangement than found on a Socket 478 motherboard, so they physically will not fit.
Jul 03, 2010 | Dell Dimension 4550 P4 Socket 478B...
What processor can use to upgrade my Pentium 4 2GHz in my HP M1270
HP Media Center M1270n desktop PC?
Here are the Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00280666&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=443756
Here is the Motherboard Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00297771&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=443756
The Asus PTGD1-LA motherboard, is a Proprietary motherboard, made Especially for HP.
HP's name is PufferM-UL8E
You won't find it on the Asus Support website.
Fortunately, HP listed basic information for CPU (Processor) Support.
When you look to the right of the CPU/Processor heading, you can see it states -
A) Socket LGA 775 (Processor socket)
Looks like this,
Processors that fit this processor socket, have the socket holes.
775 of them.
The LGA 775 processor socket, has the pins that go up into the socket holes of the Processor.
775 of them.
[The Socket 478 processor socket, that was before the Land Grid Array 775 processor socket, has the socket holes (478), and the processors that fit this processor socket, has the pins. {478 of them]
B) Supports processors with up to a 3.8GigaHertz frequency rate.
3.8GHz.
['Speed' is a slang term for Frequency Rate.
Giga = Approximately 1 Billion
Hertz stands for Cycles per Second.
3.8 Billion Cycles per Second.
Can also be stated as 3800 MegaHertz.
Mega = approximately 1 Million ]
C) Can support Intel Pentium 4 processors with HT.
Hyperthreading Technology.
D) Looking to the right of the Front-side bus (FSB) heading, you will see it states -
800MHz.
This means the Asus PTGD1-LA motherboard will support Pentium 4 processors with,
1) HT
2) UP TO a 3.8GHz frequency rate
3) Up to a FSB frequency rate of 800Megahertz.
4) Use an LGA 775 processor socket.
Now let's look at one example, of a chart of Pentium 4's with HT, that fits these specifications,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29_2
See the heading - Prescott (90nm)?
This means the processors in this chart, are based on the Prescott Core, and the 90nm architecture.
(nm stands for NanoMeter. Approximately 1 Billionth of a meter)
Looking at the headings in the chart, you will see Model Number, sSpec Number, Frequency, L2-cache, Front-Side Bus, Multiplier, Voltage, TDP, Socket, Release Date, Part Number/s, and Release Price.
At this point I would only concern myself with the,
Model Number, (If applicable),
sSpec Number,
Frequency,
FSB, (Front Side Bus),
Voltage,
Socket,
and Part Number(s)
1) Model Number:
The older Intel Pentium 4 HT processors did not have a Model Number.
Intel didn't start using a Model Number until later.
Model Number examples start with 517, 520, 520J, and so on.
Look for the sSpec Number, and the Part Number, for the older Pentium 4 HT's. They're printed on the top of the processor's case, and should be listed by the seller.
2) sSpec Number:
Intel brought this out.
Their way of marking a processor.
Another identifier for you to use.
3) Frequency:
The Maximum frequency rate, ('Speed'), that the Processor is supposed to be able to operate at.
4) L2-cache:
The small memory area for the Processor. The Processor accesses this small memory area first, because it operates at the same frequency rate as the Processor.
You can't change it, and 2MB of L2-cache, is the largest size for an Intel Pentium 4 with HT.
Just thought I would include this information.
(Ram Memory is next. Typically, Ram Memory operates at half of the FSB frequency rate. The Harddrive is next)
5) Front-Side Bus (FSB):
The frequency rate that the Processor transfers data (Information) to the Northbridge chip, and back from the Northbridge chip.
More on the Northbridge chip in a moment.
6) Voltage:
Pretty self-explanatory. The Voltage range the Processor will use.
You need the Voltage range of 1.25/1.4 Volts.
(1.25 Volts to 1.4 Volts)
Any Processor (That is Intel Pentium 4 HT, Socket LGA 775), that uses Voltage in this range will work.
7) Socket:
The type of processor socket that the Processor will fit in.
Has to be LGA 775.
8) Part Number(s)
Self-explanatory again.
The Part Number, that is stamped on top of the Processor's top case.
Part Number(s) is listed, because there may be more than one Processor in the Model Series, that fits the same specifications.
If there is no Model Number, refer to the sSpec Number, or Part Number.
The largest frequency rate (Speed) of Processor you can use, is a Pentium 4 HT that operates at 3.8GHz. (And fits in an LGA 775 processor socket)
Barring that a Pentium 4 at 3.8GHz cannot be found, you will know what Processors you Can use.
Scroll across the headings with your eyes, and start under the Frequency heading.
Find the frequency rate ('Speed') you wish to try.
Go across to the Front Side Bus heading. You should look for a processor listed that has an 800MHz listing.
Look at the Voltage.
All of the Intel Pentium 4 HT processors that fit in an LGA socket, use an 800MHz FSB, and are in THIS particular chart, fall within the same Voltage range.
Keep the Voltage range in your mind, as you look at the other charts below this one.
Socket.
You know you need a processor that fits in an LGA 775 socket.
Look at the chart below this Prescott Core (90nm) example.
Prescott 2M Core (90nm)
Use the above criteria above in this chart.
I wouldn't recommend any Pentium 4 HT's, in the Cedar Mill (65nm) chart.
It isn't that the architecture is smaller (65nm), but that the BIOS program,and version on your motherboard, may not be able to handle these processors listed.
I also do not see a BIOS update for one, and for two, if you make a mistake when performing a BIOS update, your motherboard becomes an expensive Frisbee, or doorstop.
You also do not want any of the processors listed under the Pentium 4 Extreme Edition heading.
(Mobile Processors are for laptops Laptops are M-O-B-I-L-E)
Northbridge chip.
1) The Northbridge chip, and the Southbridge chip make up the motherboard chipset.
(Does not apply to the new motherboards that support the Intel i3, i5, and i7 Core processors)
2) Chip and Chipset are slang terms for I.C.
Integrated Circuit.
http://en.wikipedia.org/wiki/Integrated_circuit
The Northbridge chip handles the faster processes of the computer.
Processor, Ram Memory, and High speed graphics.
(AGP or PCI Express. Not a graphics card in a PCI slot, nor Integrated Graphics on the motherboard. These are slower processes of the computer)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
(CPU = Processor
Memory Slots = Ram Memory slots)
Looking at the diagram, you can see the slower processes handled by the Southbridge chip.
Looking back at the Motherboard Specifications, look across from the Chipset heading.
Northbridge: i915P graphics and memory controller hub
(MCH)
Southbridge: ICH6 Intel I/O Controller Hub 6
Uses an Intel 915P Northbridge chip, and an Intel ICH6 Southbridge chip.
Jun 27, 2010 | HP Media Center m1270n (PP132AA#ABA) PC...
I have intel pentium celeron 1.70ghz 256mb ddr ram, i wana upgrade it to P4, i got 8284g motherboard
8284G tells me nothing unless I want to hazard a guess, and I don't.
I like to post factual information.
8284G could be a pre-built computer manufacturer number on a label, that is stuck upon the motherboard manufacturer's printed model number, on the motherboard.
All pre-built computers have their motherboards made by a motherboard manufacturer, they do not make their own.
Or it could be a printed model number on the motherboard, but refers to the pre-built computer manufacturer model number, that they wanted printed on. Printed on for them by the motherboard manufacturer.
It could be a reference to a part number on a chip of the motherboard. An Intel 8284g which is a graphics controller chip. (Chip and chipset are slang terms for Integrated Circuit, or IC)
http://www.intel.com/support/graphics/intel845g/sb/cs-009072.htm
However though, the Intel 8284G graphics controller chipset is usually used in conjunction with the Intel i845 chipset family.
(845, 845E, 845GL, 845G, 845GE, 845PE, and 845GV)
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
The Intel i845 chipset family supports Intel processors that have up to a 400MegaHertz Front Side Bus. (400MHz FSB), and some of the Intel i845 chipsets will support processors with up to a 533MHz FSB.
So now let's look at the Intel Celeron 1.7GHz processor,
http://en.wikipedia.org/wiki/List_of_Intel_Celeron_microprocessors#.22Willamette-128.22_.28180_nm.29
1) Based on the Willamette-128 Core
2) Based upon the 180Nanometer architecture. (180nm)
3) Uses a 400MHz FSB
4) Uses 1.7 Volts (DC)
5) Uses the Socket 478 processor socket. (Processor has 478 pins, processor socket has 478 socket holes)
Based upon the processor information, and processor information only, you could use an Intel Pentium 4 that has a maximum frequency rate of 2.0GHz, and uses a Socket 478 processor socket.
I also believe it should be based upon the Willamette Core. Reasoning is that the Willamette Core Intel Pentium 4 processors, use 1.75 volts.
The next generation of Intel Pentium 4's are based upon the Northwood Core, and the 130nm architecture.
They use 1.475 to 1.525 Volts.
I don't know if you would install one of these Intel Pentium 4 processors, and your BIOS would automatically recognize it, and set the voltage to match. If not, the processor would burn up due to too much voltage.
What would you gain if you installed a Pentium 4 2.0GHz processor?
Intel Pentium 4's have twice the cache that a comparable Celeron does.
Cache. Crude explanation:
You are writing a thesis, and you need more information. The information is located in books, which are in the basement in a box, and there is no light in the basement.
Down you go with a flashlight in hand, locate the box, and look through the books until you find the book you need.
Back upstairs you open the book, and find the page/s you need for your information.
You find that not all the information you need is located in that book, and back downstairs in the basement you go, flashlight in hand.
OR, you press a few keys on your keyboard, of the computer in front of you, and have your information is seconds.
Low cache is the basement scenario.
Large cache is the computer scenario.
The processor cache is a small memory area for the processor. It operates at the same frequency rate as the processor, therefore it is the fastest memory area available for the processor. It is also the first memory area the processor 'sees'.
Ram memory is next, followed by the harddrive. The harddrive is slower due to it being a mechanical device. (SSD or Solid State harddrives are faster than the mechanical IDE and SATA harddrives. Still not as fast as Ram Memory though)
The .3GHz increase, and the cache increase will be a slightly noticeable difference.
Enough to "Write home to mom about?"
Nope. Not IMHO.
You probably won't notice any increase when on the internet, or doing school/business work.
You differently won't notice any real increase when gaming.
To summarize:
The amount spent, and the time looking, for an Intel Pentium 4 processor that is 2.0GHz, and based upon the Willamette Core, just won't be worth your trouble.
Unless someone just gives you one.
Mar 22, 2010 | Intel Celeron -D 2.26Ghz Computer System...
Need to replace the processor but dont know which one to get..
Intel Processor Pentium 4 672 3.80GHz 2MB Cache 800MHz FSB VT computer component
regrads
Mar 17, 2010 | Alienware PC Systems ALIENWARE 5620D...
UPGRADING FROM PENTIUM 3 PROCESSOR TO PENTIUM 4 PROCESSOR
To upgrade from a Pentium 3 to a Pentium 4 processor, you would have to replace the motherboard. The Pentium 4 processor has more pins on it than the Pentium 3 and would not sit in a Pentium 3 motherboard.
Apr 05, 2009 | Compaq Deskpro EN PC Desktop
Computer shuts down automatically when it starts to load OS... can anyone fix this problem out...
you might need a new hard drive or need to reload the operating system also might be an issue with the bios chip or mainboard
try running the computer with the harddrive only connected and your video card and a keyboard
Mar 15, 2009 | Intel Pentium 4, 2.4 GHz Pentium 4-M 705...
Dell Dimension 4550 PC Desktop Logo
66 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
