Question about Pentair Minimax NT Heater
Water is leaking out of the far right burner tube, while pool pump is running.
  • 366 Answers
Sounds like you either have a pinhole in your heat exchanger or possibly a bad tube washer (seal). A pinhole can result from poor water chemistry or chemical exposure such as pH chronically low or a chemical feeder (chlorinator or salt cell) installed near the heater without a chemical resistant check valve. You will have to dismantle the heater far enough to access the heat exchanger and inspect it while the pump is running. If it's a pinhole in the exchanger, you will need a new exchanger. If its a seal, you will just need a new set of seals (washers) for the exchanger manifold.
Posted on Sep 24, 2009
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Tip
How to fix air conditioner causing a lot of Water pools
Air conditioners and high-efficiency combustion furnaces create significant condensation, which exits through a plastic drain tube. This should go into a floor drain or be carried away by a small “condensate pump.” If water is pooling at the base of the appliance, something may be blocking the water's flow, or leaking, or the pump may not be working.
1) Look to see if one of the tubes is leaking. If it is, replace it.
2) Test the condensate pump by pouring water into its pan. If the pump doesn't start, either it isn't receiving power or it is broken. Be sure that it's plugged in and test the circuit. If it's broken, either get it repaired or replace it.
3) If the pump runs but doesn't empty the pan, the ball-like check valve just before the discharge tube is probably stuck. Unscrew the check valve, loosen the ball inside, and look for an obstruction. If it appears that a condensation drain tube is clogged with algae, remove it if possible (you may have to cut it and replace it later with a coupling). Run a wire through it to clear it. To kill the algae, pour a dilute solution of bleach (1 part bleach to 16 parts water) through the pipe.
4) Ice may be blocking the tube. If this is the case, be sure the filter isn't dirty. If the filter appears to be fine, the air conditioner's refrigerant supply is probably low. This is when it's time to call an air-conditioning technician.
on Sep 02, 2010 | Heating & Cooling
Tip
Pool loosing water?
Maybe you cannot decide if the loss of water in your pool is a leak or evaporation. If you place a bucket of the pool water on a step in the pool with the water level the same inside and ouside the bucket exactly the same and run the pool pump for a day, then you will be able to tell if youi have a leak. A leak would result in a lower level in the pool after running the pump for the day. If the levels stay the same, then it is evaoporation.
on May 10, 2010 | Plumbing
Pool heater
If you have bubbles, you have a suction leak. That means the pump is pulling air into the system. Sometimes it's just the basket o-ring under the pump lid needs replacing. If the pump has run hot (without water) for a while, it may have caused shrinkage at the inlet to the pump. Unless it is underground, suction leaks are fairly easy and inexpensive to fix. Heaters will not work properly with air in the system.
Jun 23, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool pump issue
Copy following link to identify Hayward product and download product manual with troubleshoot section:
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1___I.htm
Select 'Pumps: above ground' or scroll down to same
Typical troubleshoot section:
Low flow "Check for clogged strainer or suction line, plugged discharge line, air leak in pipes or tubing, bad impeller"
Noisy pump "Check for air leak, foreign matter in pump housing, worn out bearings etc"
Air in line due to loose pipe or tube, clogged intake and outfow, and bad pump is common to both symptoms.
May 07, 2013 | Pool & Spa
Our pump was running dry for at least a day because a leak dropped the water level below the skimmer. it runs on 220 and sounds like it's running but no water movement in or out. i need a new pump, right?
not necessarily if running may need to be bleed[air bound and need to let out air ]or may need to be primed if there is a bleeder on pump housing un- screw to release air until water runs out --- if still no water pumping may have damaged the impeller depending on ur pump may have to only replace impeller or pump housing
Jul 20, 2010 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
G4-7 atwood water heater lights great, heats water but when it cycles the pilot goes out no hot water
Sounds like the burner flame may be too strong (jumping out from burner tube) . Some people think the louder the better, but that is not correct. When burner shuts down like that, it has a tendency to snuff out pilot as well. Adjust your air shutter at burner so that the flame is a nice blue, or with just a hint of orange/yellow at the tip. Whatever setting that keeps the flame solid from burner tube, and not a big gap between tube and flame. Signs of soot (black) up the cover, or side of trailer means it's running too rich, and you've gone too far thus needs more air. Keeping the flame blue but still right out of the burner, actually heats better, is quieter, and should eliminate that pilot getting snuffed out. Pilot should also be a nice blue flame as well. There may be a problem with positioning of the burner tube as well, but doubtful if it has been running well in that position before. Let me know what happens.
May 10, 2010 | RTO Atwood Water Heater - 6 Gal LP
My Jet Pump Looses it's prime at night.
I assume the pump is not running at night. If the pump is higher than the pool, and the inlet and outlet to the pool are both under water, then you have a small leak. This could be allowing the water to leak out of the line. Or, if the leak is higher than the pool surface it is allowing air to leak into the line, which allows the prime to run down into the pool. If you found this useful, please vote. Thanks.
Feb 16, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
I have a Shasta pool from 1996. I replaced the
either you have an air leak somewhere on the suction side or your impeller is very clogged. you can fill the pump with water and turn it on, it should try to pick up prime, right when it starts to pull in some water turn it off and try to listen for air leaks or water squirting out somewhere on the suction side. Also, remove the pump basket and try to feel the impeller to see it there is any debris in it. the main cause for a clogged impeller is a cracked or broken pump basket. Also, if the pump has run dry for any period of time, the threaded fitting on the suction side of the pump can shrink and cause a large enough air leak to keep the pump from priming.
Nov 14, 2009 | Pentair 3hp Whisperflo Pool Pump In -...
Water Pump leakes from steel tube.
when installing new o-ring on tube, lubricate o-ring and stick it in water pump. Then pull pressure back on tube and then tighten hold down clamp. problem solved
Apr 16, 2009 | Dodge Caravan Cars & Trucks
Pentair Minimax NT Heater Logo
243 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
