Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
Trying to find correct distributor for (experts tell me)what we think is a 1952 TO20. A Delco rebuilt sent does not fit. It has a cam around the "shaft", whereas mine is smooth all the way. Maybe it isn't a TO20, maybe it's a TE 20. What distinguishes the one from the other? I was told that the location of the oil filter (on bottom of oil pan), and connection of gear box to body (separate and with 2 bolts for removing)makes it a TO, not a TE. Any other distinctions? And how can I find the correct distributor?
  • 496 Answers
I love digging into stuff like this, but I'm out of time here. I'm forwarding something that might help a little. If you can obtain your serial number, this link is a chart to help identify year and origin. TE/TEA20s were built in Coventry, UK and all TO-20s were built in Detroit, USA
I'm interested in your serial number if you can send it in a reply... with that, I'll do some more looking.
Thanks!
http://www.fergusonenthusiasts.com/serial%20numbers/SNRanges_1946_1960.pdf
Posted on Sep 23, 2009
DISTRIBUTOR WILL NOT GO IN FLUSH IN THE CAM
Hi,if I was you I would put the distributor in the only way it will fit.
as long as you have got the valve and crank timing gear setup correctly you cant do eny damage.if you have set the valve and crank so when you turn the crank twice from tdc mark and the marks line up then you can sort out the ignition timing out after.
hope this was some help
Jul 17, 2015 | 1993 Toyota Camry V6
Installed rebuilt short block and will crank but not start and backfires out intake have had several people check timing and seems good new grank and cam sensors also
timing is off 180 degrees,find number 1 piston,find top dead center,pull off distributor cap and see if it lines up with number 1 plug,if its off,pull distributor and place back in correct position
Jul 03, 2015 | Cars & Trucks
Z24 engine specs
place the timing mark on the crank pulley at the correct ignition timing mark (10 degrees advanced). Place in the distributor so that the rotor button points to no1 cylinder in the cap. when fitted in properly turn the distributor so that the points are just opening. ( you can get this by turning on the ignition and when you see the points spark or hear a spark click then lock the distributor up at that point . Use a timing light for final set. If it wont start you got it on 180 degrees out then just move the HT wires around 180 degrees. If you have a transistorized ignition then when the point of the cam star is directly opposite the magnet point that is the same as the points.
Nov 04, 2013 | 1989 Nissan Hardbody King
93 Jeep Cherokee has very weak spark from the coil and will not start
You are correct in your understanding. If the coil has at least 12 volts and gets a ground signal from the computer, the coil should fire. The coil actually sparks when the ground is removed.
The cam and crank sensors tell the computer when the cylinders are at top dead center which also opens the injectors.
Have you checked to see if you have battery voltage at the coil, and tried another coil ?
Dec 12, 2012 | Cars & Trucks
19981500 silverado code p1345,i am being told this means i need a new timing chain is this correct
if the distributor is tight no slop in shaft movement up and down ok side to side tight then you need to check dist calabration its actually a cam sensor in the distributor if you hook up a scan tool to it and look at the cam position it will show how far its out it should be -2 or 0 at 1000 rpms you can adjust some by turning the base of the distributor if the timmig chain gets to sloppy you wont get to the correct specs. hope this helps
Feb 29, 2012 | 1998 Chevrolet K1500
PO340 No Cam Signal The car stalled a couple of times and this code came up after the Service light came on
the cam sensor is a part in the distributor.you should check the voltage readings for the distributor and compare them to spec,to make sure the distributor is getting the correct readings.we used to get one from the wreckers as they were far cheaper than a new or rebuilt.you can have the unit sent away to be rebuilt to have only the defective part replaced or just buy a rebuilt unit.
Oct 27, 2011 | 1996 Plymouth Grand Voyager
Have rebuilt motor new everything from mazda now i have pooo12 code retarded intake cam checked timing with sst and ex and in cam are in perfect alignment with sst the solniod tested out fine . the only...
remember 1 thing..dont confuse cam timing with ignition timing also if the belt or chain has alignment dots or marks on it ..it can be put on backwards and still line up marks correctly but but in a different position making the cam timming off i have done it and seen it done before like an old chevy when you put timming gear set on you line up the 2 dots alot of people think that is tdc and they set up ignition and go to start it and get pops and bangs well thats because the the install dots are actully 180 degrees out from tdc so you remove the distributor and turn it 180 deg. and now she starts right up i think you have 1 of these cams a tooth off or your using marks incorectly or belt or chain is backwards making dots align in different postion appearing correct
Oct 02, 2017 | Mazda CX-7 Cars & Trucks
On a '99 Chevy Astro, I was getting multiple engine misfire code, so I installed a new distributor. That fixed the misfire, but then I got PO 340 (cam position sensor). Why would a new distributor cause...
You may be out by one tooth on your new distributor installation.Try advancing or retarding by one tooth by removel and reinstalling distributor.I do not think there is anything wrong with your Cam position sensor. In fact I think it is trying to tell you that the gears on the distributor are not in propper position with the gears on the cam so give it a try and good luck.
Dec 05, 2010 | 1999 Chevrolet Astro
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
392 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
